Noob check-in/build thread? - Page 4 - JeepForum.com
post #46 of 65 Old 02-10-2013, 09:41 PM Thread Starter
GrandPuba
Went cruising and junk yarding today. The Jeep sounds great...nice mellow tone, not annoying. The lift rides good, doesn't seem much rougher than stock. Turns out I replaced the wrong O2 sensor though! It threw the code again. I thought it was the "rear" one after the precat, but I realized there's two of those dumb things and 2 O2 sensors before them. So it seems it would be the rear of those 2. Anyway...time to get it dirty I think.
If you can't google it, you really shouldn't be looking it up.
'04 Grand- OME HD blah blah
'65 Chevy C-10...things are happening...
'88 Comanche...dead and buried :(
GrandPuba is offline
post #47 of 65 Old 02-17-2013, 07:09 PM Thread Starter
GrandPuba
Finally unloaded my junkyard loot... Time to mount my receiver I think!
post #48 of 65 Old 02-17-2013, 07:11 PM Thread Starter
GrandPuba
Also replaced my TPS and rear bank O2 sensor. Cleaned the throttle body and AIC. So far running way better. Smooth consistent idle, proper shifting, no converter weirdness.
post #49 of 65 Old 02-17-2013, 08:54 PM
wvracer821
Looks like you had a great day at the junk yard
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #50 of 65 Old 02-17-2013, 09:08 PM Thread Starter
GrandPuba
Indeed I did... All this was only about $150. Oh, with hatch glass too! I did just realize that the donor probably has a Dana 44 though. O_o
post #51 of 65 Old 02-17-2013, 11:17 PM
xrunndonex
1994 ZJ
Guess you should make your way back then
xrunndonex is offline
post #52 of 65 Old 02-18-2013, 12:31 AM Thread Starter
GrandPuba
No doubt... I wouldn't be surprised if it was already gone though.
post #53 of 65 Old 02-18-2013, 12:47 AM Thread Starter
GrandPuba
Got my junkyard hitch installed... Wiring and hatch glass tomorrow probably.
post #54 of 65 Old 02-18-2013, 02:38 AM
xrunndonex
1994 ZJ
Its possible I'm really cool with this guy that tows wrecks and such and whenever he has a Jeep about to go to the jy he hits much up so I can get first dibs
post #55 of 65 Old 02-18-2013, 08:09 AM Thread Starter
GrandPuba
That's a very cool possibility...
post #56 of 65 Old 02-18-2013, 08:59 AM
houston92
Which junk yard did you go to, I've been meaning to go shopping
2000 WJ 4.0l
3" IRO w/ Bilstein 5125
31x10x15 BFG A/T K/O
flowmaster 50
magnaflow cat
kolak 2.5" pipe
houston92 is offline
post #57 of 65 Old 02-18-2013, 09:29 AM Thread Starter
GrandPuba
Pick n Pull... But this is the first WJ I've seen recently. 4 yards in the area, and only one and by now its been thoroughly molested...
post #58 of 65 Old 02-18-2013, 09:30 AM Thread Starter
GrandPuba
North yard... Forgot you were local.
post #59 of 65 Old 02-18-2013, 11:42 AM
cykaaro
I find going on a regular basis as well as getting to know someone who works there definitely helps. Get typically better prices than most. Have a few to I go to here, but two typically have WJ's there. One has about 10 right now, but yes, they get pretty picked over.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #60 of 65 Old 02-18-2013, 11:18 PM Thread Starter
GrandPuba
Put in an OEM hatch glass today...wouldn't ya know...it fits exactly the way it should, and closes very firmly. That aftermarket piece of junk didn't even touch the gasket on the sides. Also put in my trailer harness. Plugged right in to the factory harness, and even works. That made me happy.
