NarnWV's super slow build thread - Page 43 - JeepForum.com
post #631 of 763 Old 09-15-2013, 03:40 PM Thread Starter
narnwv
narnwv's Avatar
Holy crap. 2 months later.....
We're finally settling in the NEW house. It was the house I grew up in, and the garage I've used for the past 20 years. We're also headed to court against the owners of the flooded house for fraud.
The Jeep's still on my **** list. The trans had issues of putting itself in reverse while driving (locking up the rear wheels), and was diagnosed as a Shift Solenoid issue. To save some cash, I bought a transmission from a salvage yard for $150. We put it in, and it had the EXACT SAME ISSUE. I took the unit back, and as we left the yard (2 hours away) my Tracker quit running and hasn't started since. I exchanged the bad trans for a younger, lower mileage unit, and we got it installed-and it's in limp mode. We had to try 4 times to get the DRB-III emulator to force it out of limp mode and perform the "Quick Learn" procedure.
On my test drive of the latest transmission install, 1/8th of a mile from the house I started getting a clicking noise. I eased it back to the house, pulled the rear drive shaft (front one wasn't even put back in yet), and put it in drive. I found the clicking to be coming from the transfer case. Whew! I thought I was going to have to throw a transmission at someone.
I then pulled the tcase and started to tear into it. As soon as I got the rear seal off, two pieces of a snap ring fell out into my hands. This snap ring holds the main, rear output shaft in place. Without this ring in there, I was able to slide the shaft in and out (giggety) about 1/8th of an inch. On a rampage, I tried finding the snap ring. Jeep discontinued the part, so after searching and searching, I found it at a client of mine who does mechanical stuff. Putting the ring in, I still had clicking when turning the input by hand.
I kept tearing into the case and discovered that the planetary gears on the input shaft were binding and causing the clicking. This is the case that I built almost 3 years ago, using a 242 from an I6 w/71k miles on it, and the input shaft from my dead 247 with 200k+ miles on it. I figure the trans slamming into reverse, locking up the rear wheels is what caused the extra wear in these gears.
The next morning I was off to the closest salvage yard. I grabbed a 242HD for $275 with 62k miles on it. I got it in pretty quick (getting good at this now), and hooked up the front drive shaft, and filled her full of fresh fluid. (proper yoke already on it yay!). No rear drive shaft, since my setup was the I6 frankenstein unit, and the yard didn't have the one I needed.
With my front wheel drive Jeep, I took off to test the 2nd replacement transmission that I installed last weekend, and my new tcase. About 2 miles down the road, I got a check engine light and it's stuck in limp mode again. (2nd and 3rd gear only). The only code I'm pulling is P1728, which is a Chrysler specific code for "2C Hydraulic Pressure Switch Circuit". I'm hoping that it's the "Governor Pressure Transducer" that others have found it to be, and not anything major. Of course no parts stores stock this item, so it's going to be ebay or a trip to the dealer. I knew I should've kept all the sensors off the transmissions I took back to the salvage yard. (the 1st purchase and my core). It also slammed once or twice as well, and I noticed some binding/cracking coming from my driver's side front wheel area. Let's hope that's just a CV issue.
Any input on the P1728 /2C Hydraulic Pressure Switch Circuit issue would be most appreciated.
I still have the IRO tcase skid, waiting to be installed. I also now need my yearly safety inspection sticker. While spending so much time under the Jeep recently, I've discovered that my rockers are half rotted out, so hopefully before winter, we'll cut those out and weld in boat-sides for sliders.
~Aaron
narnwv is offline
post #632 of 763 Old 09-16-2013, 07:30 PM Thread Starter
narnwv
narnwv's Avatar
So, the dealer said $80 and 5 days to get the Governor Pressure Transducer. I grabbed a whole set of external sensors (the Transducer plus both input/output speed sensors) for $90 from ebay, which should be here by Friday. Let's hope I can drive this muhfugga this weekend. I'm sick of working on it.
~Aaron
narnwv is offline
post #633 of 763 Old 09-19-2013, 07:26 PM Thread Starter
narnwv
narnwv's Avatar
I reset everything and drove it yesterday. Now the code it gives 1 mile into the drive is P1767--which research points to the transmission relay not closing.
