NarnWV's super slow build thread - Page 18 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > NarnWV's super slow build thread
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-25-2012, 07:35 PM   #256
dzachareas
Narn, we have to figure out this overheating issue. I just replace my e-fan motor, radiator, fan clutch, t-stat, hoses, water pump, I also have a 4.7, 192,700 miles. It's getting warm under load at speed as well. The only thing I haven't touched is the heater core. I'm at a loss. How did your shrowd come out? I'm thinking of doing the Taurus fan swap, as me e-fan still doesn't seem very effective even after a new motor from Advance. I ordered a kit from Blackstone today to get my oil tested, but I just changed my oil yesterday before I read your build thread (again :-) ). Let me know what your oil test says man, I'm a fart smeller but I'm clueless here...
dzachareas is offline   Reply With Quote Quick reply to this message
Unread 06-25-2012, 09:52 PM   #257
narnwv
narnwv's Avatar
not finished with the shroud yet. I did get some work done on it the other evening.
I got a CEL again this evening, while idling for a while (using it to jump my lawn tractor after fixing it, after a rollover)
Codes:
P0300--random misfire
P0302--Cylinder 2 misfire
P0307--Cylinder 7 misfire
I had these exact 3 codes a while back, which is why I changed (to inspect) my plugs. If you guys will recall, I got a P0302 a couple days after I changed plugs. Since the 2 misfires are on either side of the engine, that would almost rule out a head gasket, unless the front of one side and the rear of the other side is leaking.........
Ideas? someone mentioned that I could be running lean. I wonder if it's time for some injectors?
Anyway to properly test the coils with a multimeter or anything?
~Aaron
narnwv is offline   Reply With Quote Quick reply to this message
Unread 06-25-2012, 10:59 PM   #258
dzachareas
Mine smells like it's running lean, I'll have to pull my plugs and see if they look hot. They only have 5-10,000 miles on them, so I should be able to tell right away. I'm worried about the head gasket, but I'm not losing any coolant and my Jeep is running like a dream... Except I've developed a slightly rough idle since the cooling system work.
I don't know, maybe I got a crappy radiator cap from O'reilly's or the problem is my heater core. I think my heater core needs replaced anyway, I've been smelling a little coolant off and on in the cabin.
Can your tablet setup read your fuel mixture? If not, maybe I'll grab a setup that can read my fuel mixture too see if I'm running lean before I swap my injectors. I'm getting 19MPG though...
Unread 06-26-2012, 06:56 AM   #259
wj4play
Codes:
Do u have coil packs? Check those
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline   Reply With Quote Quick reply to this message
Unread 06-26-2012, 07:01 AM   #260
narnwv
narnwv's Avatar
I posted a few pages back, pictures of my plugs. What do you think about them?
Sent from my Atari 2600 using JeepForum App
~Aaron
Unread 06-26-2012, 07:03 AM   #261
narnwv
narnwv's Avatar
How do I go about checking them?
~Aaron
Unread 06-26-2012, 07:05 AM   #262
narnwv
narnwv's Avatar
It can read O2 sensor data, but I don't know how to decipher it.
~Aaron
Unread 06-26-2012, 07:09 AM   #263
wj4play
Old school was a ohm meter... U will have to look up resistances for the primary coil and secondary coil
Unread 06-26-2012, 09:47 AM   #264
dzachareas
If those plugs had 50,000 miles on them, I'd think they were fine, but since they were pretty new, I'd say that you might be running a little lean. But I may not be the best guy to ask. Just letting you know what I would think if I pulled mine out and they looked like that.
For your coil packs, you could always move them to different cylinders and see if your misfire codes follow to the new cylinder.
I have a buddy that has a setup that can read my fuel mapping, I'll see if he wants to take a ride with me and scan my mixture to see if I'm running lean
Unread 06-26-2012, 10:35 AM   #265
narnwv
narnwv's Avatar
My CEL went off by itself this morning. :/ I was hoping it would stay on, so I could move the coils to other plugs for testing.
Since none of the plugs look much different, and at the time of taking the picture I only had a misfire code for cylinder 2 (although I've had the Cyl 2 and Cyl 7 codes together before) Would you guys think it could be O2 sensors leaning out the whole thing? When I pulled the 8 plugs (~35-40k) they all 8 looked similar to each other, and of course in a bit worse shape than those posted earlier.
I didn't send my oil analysis out yesterday, going to today. (lazy. I work 80 feet from a UPS store)
~Aaron
Unread 06-26-2012, 11:16 AM   #266
dzachareas
I changed my O2 sensors last month with Mopar sensors (CEL came on). Come to think of it... That's when I started over heating. That is also when it started getting warm here too.
Unread 06-26-2012, 12:01 PM   #267
narnwv
narnwv's Avatar
Yay! The new condenser is here.
~Aaron
Unread 06-26-2012, 04:45 PM   #268
narnwv
narnwv's Avatar
Even though this project is for getting more air across the radiator, I'm sure that the a/c performance will increase from the new condenser. Someone asked me to take temp readings and I figured it wouldn't hurt to document everything anyway.
80 degrees ambient air, and I put the temp probe into the center vent. It's barely in the opening.
The blue part is maybe 2" long.
I'll be taking pictures and uploading from the phone as I go.
~Aaron
Unread 06-26-2012, 04:58 PM   #269
narnwv
narnwv's Avatar
Here you can see the waves in the condenser better.
More funky
Front End coming apart. I could do this in my sleep.
Here's what happens when you don't have the plastic front inner fenders in.*
~Aaron
Unread 06-26-2012, 05:40 PM   #270
narnwv
narnwv's Avatar
Condenser is out. I managed to get it out without removing the header panel.
I had to take a smoke break and wait for the Liquid Wrench to soak into the hood release bolts.
Look how wavey, not to mention the dent in the right side of it.
Held up at the evening sun.
Back Side
No condenser
Mud still in the radiator :/
~Aaron
