Neewbie Jeep's Thread 1996 Grand Cherokee Limited - JeepForum.com
post #1 of 11 Old 03-30-2013, 07:51 AM Thread Starter
Meik
Hi all,
So I have bought a:
Make: JEEP
Model: Grand Cherokee LTD AUTO
Fuel Type: Petrol / LPG
Engine Size: 3960 CC
Was a blind buy of ebay, but I like it
So I decided to jack it up and take a look at the brakes and hub etc as I have a droning noise on the Front Left Passenger side..
I have up-loaded some images, It looks like the rear drivers side pads are wearing unevenly... would you change pads? disc's? both? or leave?
  • At the front you can see the rubber housing behind the wheels are also perished,
  • Other than that the hand break is naff and I am undecided as to changing the whole things it trying to adjust... for it to apply it needs to be pulled right up.
  • Whats the best thickness for disc's on jeeps before they need changing?
My Jeep.jpg   front drivers side.jpg   front drivers side 2.jpg   front drivers side 3.jpg   Front passenger side.jpg
Meik is offline
post #2 of 11 Old 03-30-2013, 09:13 AM
Scopez
1994 ZJ
The rubber boot behind the wheel is the CV axle, they aren't too terribly expensive to replace. I recommend checking the other side for a torn boot also.
Also, for preventative maintenance, I'd replace both sides at once.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #3 of 11 Old 04-01-2013, 01:09 AM Thread Starter
Meik
Ok so I'm going to start with the hand brake, is there any photo guides on how to do this?
Meik is offline
post #4 of 11 Old 04-01-2013, 01:13 AM
xrunndonex
1994 ZJ
Is worry about the CVs first.
xrunndonex is offline
post #5 of 11 Old 04-01-2013, 01:28 AM Thread Starter
Meik
I have ordered some boots to replace them
Meik is offline
post #6 of 11 Old 04-01-2013, 01:39 AM
xrunndonex
1994 ZJ
Ok bro. I normally replace my rotors everyother time I change my brakes btw. I Probly don't need to but still do.
post #7 of 11 Old 04-01-2013, 01:46 AM Thread Starter
Meik
Cool ta, the last picture I posted is my back rear brake which i think looks to be wearing slightly un evenly what do you think?
Meik is offline
post #8 of 11 Old 04-01-2013, 03:27 AM
xrunndonex
1994 ZJ
Yea, the outer is defiantly wearing faster then the inner side.
post #9 of 11 Old 04-01-2013, 09:39 AM
Scopez
1994 ZJ
Hope you're saving those old rotors haha. I just turn mine, normally replace them every 4-5 brake changes.
Scopez is offline
post #10 of 11 Old 04-04-2013, 10:40 AM Thread Starter
Meik
Used a 12 volt pump to pump up my tyres and it drained the battery.... Yet this never happened on other cars I've had... Yet the battery charge sees fine in general just not when using gadgets.
Meik is offline
post #11 of 11 Old 04-13-2013, 06:03 AM Thread Starter
Meik
One new battery installed , tested it and it's reading 12.6 volts, disconnected the positive cable and checked for drain didn't read anything so that's good hopeful,y was just a duff battery.
Meik is offline
