My third Jeep, '04 Overland - JeepForum.com
post #1 of 61 Old 05-12-2014, 07:04 AM Thread Starter
poj2001
I just picked up a 2004 WJ Overland, Onyx Green with only 56,000 miles on it!. This is my third Jeep ('95 ZJ and '01 WJ) and the first one that I will lift.
I already ordered a 2" BB and Bilstein 5100 shocks (thanks Kolak). I have been looking around for the right tire to get, I will probably go with a 245/70R17. From what I read that is the largest size that will fit into the spare tire well. As far as brands go, I have Cooper A/T3 on my '01 and might just get those again, but I'm looking around still. Any tire suggestions? I live in central NY and we get a ton of snow so the tires should be good on ice and snow.
The body needs some touch up work and there is a little rust on the the rear driver side fender near the door that I want to try and eliminate. I also need to find some new plastic panels that are clipped onto the bottom of the doors, two of them are cracked.
poj2001 is offline
post #2 of 61 Old 05-12-2014, 11:54 AM
dcorn
Nice find. I bought mine last year with 65k miles on it, perfectly mint.
Make sure to do a good fluid change. I've swapped every single fluid on the jeep and feel much better about the reliability. That also stopped the groaning in the rear axle.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #3 of 61 Old 05-12-2014, 01:46 PM
redneck_ram
2003 WJ
grabber at2's are a great tire, as well as the duratracs. have had both, feel as though the duratac was better in the snow than my current grabbers are.
both at2s and duratracs are stud-able. granted these tires are on my ram 1500 that i use for plowing, but still.
2003 WJ Overland 4.7HO quadra-drive - k&n fipk, kolak 3" exhaust, magnaflow muffler, sct tuner-hemifever
2001 Dodge Ram 1500 - QCSB 4x4 built 360, 46re, not stock!
redneck_ram is offline
post #4 of 61 Old 05-12-2014, 01:58 PM
braddf
that is a nice looking jeep! It's so clean and the colors are great and with that few miles? I am a very jealous person
Build thread: http://bit.ly/1puFzZm
Stock rims for sale: http://bit.ly/1kMw7k5
braddf is offline
post #5 of 61 Old 05-12-2014, 02:10 PM Thread Starter
poj2001
Good idea, the oil is new but I will definitely look into swapping everything else (except maybe washer fluid!)
poj2001 is offline
post #6 of 61 Old 05-12-2014, 02:13 PM Thread Starter
poj2001
I'll check those out, I was not really happy with the Cooper A/T3 but that maybe have been also due to the Quadra-Trac II in the 01 Limited. I hear the Quadra-Drive is a lot better.
poj2001 is offline
post #7 of 61 Old 05-12-2014, 02:15 PM Thread Starter
poj2001
I lucked out getting this one. I test drove it last Monday and put a deposit down to hold it for a week while I was out of town. They said by Friday they had gotten hundreds of calls from all over the country asking about it.
poj2001 is offline
post #8 of 61 Old 05-12-2014, 04:20 PM
Frambo
Nice! I recently got an 04 Overland in Onyx Green with 60K as well! Great Jeeps... that colour is awesome- looks different depending on the light!
Frambo is offline
post #9 of 61 Old 05-12-2014, 06:57 PM
WXman
4.7 HO?
Sent from AutoGuide.com Free App
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #10 of 61 Old 05-12-2014, 07:14 PM
redneck_ram
2003 WJ
Originally Posted by WXman View Post
4.7 HO?
thats the only motor the overland came with...
post #11 of 61 Old 05-12-2014, 10:45 PM Thread Starter
poj2001
Cool! I haven't noticed that yet, it's still a little dirty, needs a good wash.
poj2001 is offline
post #12 of 61 Old 05-12-2014, 10:48 PM Thread Starter
poj2001
4.7 HO
Yeah, it is the HO, I think I read that if the original buyer wanted something different it was an option, but I doubt anyone didn't choose the HO.
So far the only real I difference I've noticed is the sound. Seems to have the same power as my '01 4.7V8, but I haven't towed with the HO yet. Maybe. That's where I'll notice it. 0 to 60 seems about the same.
poj2001 is offline
post #13 of 61 Old 05-12-2014, 10:52 PM
cr8zynelly
Put some 93 octane in. You should notice the difference.
cr8zynelly is offline
post #14 of 61 Old 05-13-2014, 06:23 AM Thread Starter
poj2001
93 octane
Next time I fill up I'll get the good stuff and report back.
poj2001 is offline
post #15 of 61 Old 05-13-2014, 06:50 AM Thread Starter
poj2001
So last night I did my first mod to the Overland. I was reading through theksmith's build:
http://www.jeepforum.com/forum/f197/...4-7-ho-526660/
and decided to copy a few of his ideas. The first was modifying the dual climate zone module to adjust both driver and passenger side temperature simultaneously. Well I was at it I swapped the face of the module with the one from my '01 WJ because the face plate of the '04 was stained. I guess the modules are not interchangeable, and the circuit boards definitely look different.
Stained '04 module:
'04 on the left, '01 on the right:
I soldered the driver side wire to the front:
Then realized there was WAY more room to solder the wire to the back at the dial terminals (passenger side):
It took a little testing to get the module to work how I wanted it to, but basically when the switch closes, the reds get connected and the blacks get connected:
I could have done a better job drilling the hole, first I drilled a hole then tried to make it square with a Dremel. You can't even notice when its installed:
Here is a video of it working while testing:
https://www.youtube.com/watch?v=sIkgeZ_Bg98
I set it so when the switch is to the left the driver and passenger side are synced and when its to the right they are independent.
I will post more pictures of it installed tonight, I think when I was putting the module back together some wires were shorting out because when the switch was closed it was doing some funky things.
Thanks theksmith, great idea!
poj2001 is offline