ANYONE have any ideas? Similar issues? There's about to be a fire inside of this Jeep.
~Aaron
narnwv is offline
post #634 of 763 Old 09-19-2013, 09:21 PM
wj4play
Originally Posted by narnwv
I .............There's about to be a fire inside of this Jeep.
Hope your insurance company don't see this post Rolf
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #635 of 763 Old 09-19-2013, 09:44 PM Thread Starter
narnwv
narnwv's Avatar
heh. wouldn't cover it anyway.
~Aaron
narnwv is offline
post #636 of 763 Old 09-20-2013, 07:58 PM Thread Starter
narnwv
narnwv's Avatar
Since I had already ordered them, today I replaced both input and output speed sensors, as well as the Governor Pressure Transducer. It was a little better, but after coming to a stop, it went back into limp mode. Back with the P1767.
Keep in mind that this IS the replacement trans. I've also in the past 5000 miles replaced the TPS and crank sensors. My original trans (269k) would buzz a LOT (shift solenoid) and randomly throw itself in reverse--locking the wheels up. I replaced it, and the replacement unit did the exact same thing. This is the SECOND replacement, and while it's in limp mode, throwing codes, it's in better shape (86k) than the one I started with--that NEVER threw any codes.
~Aaron
narnwv is offline
post #637 of 763 Old 09-22-2013, 03:45 PM Thread Starter
narnwv
narnwv's Avatar
Well, I'm still getting the P1767, coupled with limp mode after a mile of driving it--after resetting the codes.
The shift solenoid is even buzzing while in Park. I guess it's time to replace it too.
~Aaron
narnwv is offline
post #638 of 763 Old 09-22-2013, 10:14 PM
wj4play
Maybe your Tcm needs flashed or replaced
wj4play is offline
post #639 of 763 Old 09-23-2013, 02:17 PM Thread Starter
narnwv
narnwv's Avatar
TCM was replaced before anything else was done. It was replaced before the first trans was pulled out.
Typing on phones sucks.
~Aaron
narnwv is offline
post #640 of 763 Old 09-25-2013, 11:16 PM
Justin_WJ
And to think. You could have bought my transmission and not had a problem....hmm Who would thunk it.
2000 WJ Limited, 4inch RC X, 242 T-case swap, 33x12.50 STT's, 15x8 D window wheels with 3.75 BS, JKS ADJ. Tracbar, T-case armor, Custom front winch bumper, Smittybilt XRC 8, 4.56's Extended Rola Rack w/Harbor Freight 6" lights, and always muddy :)
Justin_WJ is offline
post #641 of 763 Old 09-26-2013, 08:11 AM Thread Starter
narnwv
narnwv's Avatar
~Aaron
narnwv is offline
post #642 of 763 Old 09-26-2013, 07:35 PM
wj4play
I don't see it ??
wj4play is offline
post #643 of 763 Old 09-26-2013, 07:37 PM Thread Starter
narnwv
narnwv's Avatar
now do you?
~Aaron
narnwv is offline
post #644 of 763 Old 09-26-2013, 07:44 PM
wj4play
now do you?
Nope ... Nothing if u attached something
wj4play is offline
post #645 of 763 Old 09-26-2013, 08:08 PM Thread Starter
narnwv
narnwv's Avatar
it's a screenshot of a conversation Justin_WJ and I had when he started parting out his WJ.
~Aaron
narnwv is offline
lateralus3's slow build thread lateralus3 Grand Cherokee General Discussion 746 01-30-2014 05:13 AM
My slow zj build Erbo1Kanerbo Grand Cherokee General Discussion 564 05-10-2013 08:46 AM
Haviiks 01 WJ (slow) Build HaViiK Grand Cherokee General Discussion 392 03-18-2013 11:43 PM
WJ=Wifes Jeep. WJChris' Slow Build WJChris Grand Cherokee General Discussion 134 12-28-2011 08:03 PM
99wjlaredo's Slow 99' WJ Build 99wjlaredo Grand Cherokee General Discussion 18 08-03-2010 10:18 AM
