O2 Sensors and my check engine light - JeepForum.com
post #1 of 1 Old 05-17-2010, 10:37 AM Thread Starter
MicahHudson
1997 XJ Cherokee
So I recently purchased a 97 Grand Cherokee Laredo under book price which needed some mechanical work. As we are getting into the vehicle, I checked the codes and it was due to O2 sensors, so I crawled under to check it out. The previous owner had replaced the exhaust with one that does not have a catalytic converter and no spot for the post-cat O2 sensor so the wiring is just zip tied up in there. Also the pre-cat sensor is in, but it was disconnected. I know that with them disconnected it will just default to a set fuel ratio, but I was wondering if I should hook up the pre-cat sensor and make a way to install the second sensor? I want to get good mileage and be nice to the engine, but without the cat. conv. I didn't know how that would affect the readings.
Thanks
-Jeep Greenhorn
MicahHudson is offline
catalytic converter , emissions , exhaust , o2 sensor
Check Engine Light On: 1995 Jeep Grand Cherokee Limited 4x4 4.0 Engine Keith1975 ZJ Grand Cherokee Forum 7 11-04-2014 10:31 PM
Check engine light and ways to check codes cody11ca ZJ Grand Cherokee Forum 12 01-11-2011 09:04 PM
OK... Changed the O2 Sensors... Still have a check engine light... JonM81 ZJ Grand Cherokee Forum 27 10-17-2009 07:30 PM
0 oil pressure and no check engine light? Also what trigers major check engine fault SPL Tech ZJ Grand Cherokee Forum 9 01-08-2007 08:28 AM
check engine light, engine losing power kemicalburns ZJ Grand Cherokee Forum 21 05-27-2005 02:49 PM
