Newb and his WJ - Page 6 - JeepForum.com
post #76 of 206 Old 04-25-2013, 06:25 PM
xrunndonex
1994 ZJ
Originally Posted by Newfive View Post
Right now it would just blow off.. this was test fit... think ubolts... stainless ones should work...
Should have it cleaned, painted and mounted by sunday... 30 days I shall be in Texas... uggg... still tons to do... Trans flush... gear oils... ujoints.
Paint it red
xrunndonex is offline
post #77 of 206 Old 04-25-2013, 06:46 PM Thread Starter
Newfive
Originally Posted by xrunndonex View Post
Paint it red
I thought about rear one being red.... dark red???? I did change all my lights inside to red...hummmm btw its not really painted... photoshop
Newfive is offline
post #78 of 206 Old 05-01-2013, 08:23 PM Thread Starter
Newfive
Update... cargo rack is about finished... all tacked and welded... went through and clean joints smooth to touch... primed
Mounted light brackets... used I bolt on backside...another place to attach tie downs too.
It is ready to paint... too bad weather isn't... rain...humidity is too high... paint wont stick correctly.... maybe tomorrow...
Time is running out.... MAY 1.... 24 days left.....getting whining noise from alternator...might pick up a spare from yard to put in milk crate
Newfive is offline
post #79 of 206 Old 05-01-2013, 08:55 PM Thread Starter
Newfive
Oh yeah... replaced front rotors... found that dumb-arse who previously owned this WJ had used a bolt in place of one of the slide pins.... had to get caliper bracket from yard with pins... oh and the WJ I got it from had brand new brakes on it... FREEbee.... brakes must have just been put on before scrapping it...not even scuff marks across face yet.
Picked up new alarm collar for entry key... old one sometimes works... sometimes doesn't.
Got an AC outlet for rear cargo area too....
Changed all interior lights to RED LED along with dash lights... video soon...
Snagged a multi-blinker (OEM $57) from yard.... when I purchased a key-fob ($5) he said keep will get reprogrammed when I get new key made.
Newfive is offline
post #80 of 206 Old 05-05-2013, 08:16 AM Thread Starter
Newfive
Well the weather cleared enough to get rack painted and clear coated... wired and switches in.... also the multi-wire run to back third brake light. I mounted 6 switches and only using 2 right now... guess that mean more things to add later
After mounting... I dont like it.... when I get back from road trip... MOD that thing... gonna make her fatter... hang off the sides... looks too skinny.
Drop suggestions if you want.
Newfive is offline
post #81 of 206 Old 05-09-2013, 07:36 PM Thread Starter
Newfive
Well I tried and tried to clean the windshield, used razorblades on it.. rubbing compound... wiper streaks and small pits all over it... so time to replace it.
called about 20 places ranging from $175 (tomorrow) to $280 (safe-light)... called Low Price Auto Glass on W. Colonial Dr. http://www.lpautoglassorlando.com/ ($175.08 with tax) told me between 12pm - 2pm... he called about 1:30pm... was done at 1:50pm.... COOL nice clean windshield.
Decided to further the look.. removed pinstripe on both sides and decals... will let dry for two days then use 3M decal glue to put back on... not looking forward to the "Grand Cherokee" on doors though Thought about doing the "Laredo" in OEM paint but did one letter and decided NO....wiped off paint and retouched with black and flat...
Newfive is offline
post #82 of 206 Old 05-09-2013, 08:18 PM
ZB_WJ
IMO that rack looks fine. If you were able
to move the two front lights on the sides and get some bigger ones up front. It may widen it out. Plus you can use the extra switches
Ammo cans on the side might be cool. Don't Really know what style your going for, but some cans that could go on and be removed would be pretty handy.
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #83 of 206 Old 05-12-2013, 12:41 PM Thread Starter
Newfive
I was playing with my REAR end today... finished that and move to the middle (transfer case) then it all went to the front end.... couple pics sorry camera phone... not use to it.. too small not like my Canon...
Need to get heater hoses and upper/lower radiator hoses and then put coolant in.... all fluids will have been changed but brake... will be putting new lines on when I get back....
Newfive is offline
post #84 of 206 Old 05-14-2013, 06:00 PM Thread Starter
Newfive
Well I put spares on front to see if vibration, I have two spare tires, but still there....
next....
Removed front driveshaft and take for testdrive.....
COOL BEANS... no vibration.....
went to driveshaft shop behind where I use to work....
$350-$400 and backlog of a week....
Snizzle me dizzle.....
Back to the house to grab the BAG!!!!.... of to the yards I GOOOOOOOO
First yard... NO shafts... all either gone or cut..... but found "Limited Cluster"
dratz... next
Second yard... $2 admin feeeeee... forkers....
Found Driveshaft.... and low and behold... short front shaft just laying on ground beside WJ I am getting front shaft from.... (thanky you meself).... Muhaahaaa....
Total cost $100 for both shafts and cluster.... now off to the driveway to remove rust... prime...paint... and install..
Newfive is offline
post #85 of 206 Old 05-16-2013, 05:32 AM Thread Starter
Newfive
Well the vibration from 45 - 55 is gone... now I have wobble type vibration at 55-60.... think I already know what this is.... when I did CV boots the short shaft CV was worn... had to file some sharp edges...
Badabing... that is why I grabbed that short shaft while at the yard.... that is todays goal... yesterday I did rear driveshaft.... put in "De Best" MOOG Ujoints I could get.. SPPI (sand, prime, paint, intsall) and took it for a drive...
I already replaced rotors.... dont think axles are bent... looked pretty straight when I pulled them for boots...really want to upgrade to Ujoints instead of those CV....maybe after I get back.
Newfive is offline
post #86 of 206 Old 05-18-2013, 06:42 PM Thread Starter
Newfive
Took WJ to local tire shop... had tired rebalanced... everything is smooth again...
Washed, waxed and getting everything ready for trip... went to Mt Dora flea market picked up hitch pin (need to drill out for lock), picked up some bungees, also some para cord for tying down items... almost time to boogie.
Other roommate wants to go but someone has to stay and take care of this place....not a total fun thing... the drive will be tough
Newfive is offline
post #87 of 206 Old 05-20-2013, 05:39 PM Thread Starter
Newfive
Well... it rained here... NW Orange county received about 7" of rain in one hour...
I watched them mow the retention pond this morning... its now over 5' deep... not a small pond either.... here is 2 of 2 videos with my new Gallaxy SII yeah not new to anyone else but.. first cell I have had in 5 years... and it shoots great video....Uploading part one right now...
Part1 https://www.youtube.com/watch?v=lJM4c4Y5p1Q
Part2 https://www.youtube.com/watch?v=WUbDDiBdCtU
Just quick movies...
Newfive is offline
post #88 of 206 Old 05-20-2013, 07:22 PM
4x4Jeep
holy **** that's a lot of water; never seen streets around here flood like that. today it rained for like 30 minutes lightly with some thunder. lucky
Build -
SOLD
4x4Jeep is offline
post #89 of 206 Old 05-20-2013, 07:43 PM
ZB_WJ
That's one way to wash all the mud off the bottom
ZB_WJ is offline
post #90 of 206 Old 05-24-2013, 09:43 PM Thread Starter
Newfive
Uploading some videos to Youtube channel.... Long *** drive to Texas.... next stop from here is Georgia....not the greatest but some short clips.... more to come more traveling and more fun....
http://www.youtube.com/user/Newfive
Newfive is offline
