NarnWV's super slow build thread - Page 14 - JeepForum.com
post #196 of 763 Old 06-16-2012, 01:45 PM
C101Commando
Ever thought of using a float switch for your fan? Mount the switch below fan level, then it would shut the fan off automagically whenever you got into deep water. That would eliminate the possibility of a kid turning your fan off when you weren't looking..
03 WJ, 4.7 Limited
C101Commando is offline
post #197 of 763 Old 06-16-2012, 09:31 PM Thread Starter
narnwv
narnwv's Avatar
changed out the TREs on my drag link today under warranty. Managed to cause my steering gear to start leaking pretty bad. I grabbed a seal kit, but the pitman arm is fused to the shaft via rust i'm sure after not being apart for 12 years, so I'm sure I'm going to have to replace the whole box. I need a new DD so I can stop pouring money into this thing every time I turn around.
That hadn't even dawned on me....great idea though! Maybe I'll look into it.
Anybody have any input about the condition of my spark plugs I posted after getting a P0302?
~Aaron
narnwv is offline
post #198 of 763 Old 06-16-2012, 09:43 PM
PhantomWJ
2003 WJ
Whats p0302? cylinder 2 misfire?if so, fuel delivery then...injector?
PhantomWJ is offline
post #199 of 763 Old 06-16-2012, 09:58 PM Thread Starter
narnwv
narnwv's Avatar
that's what I'm trying to figure out. Knowing the over temp issues I've been having, some are suggesting head gasket, someone mentioned running lean. This morning I had the CEL pop up with this code, so I snapped a few cell phone pics for some input.
The plugs were put in less than 1000 miles ago.
unrelated: Typing all this on a tablet sucks.
~Aaron
narnwv is offline
post #200 of 763 Old 06-17-2012, 11:35 AM
Cnolenwj
As much as a don't want to think about it, I think the head gasket may be my problem.
I had some work done on the heads a year or two ago by the dealership, and all I'll say is the work they did on my jeep was mabe marginal at best.
If they needs to be replaced I may attempt it this time, I don't think I would do much worse than they did.
I know I'm not much help, but good luck on finding a cure for your problem and please share if you get it figured out. I'll keep you posted too if I get anything straightened out.
2000 wj limited, 4" IRO, long armed front.
Build thread-
North Texas Grands-
Grand Slam Texas-
Grand Slam Texas Group-
Cnolenwj is offline
post #201 of 763 Old 06-17-2012, 11:56 AM Thread Starter
narnwv
narnwv's Avatar
My engine had a spun bearing when I got the Jeep, and I've put ~64,000 on it in 2.5 years. It did peg the red once in 2010, but it was just for a few seconds. As soon as I pulled off the interstate, it dropped quickly (within seconds) to normal operating temp. That also was NOT the beginning of my heat issues. (I don't think)
I've been looking around, because if it is indeed head gaskets, I'm just going to build a second engine to drop in. I can live with it getting a little warm while I build an engine (I mean, it's been 2 years already), and I can find "blown" 4.7s for less than $250 all day.
~Aaron
narnwv is offline
post #202 of 763 Old 06-18-2012, 10:48 AM Thread Starter
narnwv
narnwv's Avatar
I filled up today with 90 octane Ethanol-FREE gasoline. I'm hoping it helps with mileage a bit, and see if the rough idle goes away.
~Aaron
narnwv is offline
post #203 of 763 Old 06-18-2012, 11:39 AM
Cnolenwj
Have you tried running any seafoam through the vacuum line?
Build thread-
North Texas Grands-
Grand Slam Texas-
Cnolenwj is offline
post #204 of 763 Old 06-18-2012, 11:44 AM Thread Starter
narnwv
narnwv's Avatar
yeah, I do it about every 10 oil changes. I bought a can do run it through BEFORE I changed my plugs this last time, but forgot to run it through, so I dumped it in the tank.
Someone mentioned that a partially clogged converter would cause high vehicle speed overheat issues, and it made me wonder if all the Seafoming I've done caused anything like that.
~Aaron
narnwv is offline
post #205 of 763 Old 06-18-2012, 11:53 AM
Cnolenwj
That's interesting, my exhaust was submerged in nasty water for almost 24hrs about a year ago when I got it stuck.
Yet another thing it could be. The list is getting long.
Build thread-
North Texas Grands-
Grand Slam Texas-
Cnolenwj is offline
post #206 of 763 Old 06-18-2012, 12:05 PM Thread Starter
narnwv
narnwv's Avatar
cnolenwj--are you still getting warm after all the cooling system work?
~Aaron
narnwv is offline
post #207 of 763 Old 06-18-2012, 12:05 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Those of you questioning your headgasket without obvious headgasket issues - do an oil analysis on your next oil change. They can detect even slight coolant contamination in the oil and any associated wear that may be occurring (antifreeze is corrosive to the soft-metal bearings). $25 and you will find out pretty definitively if there's an issue.
~Richard
billzcat1 is offline
post #208 of 763 Old 06-18-2012, 12:08 PM Thread Starter
narnwv
narnwv's Avatar
just ordered a kit from http://www.blackstone-labs.com
~Aaron
narnwv is offline
post #209 of 763 Old 06-18-2012, 12:10 PM
billzcat1
2003 WJ
That's who I use. Very helpful folks. Gah, I still need to mail out my last sample!
~Richard
post #210 of 763 Old 06-18-2012, 12:11 PM Thread Starter
narnwv
narnwv's Avatar
yeah, that's why I ordered from them. I've been meaning to for a while. :/ I think I'm just scared to see the results.
~Aaron
narnwv is offline
lateralus3's slow build thread lateralus3 Grand Cherokee General Discussion 746 01-30-2014 04:13 AM
My slow zj build Erbo1Kanerbo Grand Cherokee General Discussion 564 05-10-2013 07:46 AM
Haviiks 01 WJ (slow) Build HaViiK Grand Cherokee General Discussion 392 03-18-2013 10:43 PM
WJ=Wifes Jeep. WJChris' Slow Build WJChris Grand Cherokee General Discussion 134 12-28-2011 07:03 PM
99wjlaredo's Slow 99' WJ Build 99wjlaredo Grand Cherokee General Discussion 18 08-03-2010 09:18 AM
