NarnWV's super slow build thread - Page 20 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > NarnWV's super slow build thread
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 06-27-2012, 07:18 AM   #286
wj4play
Originally Posted by narnwv View Post
Condenser is out. I managed to get it out without removing the header panel.
I had to take a smoke break and wait for the Liquid Wrench to soak into the hood release bolts.
Look how wavey, not to mention the dent in the right side of it.
Attachment 422469
Held up at the evening sun.
Attachment 422470
Back Side
Attachment 422471
No condenser
Attachment 422472
Mud still in the radiator :/
Attachment 422475
Sent from my Atari 2600 using JeepForum App
How in the Hell did you get it SO wavy.... car crusher or trying to drive up the empire state building like the blues brothers????
wj4play is offline   Reply With Quote Quick reply to this message
Unread 06-27-2012, 07:23 AM   #287
HVACNY
HVACNY's Avatar
2013 WK
It took 95% of 24 ounces (2x12oz cans), so there couldn't be much propane in there...
I do plan to watch it closely.
Oh ok i interpreted it wrong then,i thought it was 2/3 134a to 1/3 propane.Your ratios are fine my man.
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline   Reply With Quote Quick reply to this message
Unread 06-27-2012, 07:57 AM   #288
narnwv
narnwv's Avatar
Originally Posted by wj4play View Post
ok im sold on the propane
Still overheating?
do a lot of research before hand, watch plenty of youtube videos. the only reason I knew to use it, and felt confident in using it is that my boss (IT company) used to be an HVAC guy, and he knows waaaayyy more than I do, and did it to his.
No idea on the overheating yet. Didn't get done until 9ish last night, but I did take it on the interstate on the way home. The temp stayed at 205, not 210-212 like it has been. Cleaning that mud out of the radiator, and having a condenser that isn't stopped up HAS to help. I need to get the shroud finished too, so I can pull air across the whole thing instead of just 70% of it.
I did get the 3 CEL codes again last night (300,302,307) I think I'm going to buy a couple coil packs on the way to work, swap them out and see what happens.
~Aaron
narnwv is offline   Reply With Quote Quick reply to this message
Unread 06-27-2012, 07:58 AM   #289
narnwv
narnwv's Avatar
You can see the dent on the right side of the condenser, I'm sure that's from a wreck. Who knows how many wrecks this has been in.
~Aaron
Unread 06-27-2012, 07:58 AM   #290
narnwv
narnwv's Avatar
~Aaron
Unread 06-27-2012, 08:58 AM   #291
narnwv
narnwv's Avatar
70 mph, 75 degrees outside
It hit 212 climbing a hill.
Let's see how it goes when it gets hotter out.
~Aaron
Unread 06-27-2012, 09:49 AM   #292
dzachareas
I replaced my temp sending switch last night and all appears to be well this morning. I'll know for sure when I'm driving home, when it's warmer outside and I get to UP the big hill that I usually gun it on instead of coasting down it. Other places where I would usually get warm, I stayed below 210 on. I'm hopeful that my temperature was just being read incorrectly, but I doubt it. We'll see.
I'm going to have to try that propane trick, thanks Narn! What is that app that you're running on your tablet? I may have to look into that.
Whether or not I'm running lean is still to be determined, my "buddy" is being an ****ole, but the software and cable is only $30. If I can just remember what it was called, I'll buy it and check my fuel mixture myself.
dzachareas is offline   Reply With Quote Quick reply to this message
Unread 06-27-2012, 09:51 AM   #293
narnwv
narnwv's Avatar
Torque for Android. It's free, and there's a $5 paid version as well. I use the free version.
I bought two coil packs this morning, and may go change them out. I really hope they get rid of those misfire codes I've been getting on and off.
~Aaron
Unread 06-27-2012, 10:10 AM   #294
dzachareas
Good luck buddy, I hope the coil packs are the issue and your problems are solved Thanks for the info on Torque.
Unread 06-27-2012, 10:38 AM   #295
mrJ
2002 KJ Liberty
i had misfires on 3 and 8 rcently. replaced all plugs and it went away. good luck with the misfire, it sucks when she's not running right
those temps are pretty normal for me when i'm on the trails in 90*+ down here in Florida. this was on the way to the offroad park in the morning. temp was in the 80's and this was after maybe an hour of already running at that speed.
Build In Progress...[url]http://www.jeepforum.com/forum/f22/03-wj-limited-build-she-needs-name-1113549/[/url]
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline   Reply With Quote Quick reply to this message
Unread 06-27-2012, 10:43 AM   #296
narnwv
narnwv's Avatar
I slapped the coil packs in. Look at the difference. There's 2 different seals on the replacements, where there's zero on the existing.
And here's my temps while driving, when it's now 80 degrees out.
After replacing the coils, I was hoping my rough idle would magically go away, it didn't--which leads me to believe that my misfires are from injectors.
I reset the CEL and we'll see how it goes.
~Aaron
Unread 06-27-2012, 03:27 PM   #297
narnwv
narnwv's Avatar
it's 90 out now (ugh I hate the heat). I had to run to a client's place to take care of some things.
Sitting in traffic, it would fluctuate between 208 and 212 degrees. Once I jumped on the 4 lane, I gunned it up to 60 and it hit 217 pretty quickly. I didn't go far, so I can't say it will climb more than that. Once I came to a stop light, it dropped back to 210.8
I need to put some fuel in it and just go for a drive. I've got so much to do though.
~Aaron
Unread 06-27-2012, 03:29 PM   #298
narnwv
narnwv's Avatar
I also manually reset the CEL. My idle is still rough, so I'm sure the misfire codes will return, even with the new coils.
~Aaron
Unread 06-27-2012, 06:21 PM   #299
narnwv
narnwv's Avatar
well, looks like I'm going to take out a loan and get some Clayton long arms, since that's the only suspension worth having.....
(not)
~Aaron
Unread 06-28-2012, 06:59 AM   #300
narnwv
narnwv's Avatar
according to tracking, my oil analysis kit should reach Blackstone today. Please keep my Jeep (and wallet) in your thoughts and prayers (if you do that sort of thing)
~Aaron
