OutlawDaves WJ - 4" Rough Country Long Arm Build - JeepForum.com
 14Likes
post #1 of 260 Old 07-10-2015, 08:36 PM Thread Starter
OutlawDave
Updated Build details
Ordered from Kolak:
Clayton Offroad 4.5" springs set
Bilstein 5100 series shocks
JKS HD front adjustable trackbar
Addco 1" rear antisway bar
Energy greaseable bar mount bushings
Crown Automotive rear spring isolator set
Crown Automotive front upper control arm bushing set
Ordered from a buddy in my local jeep club:
Rough country WJ Long Arm Upgrade
Summit Racing:
Cragar 15x10 "D" Window, 4" Back spacing - CRR-3425150 Ordered center caps and new lugnuts as well
Smittybilt X20 Gen2 Wireless 10k COMP Series Winch with synthetic rope - 98510
Bushwacker fender flares - 10926-07 (In progress)
Rock Auto:
MOOG Tie-Rod ends - ES3472, ES3473, ES3474, ES3475,
MOOG upper ball joints - K3134T (These are a new style and look odd at first)
MOOG lower ball joints - K3185
Discount tire:
Wrangler MT/R Kevlar - 33x12.5x15
Wrangler MT/R Kevlar - 35x12.5x15 (went to 35's on 1/16/17)
Major events:
HK Offroad Hidden winch installation
247J to 242HD transfer case swap
Kolak 3" cat-back exhaust system (12/6/16)
Teves to Akebono brake upgrade (12/26/16)
4.88 gear swap and differential overhaul - 11/01/16
Saving a few links here for later:
160 Amp Alternator Upgrade
Blend Door repair video
HID Retrofit
Maintenance dates:
MAP Sensor - 6/15/15
All tie rods - 8/15/15
Passenger side upper / lower ball joints - 10/20/15
Idle air controller - 1/18/16
Throttle Position Sensor - 1/18/16
Crank position sensor - 8/15/16
Pads, Rotors and front Calipers - 12/26/16
Interior Lights to LED's - 1/05/17
More to follow and will take lots of pictures to detail the build
Here is the before picture - 2" Fat Bobs spring and shock lift courtesy of the previous owner - Grabber 255/70/16
20150621_113400.jpg   12027584_1013878291965984_7634502919235749981_n.jpg   988760_1106019202751892_6887181743462206546_n.jpg   20170119_173709.jpg
tybarious likes this.
4.5" RCLA, 35's, HK Hidden Winch, Bushwackers, 242HD, 4.88
See GC General forum for build
OutlawDave is offline
post #2 of 260 Old 07-10-2015, 11:50 PM
Kolak
Vendor
Kolak's Avatar
Looking forward to this build
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #3 of 260 Old 07-13-2015, 08:14 AM
Jeeples
Jeeples's Avatar
I'll have to keep my eye on this thread, as that was the setup I was originally going to go with. Good luck!
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #4 of 260 Old 07-14-2015, 09:08 AM
tymaoaretae
tymaoaretae's Avatar
2003 WJ
Minus the addco bar and plus some OME spacers I'm running that same setup. Wish I'd started there rather than ending up there through trial and error. I think I'll be satisfied for a while though, with the suspension at least...
2003 WJ LTD 4.7, 242HD, PR44+ARB+RCV & D44HD+varilok+BTF 4.56, 7" RC LA (Clayton coils + pucks), Bilstein 5165, OBA, Lizardskined & Monstalined inside.
tymaoaretae is offline
post #5 of 260 Old 07-23-2015, 04:15 PM Thread Starter
OutlawDave
Been a very busy past few weeks and just when I wanted to get started and order the remainder of the lift, my home AC decides to need some attention. Being in Houston and 99-100 th epast few days it took priority and pushed some things back a bit.
But I did manage to install some goodies that are starting to show up.
