New to Jeeps - First WJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > New to Jeeps - First WJ
Eliminate Hood Flutter!!!Thursday Savings BlastIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-17-2014, 10:04 AM   #1
91Talon
Just dropping a quick line to say Hi to all. Just traded for my first Jeep. It's not perfect, but shouldn't need a whole lot to be where I want it.
Hopefully I can post an image of it on here. If not, I will when I get up to the number of required posts.
It has the 4.7 and the QT II. It also has a 2" lift. Really not too sure what else is there, but I'll figure it all out soon enough.
Will probably troll around for a while and learn as much as I can.
91Talon is offline   Reply With Quote Quick reply to this message
Unread 10-11-2014, 08:50 AM   #2
91Talon
It leaks on the driver's side, when it rains. Going to try and figure that one out.
Unread 10-12-2014, 05:34 AM   #3
NTH
Nice looking wj. Congrats!!
Also take a look in your spare tire area when it rains. Water tends to collect there.
____________________________
1998 Grand Cherokee Laredo 4x4 // 5.2L // D30/44RE/NP249/D44a //
NTH is offline   Reply With Quote Quick reply to this message
Unread 10-12-2014, 07:39 AM   #4
91Talon
Thanks. Spare tire area looks dry. I found the source of the leak. That blue tube that drains the sunroof has a crack in it or something, when it curves behind the dash. Probably just going to buy some tube from the hardware store and replace the entire thing.
Then I get to move on to figure out why the wipers don't turn off, even when the car is off. I'm thinking it has something to do with the leak, since the water comes out right by the fuse block.
