NarnWV's super slow build thread - Page 44 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > NarnWV's super slow build thread
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 09-26-2013, 08:11 PM   #646
gcjeeping
gcjeeping's Avatar
This attachment?
__________________________________________________ _________
-GCJEEPING's build/mod thread-IT'S A GREEN THING...
gcjeeping is offline   Reply With Quote Quick reply to this message
Unread 09-27-2013, 09:02 AM   #647
wj4play
Originally Posted by gcjeeping
This attachment?
I did see that one but did not see any typo's .... Unless you were referring to the loooong conversation via text and typing on a phone which SUX in itself
Sorry just was expecting typos from typing on the phone ...
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline   Reply With Quote Quick reply to this message
Unread 09-27-2013, 11:31 PM   #648
Justin_WJ
It's setting in my garage floor and it's $200.....only 70,000 miles on if and has all new sensors....if you remember....you said that what I was asking is twice what your junkyard was asking, thus, why you made a trip to Ohio. I did have a buyer and he backed out.
2000 WJ Limited, 4inch RC X, 242 T-case swap, 33x12.50 STT's, 15x8 D window wheels with 3.75 BS, JKS ADJ. Tracbar, T-case armor, Custom front winch bumper, Smittybilt XRC 8, 4.56's Extended Rola Rack w/Harbor Freight 6" lights, and always muddy :)
Justin_WJ is offline   Reply With Quote Quick reply to this message
Unread 09-29-2013, 07:10 PM   #649
narnwv
narnwv's Avatar
No worries. I have one in there now with 86k, all new external Mopar sensors, plus a new Mopar Shift Solenoid (the updated one, with the newer cam plate). I also now have a 242HD in there, since the 242LD I had in there got it's input shaft/planetary gear setup jacked up in the whole slam-into-reverse mess.
My last issue is that apparently during the flood, when I wasn't worried about the Jeep, my front axle filled with water. Didn't even think about that. Friday night I was over at the dealership using the Witech Pod and DRB III Emulator to re-program the transmission. With it in the air, I was getting grinding from the front axle while it was in drive. Pulled the front diff plug and 6 ounces of milkshake came out. :-/ I pumped the rest of the milkshake out and filled it back up with gear oil to limp it home. Didn't have time this weekend to do anything with it. I may be getting axles sooner than later.
~Aaron
narnwv is offline   Reply With Quote Quick reply to this message
Unread 09-29-2013, 07:12 PM   #650
narnwv
narnwv's Avatar
Nah, that's my signature when using the jeepforum app on my phone. On my tablet it says "typing on tablets sucks". (except my Surface Pro, since there's a real keyboard)
~Aaron
Unread 10-03-2013, 07:35 PM   #651
narnwv
narnwv's Avatar
Front pinion. What do you guys think? You think that might be binding while rolling down the road? There's no lateral movement, only the rotational play.
~Aaron
Unread 10-03-2013, 07:44 PM   #652
wj4play
Originally Posted by narnwv
Video Link: http://www.youtube.com/watch?v=-kSnglljuuY&feature=player_detailpage
It rubs the lotion on the gears ... Wait wrong thread
It needs lockouts
Unread 10-03-2013, 08:07 PM   #653
narnwv
narnwv's Avatar
I'm thinking vari-lock complete axle replacement. I'm also probably getting an Aussie ordered this weekend for the rear Remember the loose center pin when this mess started a few months ago? (I don't drive the Jeep much anymore)
~Aaron
Unread 10-13-2013, 07:08 PM   #654
narnwv
narnwv's Avatar
Haven't been able to drive much due to needing the innards of my front axle replaced, but I took it to the store a little while ago and got the P1767 AGAIN!!!!
This is after replacing with genuine Mopar parts:
-input speed sensor
-output speed sensor
-governor pressure transducer
-shift solenoid pack/range selector
-transmission relay
I'm lost on where to go next.
~Aaron
Unread 11-11-2013, 08:27 PM   #655
narnwv
narnwv's Avatar
I still haven't dealt with the transmission. I think I'm just going to tow it to the dealer and have them take a look.
I did get the Vari-Lock axle in yesterday though. I have tons of pictures of various projects and things I need to get uploaded. Work has been too fuggin' crazy the past couple of months to have any time, and we're finally getting stuff settled after the flood.
Holy chip! it's been a rough year.
~Aaron
Unread 11-21-2013, 06:27 PM   #656
narnwv
narnwv's Avatar
Dropped the Jeep off at the dealer two days ago. They called me today and said it had a "fried TCM, with possible other electrical issues"
~Aaron
Unread 11-21-2013, 07:49 PM   #657
wj4play
Ouch ... Wait didn't u replace that?
Sent from busted up iPhone
Unread 11-22-2013, 03:44 PM   #658
narnwv
narnwv's Avatar
Yup. I believe that I'm the one who fried them. We'll see. A refurbished w/lifetime warranty unit will be here early next week.
Typing on phones sucks.
~Aaron
Unread 11-23-2013, 06:57 PM   #659
narnwv
narnwv's Avatar
Ha!. Just because I forgot what it was, I looked it up and discovered if you google "45rfe p1767) this build thread is the 5th top result.
~Aaron
Unread 12-02-2013, 06:49 PM   #660
wj4play
So did ya get it fixed?
Saw you posted for a wiring harness for the tranny