If you've lifted even with a budget boost, do yourself some justice and install the Addco swaybar and greasable Energy Bushings from Kolak ... its a night and day difference. Here is some Parts Porn to show the comparisons ....
post #6 of 260 Old 07-28-2015, 06:01 PM Thread Starter
OutlawDave
Got more parts in today .....
Ordered my rims from Summit, the rest of the tie rods and the RC Long Arms from my buddy today (Wifes gonna kill me ...)
Think Ive settled on the Wrangler MT/R Kevlar's
post #7 of 260 Old 07-28-2015, 06:03 PM Thread Starter
OutlawDave
The JKS HD Trackbar is one beefy piece of steel ... very impressive
post #8 of 260 Old 07-30-2015, 12:02 PM
CarolinaWJ25
Subbed as well. I have been planning on going the same route
CarolinaWJ25 is offline
post #9 of 260 Old 08-06-2015, 07:41 PM Thread Starter
OutlawDave
Got home today and my buddy calls me up and says there are a bunch of heavy as hell boxes on his front porch with my name all over them.
Parts pics !!!
I have looked at several posts so I tried to give various angles to show weld quality (Very good btw) and shear size in comparison to a known object.
These things are massive, much bigger than I was expecting
And the elusive joint assembly tool that has been missing in several other kits Ive read about.
Cant wait to get started, but its been 104 the past few days so this is going to be a slow process
20150806_201801_resized.jpg   20150806_201814_resized.jpg   20150806_201829_resized.jpg   20150806_201848_resized.jpg   20150806_201855_resized.jpg
20150806_201924_resized.jpg   20150806_201935_resized.jpg   20150806_201945_resized.jpg   20150806_202025_resized.jpg   20150806_202045_resized.jpg
post #10 of 260 Old 08-06-2015, 07:47 PM Thread Starter
OutlawDave
While Im waiting for the weather to cooperate, if anyone wants any closer pics of parts, let me know. I want to document as much as I can for future builders.
Consider this a comprehesive eval of the RC Kit
post #11 of 260 Old 08-06-2015, 08:52 PM
SteeleJay
SteeleJay's Avatar
I love all those parts pics because that's exactly what's under my rig, and I tell you I couldn't be happier. I went a different route with springs/shocks - 4.5" Rusty's springs and their 4-6" lift shocks (I wish I'd gone with Bilsteins). I also got the JKS trackbar, so your build is going to be very similar to mine. I did not get the beefier rear sway and to be honest, I'm not sure I get it? Sway bars limit wheel travel - why would I want a bigger one in the back where I can't disco it?
I've had zero issues with drive line vibration or anything other than loud road noise from my mud tires.
I'm very much looking forward to watching your build.
Build Thread:
SteeleJay is offline
post #12 of 260 Old 08-06-2015, 09:15 PM Thread Starter
OutlawDave
Here is some current pics as she sits before the lift
20150520_185903_resized.jpg   20150520_185921_resized.jpg   20150520_190012_resized.jpg   20150520_190029_resized.jpg   20150520_190246_resized.jpg
post #13 of 260 Old 08-06-2015, 09:23 PM Thread Starter
OutlawDave
Honestly SteelJay watching your build is what swung me this direction.
Kolak gave me a great deal on the Claytons springs so thats the reason I went that route
post #14 of 260 Old 08-06-2015, 10:08 PM
SteeleJay
SteeleJay's Avatar
Cool, thanks for the acknowledgment!
As for springs, you probably got the better option. I don't know if Clayton products are as good as everyone says, but they certainly do get the love, whereas I've only seen a handful of threads even mention Rusty's products. Part of me thinks there's got to be something to that.
Build Thread:
post #15 of 260 Old 08-12-2015, 10:12 AM
LSRGreg
Good luck with the build! Your going to have a blast with it when your done!
04 WJ, Limited, 4.7 HO, w/ lots of goodies
Incline Winch bumper from WWW.FRANTZDESIGNWORKS.COM
LSRGreg is offline
