Newb and his WJ - Page 3 - JeepForum.com
post #31 of 206 Old 03-15-2013, 05:32 PM Thread Starter
Newfive
Seat Frame repair
oK. Drivers seat was little woopsy and bouncy when you would take off or hit the brakes...
I decided to look into it... this is what I found...repair...reassembled.
Driver Seat Frame Repair
Newfive is offline
post #32 of 206 Old 03-15-2013, 05:38 PM
DealUSAF
You could start a build thread if you're planning a lift or any big projects
98 ZJ 5.9 DD 242 t-case swap
99 WJ 4.0 3" IROR 265/75s
93 ZJ 4.0--Sold
DealUSAF is offline
post #33 of 206 Old 03-15-2013, 05:40 PM Thread Starter
Newfive
Continued Pictures are pretty self explanatory... any questions please ask... Assembly is just reverse of this...
Oh you don't need bull-nose pliers.. just take two pair of pliers and twist to clear steel frame wire.. then use same to close them up.
Be sure to pull seat cover far enough on sides when putting back together this will make attaching the clips and rails easier.
Yes, I shampooed where seat was... TIS ALL CLEAN....Shot little paint on just to keep rust off and add to the Jeep Glamor
Newfive is offline
post #34 of 206 Old 03-16-2013, 08:20 PM Thread Starter
Newfive
Just clean outside up today... wire bushed rims... dont think they have ever been cleaned... buffed the paint... dont think that has ever been done either... put some wax on her.... detailed everything outside... enjoyed nice warm day for once down here.
Tomorrow.... Corn Beef (in crock pot now) and Cabbage.... more to come next week.
Newfive is offline
post #35 of 206 Old 03-16-2013, 09:23 PM
4x4Jeep
subscribed...you live on the east side, since you mentioned J&B..i literally live a mile from there..nice to see another local WJ owner
Build -
SOLD
4x4Jeep is offline
post #36 of 206 Old 03-17-2013, 09:37 AM Thread Starter
Newfive
Actually I am in Orange County but near Lockhart... NW side
Newfive is offline
post #37 of 206 Old 03-18-2013, 05:24 PM Thread Starter
Newfive
Went for a drive today... ended up being short one...
Engine not running all the great... did the 3t key turn found few codes... off to the store I go... Ignition Coil pack... and something to stop the puddling under the truck that just started.... yeah a water pump....
so new coils, new water pump... need to get new hoses all the way around next... then I will put coolant in the engine once I know I am not going to have to tear it down anytime soon.
WJ is running so much better now... EMG is reading back in the 14s and 15s again... was stuck on 9s and 10s... lot more pep in WJ peddle also.... Disconnected battery for 15min and took for another drive... checked for codes... "done".... saweet
NEXT!
Newfive is offline
post #38 of 206 Old 03-20-2013, 04:50 PM Thread Starter
Newfive
Got a box of goodies today... BALL JOINTS... all of them... guess a detailed replacement is in order?
new thread or stick with this one? I will be doing these either tomorrow or this weekend.
I have to get truck ready for 2000 mile road trip from Otown to Texas... and I don't want any "Houston, I think we have a problem"... Still have wheel bearings and axle seals left... I have been thinking about new injectors also.
Newfive is offline
post #39 of 206 Old 03-20-2013, 04:53 PM Thread Starter
Newfive
Oh yeah... found half sheet of .91 aluminum 72"x27" on CL for $30... have to make a larger sluice... and was thinking my frame rockers are going to needs some tlc soon and I need to bend some steel for that too....
Maybe I will be making a DIY brake... say 30" or 40" long....
Newfive is offline
post #40 of 206 Old 03-20-2013, 05:59 PM
4x4Jeep
i say keep it all in one thread, that's what a 'build thread' is for right? unless you make a specific writeup on how to do something then you can do both..
Build -
SOLD
4x4Jeep is offline
post #41 of 206 Old 03-20-2013, 06:09 PM
narnwv
narnwv's Avatar
since this has turned into a build thread, I'm moving it to Grand General.
~Aaron
narnwv is offline
post #42 of 206 Old 03-27-2013, 11:23 PM Thread Starter
Newfive
I will be adding some more photos and updates in next day or so... must take photos... forgot to take them as I was working.. twas COLD as fork this past week.
I didnt want to drag out my Canon with cold fingers... cost too much to oops!
Newfive is offline
post #43 of 206 Old 03-27-2013, 11:28 PM Thread Starter
Newfive
I replaced lifters but still have a ticking noise.. comes and goes most when cold so going to put some Restore 6 cylinder in and see if that quiets it down.. if so I will be replacing mains and rod bearings... if it doesnt I already sent email out to National Cylinder Head for a rebuild of the I6... May is closing in... have to get WJ road worthy and trust worthy for a 2000 mile road trip.
Newfive is offline
post #44 of 206 Old 03-28-2013, 04:42 PM Thread Starter
Newfive
Ok starting with injectors... first are old Jeep injectors... then shot of the FORD injectors installed with factory clips in rail...nice can of Restore to see if it quiets dieseling down... which it did.
Next we have the seat memory, not quit done with that but in progress.
Then we have the PAIN in the ARSE ball joints... top, bottom, down bar, cross bar... King ball joints were a pain... kit I rented from Advance didnt have right sizes for stock.. they were larger then new ones.
Newfive is offline
post #45 of 206 Old 03-28-2013, 04:45 PM Thread Starter
Newfive
Painted handle and yard wiper arm with lifter...
More to come over next week... working on grill and few other things... weather needs to stay nice... set a record cold today 42... record was 51 in 1955
Newfive is offline
