Need Some Advice and Help - Page 2 - JeepForum.com
post #16 of 22 Old 06-11-2010, 08:59 AM Thread Starter
KillaJeep4569
2006 WK
Originally Posted by Thelt View Post
I took my 98 ZJ on the beach at Cape Hatteras a while back. It did great even with stock tires and no lift. Just air your tires down to 20psi and you will be fine. No if you just want a lift and bigger tires then go ahead.
I believe it has Bigger tires on it. I think my wife said 240/70
The spare was 250. So IDK if they are bigger or smaller or whatever. This is my First Jeep.
KillaJeep4569 is offline
post #17 of 22 Old 06-11-2010, 09:08 AM
soul_Less
1994 ZJ
I think your tires are wider then stock, not taller I believe. Your stockers were 225/70.
soul_Less is offline
post #18 of 22 Old 06-11-2010, 09:12 AM Thread Starter
KillaJeep4569
2006 WK
Thank you, So Wider tires, Is that always good for the Sand??? And if I have this Rear Bearing Issue, would it be ok to drive for a long period of time???? Drive on the beach?? Or what can you tell me. Thank you
post #19 of 22 Old 06-11-2010, 09:40 AM
soul_Less
1994 ZJ
Well, depends on what kind of tires you have. I've never played in the sand before, but I've heard mud tires suck in the sand.
And I won't say don't drive around, but get your rear bearing issue looked at as soon as you can
post #20 of 22 Old 06-11-2010, 09:42 AM Thread Starter
KillaJeep4569
2006 WK
How bad is that issue?? will it mess me up royally? need more info on this rear bearing issue.
post #21 of 22 Old 06-11-2010, 10:04 AM
K9-Handler
2005 WK
Well, neither of those numbers is a legitimate tire size. The width would have to be 225, 235, 245, 255, 265, etc.
Stock was 225 as mentioned by an earlier poster. A typical upgrade would be 235. You'll need to read the sidewall and post what you have.
But to state the obvious, yes, wider is better when dealing with sand. That said, the difference between a 225 and 235 is not enough that you would notice. Airing down would make much more of a difference than going up one tire size.
'05 WK Hemi; Dark Khaki
US Army, Viet Nam '70 - '71.
Learned to drive in a '53 Willys Wagon. 2nd vehicle: 1950 Jeepster.
K9-Handler is offline
post #22 of 22 Old 06-11-2010, 10:06 AM Thread Starter
KillaJeep4569
2006 WK
What about the Rear Bearing Issue???
Advice for WJ SWagner2806 WJ Grand Cherokee Forum 2 04-23-2010 02:28 PM
I need some help and advice on what to do...... bensminger2003 ZJ Grand Cherokee Forum 21 04-21-2010 05:11 PM
ZJ advice..XJ vs ZJ? jeepdad56 ZJ Grand Cherokee Forum 35 01-10-2009 11:29 AM
New ZJ need Some Advice ONX ZJ Grand Cherokee Forum 25 05-03-2007 03:23 PM
96 GC, Need Advice, HELP sjns ZJ Grand Cherokee Forum 4 02-04-2004 05:20 AM
