MY WJ rear QTR protection w/nudge bar and recessed LED tails. - JeepForum.com
post #1 of 12 Old 11-07-2013, 06:49 PM Thread Starter
gcjeeping
gcjeeping's Avatar
So after a few dent's in the rear QTR's and fenders as well as some broken taillight I finally got around to making some rear QTR protection with nudge bars and recessed LED tail lights.
I also built in a lockable compartment on the pass side. I made it as a remote power station and switches to turn the LED bars, side lights and BU lights. Also put in a cigaret lighter plug and the remote box for my power inverter. It has 2 110v and 2 USB receptacles. It has a switch to turn the inverter on and off from the remote box.
Started with remnant 10 gauge diamond plate, 24 riv-nuts, stainless hex cap screws and two harbor freight LED tail lights. Picked up a mailbox lock from Lowe's. I already had the toggle switches and pipe for the nudge bars.
Made some paper templates.
Cut the plate with the plasma and test fitted and adjusted as needed. I used a bottle jack, scrap metal 2x4 to put the bends in the plate.
Next was drilling holes and installing riv-nuts. I made my own riv-nut tool. I taped the plate to the jeep and drilled through the plate and fender at once.
_____________
gcjeeping is offline
post #2 of 12 Old 11-07-2013, 06:49 PM Thread Starter
gcjeeping
gcjeeping's Avatar
Cut the metal for the recessed LED tail lights and tack welded them in.
Cut and tack welded the fender pieces. The plate that is flat and facing out is scrap I had and is thicker than the 10 gauge. I had to cut reliefs in the curved bent part to get the bend right. Will fill them in when I weld them up.
_____________
post #3 of 12 Old 11-07-2013, 06:50 PM Thread Starter
gcjeeping
gcjeeping's Avatar
All welded up and a coat of primmer.
Also hole was cut for door to access power outlets.
Made a box out of scrap sheet metal for the power outlets and switches. Spot welded it in and sealed around it with RTV.
Waiting to install.
Fitted on and LED's wired up. I tapped into the trailer harness after the relays to get the LED to work like trailer lights. That way I didn't need to make any new wiring for them. Also added red reflectors to help keep it legal. Might have to add a side marker light too.
Access door. Put the cigarette lighter plug in. Will do switches and power outlets later.
_____________
post #4 of 12 Old 11-07-2013, 06:51 PM Thread Starter
gcjeeping
gcjeeping's Avatar
Cut and bent the tube then welded it on. Primed the tube and put the panels on the Jeep.
Here is the little power panel. The 3 switches are to turn on the LED bars, side roof rack lights and back up lights. Any or all can be turned on without starting or getting into the Jeep. The Cig lighter is always hot and the 120v/USB box is turned on/off by the switch on the box. Also added a mailbox lock to keep it secure.
A view from the back. LED's off, park, brake and vid of hazards.
Below is a video.
_____________
post #5 of 12 Old 11-07-2013, 07:32 PM
MoonyJohn
So sick! Its like a blend of the WJ and ZJ rear end. The squarer tail lights make it looks awesome. Good work!
MoonyJohn is offline
post #6 of 12 Old 11-07-2013, 07:44 PM Thread Starter
gcjeeping
gcjeeping's Avatar
Thanks. Came out good. Debating on painting them OD like the rest of the jeep.
Best of all no more cracked or broken tail lights.
_____________
post #7 of 12 Old 11-07-2013, 10:21 PM
CRJEeP_wj
That is genius. Great job again. Now you got me all pumped to get out and start fabing on my jeep again.
02 grand cherokee, hp60 14b, 42s. Stazwork, triangulated 4-link, rear leafs, homemade bumpers and sliders. build thread
CRJEeP_wj is offline
post #8 of 12 Old 11-07-2013, 10:39 PM Thread Starter
gcjeeping
gcjeeping's Avatar
Get going. LOL Picked up the metal from S&K for $22 bucks. Already had the tube. Was a fun build and cheap. Love cheap.
_____________
post #9 of 12 Old 12-01-2013, 09:38 AM
ayycharlay92
these are awesome
ayycharlay92 is offline
post #10 of 12 Old 12-01-2013, 11:05 PM Thread Starter
gcjeeping
gcjeeping's Avatar
Originally Posted by ayycharlay92 View Post
these are awesome
Thanks. Waiting to see who else makes some
_____________
post #11 of 12 Old 12-03-2013, 02:39 AM
VanBCguy
Two words: pure brilliant.
VanBCguy is offline
post #12 of 12 Old 12-05-2013, 10:31 PM Thread Starter
gcjeeping
gcjeeping's Avatar
Thanks. Gotta figure out something else to build on it.
_____________
