My slow zj build - Page 12 - JeepForum.com
post #166 of 565 Old 08-19-2010, 01:27 PM
squashman702
1994 ZJ
I paid $90 for factory replacements when I had my 5.9, and $135 for XRF heavy duty ball joints for my Laredo. That was for all 4. I think the job took me 3 or 4 hours when I did it for the first time in the winter. If you can put a lift on, you can do ball joints. Really isn't that tough, and there are plenty of writeups available if you need a how-to.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #167 of 565 Old 08-20-2010, 08:17 AM Thread Starter
Erbo1Kanerbo
bit the bullet and just took my car to a shop to get worked on dammit
ZJ Build thread:
ZJ's: If you dont know what it is you cant afford it.
Erbo1Kanerbo is offline
post #168 of 565 Old 08-20-2010, 10:01 AM
bigb229
ooooooo.....let us know how much that hurt. haha. well atleast it will be good to go now.
bigb229 is offline
post #169 of 565 Old 08-20-2010, 01:02 PM Thread Starter
Erbo1Kanerbo
this is what the shop told me
ZJ Build thread:
post #170 of 565 Old 08-20-2010, 01:06 PM
squashman702
1994 ZJ
Couple things wrong with this . . .
-It's going to be less effort to install CA's than ball joints
-Looks like they're charging you twice for the Rusty's CA's
-$99 each for engine mounts is highway robbery
Think Twice Garage
post #171 of 565 Old 08-20-2010, 01:08 PM Thread Starter
Erbo1Kanerbo
im thinking ill get the arms from iro and just put that in myself and ill save like $600
ZJ Build thread:
post #172 of 565 Old 08-20-2010, 01:09 PM Thread Starter
Erbo1Kanerbo
ok what kind of engine mounts do i need theres two so do i get two of the same or is there a left or right. motor mounts from advanced are about $50 a piece
ZJ Build thread:
post #173 of 565 Old 08-20-2010, 01:10 PM
JFox21
They're definitely overcharging you. I'd take it to another shop and get a different quote.
Jamie
Sophomore at Santa Clara University
JFox21 is offline
post #174 of 565 Old 08-20-2010, 01:28 PM
squashman702
1994 ZJ
Advanced should be able to give you the part numbers. I don't think that they're identical. OEM replacements should be fine.
Think Twice Garage
post #175 of 565 Old 08-20-2010, 02:49 PM
AEagle326
i've got a guy that wont charge you an arm and a leg, he does outstanding work, and he has 20 years of AMC experience and is also certified. he does almost all the work on my jeep, if you'd be interested in checking him out. he's off exit 17 on 400, in gainsville.
Andrew
1995 Grand Cherokee Orvis Edition
You can never go wrong with an Orvis.
AEagle326 is offline
post #176 of 565 Old 08-21-2010, 01:17 PM Thread Starter
Erbo1Kanerbo
i found a place today that specializes in grand cherokees. i knew i was in the right place bc right when i walk in theres a painted mural of a 98 5.9 that takes up a whole wall hahaha pretty badass but these people seem really honest and cool. im ordering some iro upper adj. arms, an iro tie rod with rod ends, and maybe a new pitman arm and theyre also doing my upper and lower ball jonts and fixing the seals between my transfer case and trans. jeep should be running real nice after this.
ZJ Build thread:
post #177 of 565 Old 08-25-2010, 02:21 PM
bigb229
is the jeep back? i almost let go of my xbox and made a trip to atl today to trade it for some soft eights...but decided to hold out b/c they were 15's. btw what is the name of this shop so i can put it on my board for future ifs and whens?
bigb229 is offline
post #178 of 565 Old 08-25-2010, 02:24 PM Thread Starter
Erbo1Kanerbo
its at the place right now its called Best Jeep Repair under google its best jeep repair, real cool guys. Im getting the input seal of my transfer case fixed, TRES, pitman arm boot thing, upper and lower ball joints up front. I also just ordered my front adj. upper control arms from iro
ZJ Build thread:
post #179 of 565 Old 08-25-2010, 02:25 PM Thread Starter
Erbo1Kanerbo
im gonna pick it up in the next hour
ZJ Build thread:
post #180 of 565 Old 08-25-2010, 11:15 PM Thread Starter
Erbo1Kanerbo
got my car back today and the steering felt alot tighter and it wasnt as bumpy but i purposely hit a pot hole and i began to feel it fall into the DW. so i hope after i get these new control arms which should be here saturday and an alignment that it will go away and the ride will be good.
ZJ Build thread:
Should it be THIS slow? JrMechanic ZJ Grand Cherokee Forum 17 11-30-2008 05:59 AM
slow key EZ1 ZJ Grand Cherokee Forum 4 09-20-2007 10:51 AM
Slow at first... randhi23 ZJ Grand Cherokee Forum 1 09-05-2007 10:26 AM
Slow on Take-off toke ZJ Grand Cherokee Forum 2 08-22-2007 09:20 PM
Will an ARB slow me down? parnell5150 ZJ Grand Cherokee Forum 7 09-06-2006 03:59 PM
