Was that a niner in there? Are we talking on walkie talkies? My new build thread
#16 | |
Mongo-fabbed
Interior:
![]() ![]() ![]() ![]() Needs a little cleaning. It has Catch-All mats in the front and trunk, and a spare set of rubber mats as well. I'm not sure who put the stereo in, but in the process, they bypassed the soundbar. I'm going to have to look into that and see if I can wire it back in.
Think Twice Garage "I guess I'd just run it?" |
#17 |
5.9,242,4.56,Aussies x 2
Welcome to the club. you interior looks just like mine, LESS the mud!!!
Military Jeepers.Com. Jeep Forum member since 2/2002 5Nine=No replacement for Displacement
#18 | |
Mongo-fabbed
I tried to switch my frankenstein intake from the Laredo today . . . no luck. I was also going to swap my Silverstar Ultra's from one to the other and put the first set of regular Silverstars in the Laredo, but I didn't have all my spare bulbs here. Gotta get them out of my storage unit sometime this week.
#19 |
Mongo-fabbed
Washed it tonight, still need pictures of it next to the old one:
#20 |
Mongo-fabbed
It's up on jackstands right now waiting for my other 44a . . . I'll try to shoot a couple pictures in the process.
#21 |
Infowars.com
That is a great looking jeep.
What is it about Ron Paul?
#22 |
Mongo-fabbed
Thank you sir!
![]() I'm really glad I got the silver (platnium?). It's my favorite color out of the 5.9's.
#23 |
Mongo-fabbed
Tonight I pulled the shocks, upper control arms, sway bar end links, brakes, brake lines, but couldn't get the ******* track bar bolt out. Plan is to disconnect the lower control arms and driveshaft and drop it and cut the bolt while it's on the ground away from the gas tank. I'd like to know the reasoning behind using a torx head here. Does this seem like the best way to take care of the problem? It's what I did on the 44a I'm swapping in.
#24 |
i love that color!!!
#25 |
Mongo-fabbed
#26 |
Mongo-fabbed
Got the ZJ back on Friday . . . I had taken it to a shop earlier in the week to pull the bolt that I broke in the 44a yoke and free up the ebrake. In the process of freeing up the ebrake, they found that the screw that holds the crosspin in with the spider gears had sheared off and was in the diff oil. This happened on the way up to the shop, because the rear end was fine prior to me filling it with fluid. So $750 later, I have a new set of Yukon spider gears, axle seals, ebrake shoes, U joint straps, and a new pinion seal. Prior to getting the axle work done, I had installed my Stillen rotors on the rear and my JKS adjustable track bar. I also ordered my SCT tuner today, which should add more than a few ponies under the hood. I'll get pictures of the rotors/rear end later.
#27 |
Mongo-fabbed
SCT Tune is installed along with 180 degree thermostat.
Quick vid, first revs are up to 2k or so and last hit 3500-4k. Hopefully just moisture coming out of the exhaust, as it hasn't run for a couple days. ![]()
#28 |
That is sweet. Awesome find! Can't wait to see it when everything's finished.
#29 |
wow. thats stock exhaust?
#30 |
Mongo-fabbed
Yup, stock exhaust. The tune makes it sound mean.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
