NarnWV's super slow build thread - Page 33 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > NarnWV's super slow build thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 10-23-2012, 08:40 PM   #481
ChrisHager
ChrisHager's Avatar
Congrats on the Cert! And I'm sure your wife will love that gift! :-)
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 10-23-2012, 08:45 PM   #482
Justin_WJ
Buy my wife some too Aaron
2000 WJ Limited, 4inch RC X, 242 T-case swap, 33x12.50 STT's, 15x8 D window wheels with 3.75 BS, JKS ADJ. Tracbar, T-case armor, Custom front winch bumper, Smittybilt XRC 8, 4.56's Extended Rola Rack w/Harbor Freight 6" lights, and always muddy :)
Justin_WJ is offline   Reply With Quote Quick reply to this message
Unread 11-04-2012, 08:23 AM   #483
narnwv
narnwv's Avatar
Been a long time since an update.
It looks like I'm going to have to just replace all the injectors. After fighting the misfires before on cyl 1 and 7, I'm now getting the 0300, 0304, 0308 codes, as well as 0155 (O2 sensor heater circuit). They come and go at random, but it's all too familiar operating-wise in how it's doing it. I'm actually thankful it's not the same cylinders as before, as that would lead me to believe there would be a gasket/head issue. I think at 262,000 miles some of the electrical parts are starting to show their age.
On a worse note, I noticed yesterday morning that there was a puddle of coolant on the ground directly under my crank pulley. It was about the size of a pancake, and when I popped the hood, I could see wetness on one side of the water pump. Thankfully when I replaced it May 2011, I bought the one with a lifetime warranty. I'm also hoping that it's been the cause of my moisture around the bottom of the block, and the point of entry for the air that keeps getting in the system.
So, on a brisk November Sunday, I'm going to change out the water pump on this beast and keep my fingers crossed that it's what's been letting air in the system. (rush of water on first startup, got way worse when the temps dropped)
I've developed a clunk in one of my control arms, but re-torquing the bolts takes care of it for a few days. I think the bolts need replacing. I'm going to replace them all when I do long arms in a few months.
All-in-all she's been doing pretty good.
~Aaron
narnwv is offline   Reply With Quote Quick reply to this message
Unread 11-04-2012, 03:42 PM   #484
bluedragon436
Awesome build writeup... I'm thinking of picking up a 99 WJ shortly and will be looking to go the same way you did with the 4" X-flex lift, JK Moabs and 32's.. Look forward to seeing your build as it progresses. Congrats on the new job, I'll be looking at hopefully getting into IT after some more time in the USAF. And by the way I feel your pain, this message typed from my Asus Transformer.
bluedragon436 is offline   Reply With Quote Quick reply to this message
Unread 11-08-2012, 07:37 PM   #485
narnwv
narnwv's Avatar
I changed my water pump last weekend, and no more leak. (yay!) However, every now and then I still hear a rush of water in the dash. (not nearly as loud/hard as before, not really ever in the mornings either). Not sure what that's all about.
On another note, I came out of the grocery store to a guy with a flashlight kneeling at the back of my Jeep. I said "can I help you with something! ?" He said "your Jeep is awesome, I've got one just like it, and wanted to see what size tires those are". I asked him if he was on here, and he said yeah. I introduced myself with my forum name and told him I was a moderator and to look me up. He said he has a 2002 Slate WJ with RC 4" (non x-series).
I'm going to order the sliders at the end of the month I think. I'm going to talk to my buddy that helped (mainly) built my spare tire carrier and see what he can do first.
~Aaron
Unread 11-08-2012, 07:37 PM   #486
narnwv
narnwv's Avatar
^^ 5000th post.
~Aaron
Unread 11-08-2012, 10:28 PM   #487
SnowLeopard
I've been wondering, did you ever figure out what was going on with your Hankook tires? Man do I miss mine. I have what came on the 4Runner, some store brand AT called Bigfoot or somesuch. They're all right, but not nearly as grippy as the Hankooks. At least they're not wearing too fast.
Yes, it snows in Texas.
SnowLeopard is offline   Reply With Quote Quick reply to this message
Unread 11-29-2012, 07:49 AM   #488
narnwv
narnwv's Avatar
I need those sliders. In a hurry, I hit a Damn pole at the gas station this morning. :/
Sent from the ISS using laser beams.
~Aaron
Unread 11-29-2012, 10:54 AM   #489
ChrisHager
ChrisHager's Avatar
Those things come out of nowhere - especially when opening your door. Poof - magical red pole grinning at you.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 11-29-2012, 11:43 AM   #490
billzcat1
Chicken in a Turkey Suit
2003 WJ
The best time to add armor is after the damage has happened! Oh wait...
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 11-29-2012, 03:21 PM   #491
PhantomWJ
2003 WJ
I recently hsd same issues. It was throwing codes everday on way to work and would go into limp mode.
Without a thermostat I knew it was running rich specially now that it is winter, so I put it back on.
I also replaced my plugs and coil pack; voila!
PhantomWJ is offline   Reply With Quote Quick reply to this message
Unread 12-17-2012, 07:58 PM   #492
narnwv
narnwv's Avatar
I still haven't done **** about the injectors. The crap idle comes and goes. New job + two kids can wear you down quickly. I've finally got everything back on track, now that I've finally got in the groove of things at the new company. (no JF during the day though )
First of the year:
-injectors
-putting the H.O. cams + intake in
-sliders
-long arms
-belly skid.
Gonna get started on it all after my 90-day bonus 2nd week of January. Got a nice Christmas bonus (decent amount of $ and a Windows 8 tablet), but we decided to treat ourselves to some frivolous xmas spending on ourselves.
~Aaron
Unread 01-01-2013, 12:28 PM   #493
narnwv
narnwv's Avatar
Happy new year to all those who are following this thread. It's going to get exciting in here over the next few months.
~Aaron
Unread 01-01-2013, 01:08 PM   #494
Cnolenwj
Happy new year!
Sounds like you have big plans, I'll be watching.
2000 wj limited, 4" IRO, long armed front.
Build thread- [url]http://www.jeepforum.com/forum/f197/cnolens-2000-wj-build-1195835/[/url]
North Texas Grands- [url]http://www.jeepforum.com/forum/f348/north-texas-grands-1323367/[/url]
Grand Slam Texas- [url]http://www.jeepforum.com/forum/f197/grand-slam-texas-1419143/[/url]
Grand Slam Texas Group- [url]http://m.facebook.com/?_rdr#!/groups/173929869420792?ref=bookmark&__user=100000454207551[/url]
Cnolenwj is offline   Reply With Quote Quick reply to this message
Unread 01-01-2013, 07:11 PM   #495
Justin_WJ
Can't wait to see the progress Aaron! My Jeep will be gettin a lil love come tax time as well
