Off Topic: Welder Selection? - JeepForum.com
post #1 of 3 Old 06-22-2013, 02:27 PM Thread Starter
JackedLaredo
1994 ZJ
I'm thinking about getting a welder to do some automotive work such as bumper fabrication, axle work, skid plates, etc. What type of welder would be best suited for this style of work?
JackedLaredo is offline
post #2 of 3 Old 06-22-2013, 02:31 PM
Technohead
This question is best posed in the Fabrication forum.
The short answer to your question is that you need a welder that runs on 220v and can produce at least 180 amps.
A good entry-level unit would be the Miller 211.
-Eric
Technohead is offline
post #3 of 3 Old 06-22-2013, 03:07 PM
Oldfrog
2007 WK
You'd be surprised at what I can do with my little Lincoln 120v wire welder....but he's right. For heavy stuff...over 1/4" thick, you'll need a heavier unit. That 220v model Lincoln wire welder lays it in there like butter, especially if you use the gas too. I havent used a stick welder in years...no need.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
