NarnWV's super slow build thread - Page 16 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > NarnWV's super slow build thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 06-19-2012, 08:13 PM   #226
wj4play
Originally Posted by Cnolenwj View Post
I'm following you closely, our problems are so similar. My condenser is pretty awful looking too.
One of us is bound to come across the cure eventually.
I hear you man, this problem is very frustrating.
if your condensors fins are bent up then that would restrict airflow as well......
wj4play is offline   Reply With Quote Quick reply to this message
Unread 06-19-2012, 08:34 PM   #227
narnwv
narnwv's Avatar
For anyone who cares, here's the transmission "cooler" that's in the right side tank of the radiator. It eases my mind a bit about the transmission doing the warming, but tenses me up a bit about how well it cools the transmission.
2012-06-19_20-46-05_961.jpg   2012-06-19_20-56-40_222.jpg   2012-06-19_20-56-58_718.jpg   2012-06-19_20-57-14_492.jpg
~Aaron
narnwv is offline   Reply With Quote Quick reply to this message
Unread 06-19-2012, 08:54 PM   #228
narnwv
narnwv's Avatar
mine are bent up pretty badly, with tons of little rocks in them. All the black coating is coming off through the back of it too (looks like hair coming out)
~Aaron
Unread 06-20-2012, 08:56 AM   #229
wj4play
IF that is the case then it probably the source of your problems. That would explain why at high speeds you have a lack of cooling due to NO air flow.
If you can swing it, pull the condensor, then go for a test drive. You will moslikly have to go to a JY to pick up a used one to replace it and then a shop will have to re charge your system. Be careful not to loose the Oring seals on it.
Unread 06-20-2012, 10:23 AM   #230
narnwv
narnwv's Avatar
I'm going to order a new one. They're less than $60 on both Rock Auto and Amazon. It seriously looks like it's been to war. I'll get pictures later.
I'll put new o-rings in it, and I can vacuum and recharge the system myself.
DISCLAIMER: DON'T DO THIS! I'm not responsible for any advice you take from here.
I usually run a bit of propane in the system, since it has a lower boiling point. In my WJ I run 3-4oz of propane, 20-21oz of R134a. Makes it nice and frosty inside. My boss runs "ES......" I'll have to ask for the name, but it has an even lower boiling point than propane. He can start his truck (Ram 1500, 4.7) on a 90 degree day, and within 2 minutes have the entire 4 door cab below 60 degrees.
~Aaron
Unread 06-20-2012, 02:02 PM   #231
wj4play
Propane huh... thats cool but how do you hook your gauges up to fill? my gauges only have 134a fittings and schrader valves?
Unread 06-20-2012, 02:27 PM   #232
narnwv
narnwv's Avatar
A custom fitting that goes from a "camp" style tank to the center hose on the manifold gauges. There is usually a R134a adapter that goes there, and this fits in it's place.
2012-06-20_15-14-37_221.jpg   2012-06-20_15-15-40_95.jpg   2012-06-20_15-15-59_734.jpg
~Aaron
Unread 06-20-2012, 02:35 PM   #233
narnwv
narnwv's Avatar
sorry for the giant pics, my cell phone is 8mp, and since it's encrypted, it's easier to upload directly from it.
~Aaron
Unread 06-20-2012, 02:45 PM   #234
narnwv
narnwv's Avatar
BTW, sitting in traffic today, my A/C all of a sudden got warm. I immediately looked at my gauges and saw 240 on the temp . Apparently my SPDT relay melted. It's rated for higher amperage than the other relay feeding it, and the fuse inline with the power. I temporarily pulled it out of the mix, but it made me realize how bad I need a failsafe for this setup. (maybe that's why the Ford Taurus' had parallel relays?)
~Aaron
Unread 06-20-2012, 03:32 PM   #235
HVACNY
HVACNY's Avatar
2013 WK
You can just buy a can of Duracool,its propane refrigerant,and it works well.
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline   Reply With Quote Quick reply to this message
Unread 06-20-2012, 03:43 PM   #236
narnwv
narnwv's Avatar
Buddy, this is West Virginia. We do things as ghetto as possible here.
~Aaron
Unread 06-20-2012, 04:05 PM   #237
narnwv
narnwv's Avatar
Just ordered a new condenser. Hopefully this will solve my 55mph+ over temp issues. http://www.amazon.com/gp/product/B00..._ya_os_product
Not a bad price. Lifetime warranty. I bought through Amazon since they ALWAYS take care of their customers if there's an issue.
I'll get pictures of the factory one that's on there. It seriously looks like it's been to war.
~Aaron
Unread 06-20-2012, 04:14 PM   #238
narnwv
narnwv's Avatar
I hit this page http://www.jeepslimited.com/index.ph...=44&Itemid=140 to see if it had correct routing for using the aux trans cooler with the factory "cooler" in the radiator, and noticed that there are "air diverters" on the sides and bottom of his radiator Mine does NOT have those..... I'm sure that's contributing to the issue as well. Might need to fab something up.
~Aaron
Unread 06-20-2012, 09:08 PM   #239
HVACNY
HVACNY's Avatar
2013 WK
Lmaooo,,
Unread 06-20-2012, 10:26 PM   #240
narnwv
narnwv's Avatar
figured I'd throw up a few pictures of the condenser. Honestly, these pics don't do it justice. It looks beautiful compared to real life, not to mention that the pics don't show how wavy the whole thing is.
Straight down, driver's side
Straight down, passenger side
Through the gap where the hood latch is
Through the grill, no idea what the blue ball-like thing is
Other side, through the grill
Both of these are looking through the gaps at the bottom of the bumper
~Aaron
