NarnWV's super slow build thread - Page 36 - JeepForum.com
post #526 of 763 Old 01-29-2013, 07:45 PM Thread Starter
narnwv
narnwv's Avatar
Going to try to replace front unit bearings as soon as it's warmer out. It was 70 today, supposed to be 31 this weekend. It gets dark within 30 minutes of being home, and the garage is full of crap and not heated. Whilst I love the snow, I'm ready for spring. Both the Jeep and the Tracker need some TLC (and upgrades)
~Aaron
narnwv is offline
post #527 of 763 Old 02-02-2013, 11:53 AM Thread Starter
narnwv
narnwv's Avatar
It's freezing cold, and still snowing here. Yesterday my hatch about gave me a concussion while I was unloading a giant laser printer (the box says "team lift") by myself. My hatch stays up in the summer, but not in the cold. Just ordered all 4 lift struts for the hatch+glass from Advance with their 20% off discount. Gotta go pick those up and slap 'em on. In the snow.
Wasn't it 70 degrees, like 4 days ago? Oh yea, this is WV.
~Aaron
narnwv is offline
post #528 of 763 Old 02-04-2013, 07:00 PM Thread Starter
narnwv
narnwv's Avatar
Changed the oil this evening. Discovered that my trackbar jam nut was loose. (1/4" out) Tightened that up. No wonder she about hopped into the other lane when i hit a pothole on the interstate that about swallowed my 32" tire earlier today.
I wonder if this will help my transfer case issue. Since it snowed, I've been running in 4wd Full Time, but it binds hard when trying to make sharper turns. I assumed it needed adjusted, or the shift forks were jacked, because with a little left-right-left-right jerks of the wheel, it'd be okay in Full Time. We'll see.
I think I'm going to postpone doing the hubs for now and try to find an affordable Vari-Lock axle to clean up and build a bit. I want some sort of traction increase in the front, and a Vari-Lock complete axle swap sounds easier than a JK axle.
~Aaron
narnwv is offline
post #529 of 763 Old 02-04-2013, 08:36 PM
wj4play
Go OX locker In front
Selectable locker and new gears in your current dana30 would be same cost vs used varilock front 30 with rebuild IMO around here front dana30 used go for 900+
TRUETRAC in rear with gears or a over stuffed d44 rear (extra plates in limited slip)
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #530 of 763 Old 02-04-2013, 08:43 PM Thread Starter
narnwv
narnwv's Avatar
Holy Crap! I can get a D30 w/Vari-Lock and a warranty for $300-ish (depends on miles, and which yard--within 200 miles)
I'd love a selectable locker, but if I'm going to lock the front, then I need u-joint half shafts. If I'm going to pull the gears out, I need shorter gears. Add those, and you're talking the cost of a used JK Rubi D44 for the front--4.10 gear, electric locker, u-joint half shafts.
~Aaron
narnwv is offline
post #531 of 763 Old 02-05-2013, 10:18 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Yeah, I've never seen a D30 VariLok for more than $500 as a complete assembly. Well, I can go on car-part.com and find a ton of massively overpriced ones, but getting one <$500 is no trouble around here.
~Richard
billzcat1 is offline
post #532 of 763 Old 02-05-2013, 10:21 AM Thread Starter
narnwv
narnwv's Avatar
car-part.com is where I'm finding them within 200 miles for about $300ish.
In other news, an old man drug his f150 across the corner of my rear bumper. Hopefully they'll give me a check and I can get a metal, tire-carrier bumper (either bought or built).
~Aaron
narnwv is offline
post #533 of 763 Old 02-05-2013, 06:08 PM
wj4play
All the yards around here are way overpriced - I was looking for a jk dana30 and they wanted 1200 - wasn't the 44 (rubicon) either
That's when I asked about a wj D30 for comparison - he said 900-1000
That was consistent with 3 salvage yards.
A lot of times yard items here are close to the parts store prices on newer year of stuff
I got my d44 varilock from smunns in Lincoln Nebraska for $150 - I'm in dsm Iowa so basically spent a Saturday picking it up
wj4play is offline
post #534 of 763 Old 02-05-2013, 06:41 PM Thread Starter
narnwv
narnwv's Avatar
There's a place in Ohio, about 3 hours from here Called Davey's Jeeps. Basically, he parts out wrecked Jeeps, and that's it. He regularly sells a pair of JK Rubi axles for $2k or less. (they go quick)
http://www.daveysjeeps.com/specials.html
~Aaron
narnwv is offline
post #535 of 763 Old 02-05-2013, 06:46 PM Thread Starter
narnwv
narnwv's Avatar
In other news, I finally picked up a "large vehicle" coolant over flow tank from Autozone to finally have wiper fluid again (after 2+ years). Dug the pumps out of the WJ's washer fluid tank (that's been hanging in the garage) to get started. Hopefully I'll have this done tomorrow. The tank came with a mounting bracket.
It's essentially this:
I'm hoping I can hook up a second one, using the drains at the bottom for the connection, and have a bigger tank. Having the connection at the bottom like that will allow the two tanks to remain level with each other.
~Aaron
narnwv is offline
post #536 of 763 Old 02-05-2013, 07:00 PM
squashman702
1994 ZJ
Why would you need U joint shafts for a locker?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #537 of 763 Old 02-05-2013, 07:52 PM Thread Starter
narnwv
narnwv's Avatar
too afraid to rip apart the CVs
~Aaron
narnwv is offline
post #538 of 763 Old 02-05-2013, 07:57 PM
wj4play
Actually if you do a 30spline then stay with cv RCV to be exact. Saw that IRO had sum chromo u joint shafts for 800 I think..
Off topic cuz I kno your a computer guy look what I received last Saturday
Did a iPhone 4S dump already
wj4play is offline
post #539 of 763 Old 02-05-2013, 07:59 PM Thread Starter
narnwv
narnwv's Avatar
very cool. Radio shack uses those. I had them dump pictures from a customer's dead flip phone. She was very grateful. Pretty neat little tool.
~Aaron
narnwv is offline
post #540 of 763 Old 02-05-2013, 08:03 PM
wj4play
Cellebrite UFED touch ultimate forensic examiner - different from what radio shack uses
wj4play is offline
lateralus3's slow build thread lateralus3 Grand Cherokee General Discussion 746 01-30-2014 04:13 AM
My slow zj build Erbo1Kanerbo Grand Cherokee General Discussion 564 05-10-2013 07:46 AM
Haviiks 01 WJ (slow) Build HaViiK Grand Cherokee General Discussion 392 03-18-2013 10:43 PM
WJ=Wifes Jeep. WJChris' Slow Build WJChris Grand Cherokee General Discussion 134 12-28-2011 07:03 PM
99wjlaredo's Slow 99' WJ Build 99wjlaredo Grand Cherokee General Discussion 18 08-03-2010 09:18 AM
