My slow zj build - Page 17 - JeepForum.com
post #241 of 565 Old 10-18-2010, 10:40 AM
redfoxbody
I like the cladding on much better
4.0 2x4>4x4 conversion 3.73, rubicon rims, 245/75R16 mtr 42RE > AX-15 Conversion in progress.
Build thread
Depressed about your car dent? dentszone.com
Nice the legs in that last picture, almost makes you not think about the jeep.
My 16 year old little sister, you creep.
redfoxbody is offline
post #242 of 565 Old 11-01-2010, 03:39 PM Thread Starter
Erbo1Kanerbo
me too... ok so heres the savings plan for the jeep. Add 1" coil spacers and new coil spring isolaters, Rear adjustable x flex control arms with johnny joints upper and lower, front lower control arms either from IRO or the Iron Man ones not sure yet, 1" transfer case drop, extended brake lines, then gonna run 33's. Does anyone know if my driveshaft will be fine at this height or will it need lengthening? it is a double cardan rezeppa style (ujoint at tcase and cv at axle) and the rear is both u joints double cardan i think
ZJ Build thread:
ZJ's: If you dont know what it is you cant afford it.
Erbo1Kanerbo is offline
post #243 of 565 Old 11-22-2010, 10:08 PM
thorrider152
my rear lamp failure light is always on too really irritating....thats chrystler wiring for you
thorrider152 is offline
post #244 of 565 Old 11-23-2010, 12:02 AM
CostcoPizza
Fresh Baked
CostcoPizza's Avatar
x2
CostcoPizza is offline
post #245 of 565 Old 11-23-2010, 09:34 PM
squashman702
1994 ZJ
You're going to want a new front shaft. Rear should be fine.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #246 of 565 Old 11-24-2010, 01:29 PM Thread Starter
Erbo1Kanerbo
yep my front ds is already done for its been whining making weird noises so i just took it out before it blew up on me. ive already talked to carolina driveline on getting a new front ds with the ujoints for 250
ZJ Build thread:
post #247 of 565 Old 11-25-2010, 07:48 PM
grandcherokee94
one in regular color
Looks awesome,can't wait to have mine lifted,which will be next weekend.I'm doing a 3.5 tuff country lift with 3/4 inch spacers.
1994 ZJ-4.0L HO,K&N CAI,TB spacer,Flowmaster Duel Exhaust,8000k HID,White Face Gauges,Pillar Gauges,3.5 Tuff Country lift,Much much more!-SOLD!
1998 ZJ Limited-5.2L AWD
Build Tread:
1996 ZJ Limited-5.2L AWD
grandcherokee94 is offline
post #248 of 565 Old 11-29-2010, 02:56 PM
bigb229
bigb229 is offline
post #249 of 565 Old 11-29-2010, 02:57 PM
bigb229
oh..these are in atl btw....20$...you cant go wrong
bigb229 is offline
post #250 of 565 Old 11-29-2010, 03:04 PM Thread Starter
Erbo1Kanerbo
theyre in alpharetta, where i live haha str8 idk if i should get those or adjustable tho what do you think?
ZJ Build thread:
post #251 of 565 Old 11-29-2010, 05:20 PM
93zjFBI
when you pulled your cladding off was there any rivites on the body i am thinkin about taking mine off
93zjFBI is offline
post #252 of 565 Old 11-29-2010, 05:36 PM
csouers
I'll bet it's the third brake light. The bulb sockets get worn and the bulb can move around inside of the socket. Sometimes to where it doesn't have a good connection, doesn't light, thus the lamp failure module being a tattle tail.
Hit the top of your hatch by the 3rd brake light and it might fix it. Hit a bump, then you're probably back to square uno.
I fixed mine by replacing the bulb socket piece. Just unplugged the old and plugged in the new.
ps. Nice rig. Even those tires look small.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #253 of 565 Old 11-29-2010, 06:48 PM
bigb229
no problem dude...ive got some fresh new bushings for them too if they need it. i have that same set of arms on my 4.5" iro lift.
bigb229 is offline
post #254 of 565 Old 11-29-2010, 07:16 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
there are about 6-10 posts per panel iirc.
ratmonkey is offline
post #255 of 565 Old 11-29-2010, 08:34 PM Thread Starter
Erbo1Kanerbo
I like the look of no cladding but only if its clean under like moony johns zj when i took mine off there was some paint chipped and the paint underneath was kind of a different color. i think mine looks alot cleaner with the cladding on (i think because its black) when you take the cladding off theres those nipple things that poke out (which kinda look cool in my opinion) and theres tiny holes. Also when you take the cladding off the plastic that holds on the cladding is over 12 years old so they tend to break pretty easily which makes a chore for you if you want to put them back on....to sum it up i would leave the cladding on and just paint it, thats what i did
ZJ Build thread:
Should it be THIS slow? JrMechanic ZJ Grand Cherokee Forum 17 11-30-2008 06:59 AM
slow key EZ1 ZJ Grand Cherokee Forum 4 09-20-2007 11:51 AM
Slow at first... randhi23 ZJ Grand Cherokee Forum 1 09-05-2007 11:26 AM
Slow on Take-off toke ZJ Grand Cherokee Forum 2 08-22-2007 10:20 PM
Will an ARB slow me down? parnell5150 ZJ Grand Cherokee Forum 7 09-06-2006 04:59 PM
