My slow zj build - Page 15 - JeepForum.com
post #211 of 565 Old 09-21-2010, 06:51 AM Thread Starter
Erbo1Kanerbo
ddm tuning kit 8000k with the hi/lo beam
ZJ Build thread:
ZJ's: If you dont know what it is you cant afford it.
Erbo1Kanerbo is offline
post #212 of 565 Old 09-21-2010, 06:52 AM Thread Starter
Erbo1Kanerbo
Originally Posted by bigb229 View Post
were still waiting on the flew pics................
lol ill probly go sometime this week ive just been really busy with school and work lately
ZJ Build thread:
post #213 of 565 Old 09-21-2010, 04:11 PM
bigb229
hey man.....x2 on the tre replacements....i just got through replacing all of mine and setting the toe in out in the parking lot.....drives like a dam dream
bigb229 is offline
post #214 of 565 Old 09-21-2010, 07:31 PM Thread Starter
Erbo1Kanerbo
yeah dude once i got my tires balanced it drives soo much better now i can go 75+ on the highway and it feels stock maybe even a little smoother. im gonna get the iro tie rod with rod ends soon im gonna do some other mods first. I hear a hum on my driveshaft so i think i need to get it balanced and im going to drain and fill my diffs with synthetic. also a kolak ignition kit. probly get tires somepoint between all that i plan on getting this all done by the end of this year
ZJ Build thread:
post #215 of 565 Old 09-21-2010, 09:11 PM
bigb229
have you checked the u joints on the driveshaft? i think a misbalanced ds would present with a vib instead of a hum...but im not really sure. and i think your stock tre's will work with the iro tr....i almost ordered one the other day when i bought my tre's of ebay.....3 moog ends.....35$ i know...sweet deal huh? what all does kolak put in the ignition kit? im scared mine might go "boom" if i up the hp anymore. lol. 150k and shes getting a little tender these days
bigb229 is offline
post #216 of 565 Old 09-22-2010, 11:46 AM Thread Starter
Erbo1Kanerbo
yea 99% positive it is coming from where the ds goes to the diff which is a cv joint. well my tre arent in the best shape might as well replace them. in the kolak ignition: Here's all the information about my Kolak Ignition Upgrade for your 1996 ZJ V8:
My recommendations for the 5.2/5.9 ZJ ignition system are designed to improve idle quality and throttle response, and to improve and maximize current transfer. This really helps support other modifications. Here's what I recommend:
Magnecor KV85 ignition wires
MSD high output replacement coil
Heavy duty US made brass terminal distributor cap with rotor
Autolite platinum plugs (one heat range colder than stock)
Price for the kit is $250.00
ZJ Build thread:
post #217 of 565 Old 09-22-2010, 12:16 PM
bigb229
oh....for some reason i thought you just had all new tre's put in...guess it was just the pitman arm end. that ignition sounds badass....you may wanna drop you thermostat a little lower as well. im not really sure why they do it...but most ppl that ramp up the ign. also cool the spark plugs and thermostat a tad too. dunno
bigb229 is offline
post #218 of 565 Old 09-30-2010, 08:07 PM
trailkingzj
Originally Posted by Erbo1Kanerbo View Post
ok what kind of engine mounts do i need theres two so do i get two of the same or is there a left or right. motor mounts from advanced are about $50 a piece
Get the polyurethane motor mounts from crawler ready. they have a lifetime warranty iircCrawler Ready - Off Road Parts and Accessories - Jeep, Wrangler, Grand Cherokee, Cherokee, Toyota
BLACK 95 ZJ: 4.5 SA, 33 BFG A/T's, FRONT AND BACK CUSTOM BUMPERS, d30 AND 8.8, BOTH 4.10 GEARS, JKS QUICK DISCO, OPTIMA YELLOWTOP, K&N, FLOWMASTER W/ TURNDOWN.
trailkingzj is offline
post #219 of 565 Old 10-01-2010, 10:04 AM Thread Starter
Erbo1Kanerbo
yea those are on my list of things to get cant beat that lifetime warranty
ZJ Build thread:
post #220 of 565 Old 10-01-2010, 03:55 PM
trailkingzj
yup i really need to get around to replacing bushings and that kind of stuff. hopefully ill get a job soon. instead of getting the CA bushings from iro or somewhere similar, would it make sense to get the daystar full polyurethane set for the whole jeep?
post #221 of 565 Old 10-02-2010, 08:14 AM Thread Starter
Erbo1Kanerbo
yeah i was thinking about getting that kit too theyre the polyurethane bushings. i think iro sells the stock type bushings. i just figure im gonna be doing all 8 adjustable arms and then going to 4.5" so ill change the bushings as i get my control arms
ZJ Build thread:
post #222 of 565 Old 10-02-2010, 09:54 AM
trailkingzj
yeah cuz im at about 4.5 on adjustable RE arms, and it rides like crap and clunks, needs new bushings bad. well be sure to let us know what you end up getting! what are you at now? hight-wise
post #223 of 565 Old 10-02-2010, 10:52 AM Thread Starter
Erbo1Kanerbo
im at 3.5". so how was the ride with adjustable arms at 4.5" when your bushings were good? im debating on whether doing long arms up front or not. this is my daily driver
ZJ Build thread:
post #224 of 565 Old 10-02-2010, 11:21 AM
trailkingzj
Im sorry to say i cant tell you. I picked this zj up for a hell of a deal from a guy who built it up as his dd in high school. pretty cool, but i can definitely tell you the ride has gotten worse since i got it, i cant really think of anything other than the bushings. Other people, such as Redhatman, have had up to like 6" on short arms. I am in the process of kinda rebuilding this zj, doing alot of maintenance and replacing.
post #225 of 565 Old 10-02-2010, 11:35 AM Thread Starter
Erbo1Kanerbo
could be balljoints theres alot of different things that can make it ride bad. if ur gonna check bushings you might as well buy a bushing kit and redo them while you take out your control arms bc they are a pain in the ase!
ZJ Build thread:
Should it be THIS slow? JrMechanic ZJ Grand Cherokee Forum 17 11-30-2008 05:59 AM
slow key EZ1 ZJ Grand Cherokee Forum 4 09-20-2007 10:51 AM
Slow at first... randhi23 ZJ Grand Cherokee Forum 1 09-05-2007 10:26 AM
Slow on Take-off toke ZJ Grand Cherokee Forum 2 08-22-2007 09:20 PM
Will an ARB slow me down? parnell5150 ZJ Grand Cherokee Forum 7 09-06-2006 03:59 PM
