My slow zj build - Page 14 - JeepForum.com
post #196 of 565 Old 09-02-2010, 08:45 PM
PurpleZJ
from the pics it looks as if it not only needs to come down but also be tilted forward away from the jeep a little. but i agree on black for sure
1996 ZJ- 4.0, AX-15 5SPD/NP242, RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
RIP Troy (bigbluezj94) you wont be forgotten
December 2010 GCOTM
5spd ZJ Club Member 001
Glad you are ok. If you were a cat, you would be down to 8.:D
Originally Posted by Greengc4x4 View Post
Everything looks great, Hellen Keller! :D
Originally Posted by rritch View Post
plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:
RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11
PurpleZJ is offline
post #197 of 565 Old 09-02-2010, 09:30 PM
bigb229
you couldn't fit your stock bumper on it with the guard? or did i miss something? i think it'll look good once you've got it on there right. my guard is from my previous 01 explorer sport...fit like a glove. but all the brackets had to be fabbed up.
bigb229 is offline
post #198 of 565 Old 09-03-2010, 12:07 PM Thread Starter
Erbo1Kanerbo
yeah i just made my own brackets and flipped some of the ones that came with it around and it fit lol ill post up some pics of it in a min. the second brackets i put on serve as light tabs also prob gonna put some piaa or hella lights on there im not sure yet, i like those black magic hellas may look into those
ZJ Build thread:
ZJ's: If you dont know what it is you cant afford it.
Erbo1Kanerbo is offline
post #199 of 565 Old 09-03-2010, 01:15 PM
squashman702
1994 ZJ
I like that you gave a shot, but it looks like ****. Fitment is everything with brushguards (and there are very few I like), so if it fit better on the front, I'd say keep it.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #200 of 565 Old 09-09-2010, 02:33 PM Thread Starter
Erbo1Kanerbo
yeah i took it off lol it wasnt as flush as i wanted it to be. so im still getting some death wobble problems damit. so heres the deal i have this lifetime alignment rotate and balance on my tires so i took it to the place and they aligned it a little more but here it is do you think that any of this will cause my dw? if its not any alignment issues im gonna have to get lower control arms i guess and maybe bushings somewhere idk someone help please haha
ZJ Build thread:
post #201 of 565 Old 09-09-2010, 04:41 PM Thread Starter
Erbo1Kanerbo
should i take it to offroad shop to align it or is there something else causing this problem?
ZJ Build thread:
post #202 of 565 Old 09-09-2010, 04:52 PM
bigb229
whens the last time you had your tires rotated and balanced? if one of the fronts has a bad wear pattern and the other smooth it will cause dw....also im not really sure but imo you right front tire shouldn't have both - camber and - caster. i know they adjust the camber on the right sometimes to help with the crown of the road. but me personally...i like all of my caster and camber to be set evenly. i also like my caster to be more neutral as well...i've got mine around 2 degrees. but every jeep is a little different. but i'd ask about the - caster and - camber if i were you. maybe someone else will chime in.
bigb229 is offline
post #203 of 565 Old 09-09-2010, 04:53 PM
bigb229
uh....oops...by - caster i mean it shouldn't be that much diff than the left side. sorry
bigb229 is offline
post #204 of 565 Old 09-09-2010, 04:57 PM
redfoxbody
What shape are your trackbar bushings in? from what I understand thats one of the main causes. If your control arm bushings are shot thats probably not helping lol
FWIW when I did my 4x4 swap I kept getting dw and I found out it was my trackbar bolt working its way loose on the axle side. Some locktite and its been good since but give it a good crank.
If they aligned it unless the shop that did it was crap I'd think it would be fine?
looking good btw
4.0 2x4>4x4 conversion 3.73, rubicon rims, 245/75R16 mtr 42RE > AX-15 Conversion in progress.
Build thread
Depressed about your car dent? dentszone.com
Nice the legs in that last picture, almost makes you not think about the jeep.
My 16 year old little sister, you creep.
redfoxbody is offline
post #205 of 565 Old 09-10-2010, 10:02 AM Thread Starter
Erbo1Kanerbo
so those numbers on that sheet dont look too bad? also i figured since i got my upper arms i put my front driveshaft back in and it has reduced vibes and it feels alot stronger. ive noticed though that when im going down a hill not giving gas i hear a humming noise also say im going 45 and idleing down a hill my speedomoter will bounce a little bit idk if this is normal or not
ZJ Build thread:
post #206 of 565 Old 09-11-2010, 02:28 PM Thread Starter
Erbo1Kanerbo
bored as **** today so i cleaned my iac my car idles like butter now as everyone else says lol was very easy to do just two torsion bolts on the back of the throttle body and then you pull it off spray wipe spray wipe and your done
ZJ Build thread:
post #207 of 565 Old 09-18-2010, 12:05 PM Thread Starter
Erbo1Kanerbo
alright so i got my tires rotated and balanced and no more dw! im gonna use these tires until i find a good deal on some 31/32's because ive got lifetime rotate balance and alignment. saving up for some other little things to do
ZJ Build thread:
post #208 of 565 Old 09-20-2010, 05:23 PM Thread Starter
Erbo1Kanerbo
mocked up a box with the same dimensions as the Uniden PRO520XL cb im going to buy. it fit perfectly where my vic was. i ordered my 4' firestik anetenna and gonna order the radio once i have the money
ZJ Build thread:
post #209 of 565 Old 09-20-2010, 11:23 PM
bigb229
were still waiting on the flew pics................
bigb229 is offline
post #210 of 565 Old 09-21-2010, 04:16 AM
hawaiianZJ
Originally Posted by Erbo1Kanerbo View Post
pics as promised...ill get some shots of the hids at night. im really impressed with how much light they put out, so much better over stock. they are the 8000k btw
do you remember what brand hid's you got?
hawaiianZJ is offline
Should it be THIS slow? JrMechanic ZJ Grand Cherokee Forum 17 11-30-2008 06:59 AM
slow key EZ1 ZJ Grand Cherokee Forum 4 09-20-2007 11:51 AM
Slow at first... randhi23 ZJ Grand Cherokee Forum 1 09-05-2007 11:26 AM
Slow on Take-off toke ZJ Grand Cherokee Forum 2 08-22-2007 10:20 PM
Will an ARB slow me down? parnell5150 ZJ Grand Cherokee Forum 7 09-06-2006 04:59 PM
