My build - Expedition Rig - 2003 WJ 4.7 HO - Page 7 - JeepForum.com
 3Likes
post #91 of 1687 Old 12-26-2008, 08:47 PM Thread Starter
theksmith
2003 WJ
Originally Posted by JCDubya View Post
Does the rear sit lower with the Teraflex springs? How do they compare to IRO springs?
the teraflex coils do lift the front more than the rear, which makes the jeep sit perfectly level instead of a slight rake like stock.... however, as soon as you put a full size spare tire and some tools and a jack in the rear... well now it's not level anymore i have a set of spacers to put in the rear to hike it back up a little, just need to get around to installing them
i know nothing about the IRO coils, so can't comment
theksmith is offline
post #92 of 1687 Old 12-26-2008, 08:57 PM Thread Starter
theksmith
2003 WJ
just happen to be out wheeling just north of Scottsdale, AZ today when a freak snow storm came through!
http://picasaweb.google.com/kristoff...26BartlettLake
on a not-as-fun note, one of my IRO front coil spring retainers came loose... then when the spring hit the thing, it bent the sheetmetal where they mount to and stripped it... so now i have to get someone to weld a tube in there or something that will hold up better.
post #93 of 1687 Old 01-07-2009, 03:43 AM Thread Starter
theksmith
2003 WJ
picked up the jeep from the shop today that fixed my spring guides/retainers. they welded a nut to a big washer, then re-drilled the hole in the spring perch big enough for the nut to fit up into, then welded all of that to the perch. they also got some longer bolts for the IRO pieces so they would fully thread into the new nut setup... total cost: welding + nuts and bolts = $70.... not bad, but man i gotta take some time and learn basic welding!
post #94 of 1687 Old 01-07-2009, 03:45 AM Thread Starter
theksmith
2003 WJ
found this in some paperwork and wanted to keep track of it, so i thought i would just put it here!
and no, i'm not the original owner and didn't pay anywhere near that $38,405 sticker price!
post #95 of 1687 Old 01-07-2009, 03:47 AM Thread Starter
theksmith
2003 WJ
and here's my full build sheet with paint codes and such, so i can keep track of that!
Desc: 2003 ? JEEP GRAND CHEROKEE LIMITED 4X4 SPORT UTILITY 4-DR
*XL - Leather Trimmed Bucket Seats
-T5 - Sandstone
ADEP - Cold Weather Group
AFFS - Luxury Group
AHX - Trailer Tow Group IV
APAS - Monotone Paint
ATCP - Radio-CD/Cass/10 Disc/Infinity Spkrs
AWBP - Quadra-Drive 4WD System
A83P - 4.7LHO Eng(EVC)/5spdA/T 5-45Rfe(DGQ)
BAZS - 136 Amp Alternator
BC6S - 625 Amp Maintenance Free Battery
BRYS - Anti-Lock 4-Wheel Disc Brakes
CACS - Low Back Bucket Seats
CBWS - Highline Door Trim Panel
CFNS - Rear 60/40 Folding Seat
CGS - Supplemental Side Air Bags
CGUS - Child Seat Anchor System-LATCH Ready
CG1S - Next Gen Multistage Front Air Bags**
CJ2P - Supp. Side Curtain Frt/Rr Air Bags
CKDS - Floor Carpet
CKNS - Cargo Compartment Carpet
CKTS - Cargo Tie Down Loops
CLES - Front & Rear Floor Mats
CLGS - Covered Cargo Storage
CLHS - Cargo Trim Panel w/Storage Net
CLPS - Door Sill Scuff Pads
CSCS - Cargo Compartment Cover
CSRS - Passenger Assist Handles
CUDS - Mini Overhead Console
CUFS - Full Length Floor Console
DGES - All 5-Speed Automatic Transmissions
DGQ - 5-Spd Automatic 545RFE Transmission
DHAS - Lock-Up Torque Converter
DHFS - Quadra-Trac II On Demand 4WD System
DJJS - Dana 30/186MM Front Axle
DMEP - 3.73 Axle Ratio
DRKP - Dana 44/226MM Rear Axle
DSBP - Vari-Lok Progressive Front Axle
DSCP - Vari-Lok Progressive Rear Axle
EVC - 4.7L High Output V8 MPI Engine
GBBS - Tinted Windshield Glass
GCBS - Front Door Tinted Glass
GEGS - Deep Tint Sunscreen Glass
GEPS - Flipper Liftgate Glass
GFAS - Rear Window Defroster
GNCS - Sun Visors w/Illum Vanity Mirrors
GNKP - Rear View Auto Dim Mirror
GT3S - Power Mirrors, Fold-Away
GWAP - Power Sunroof
GXMS - Remote Keyless Entry
GXXS - Sentry Key Theft Deterrent System
HAFS - Air Cond ATC w/Dual Zone Control
HGAS - Hood Insulation
HGDS - Deluxe Insulation Group
I39S - Route 39 - UP, Phoenix, AZ
JA6S - Electroluminescent Instr Cluster
JCBS - 120 MPH Primary Speedometer
JHAS - Var Intermittent Windshield Wipers
JHBS - Rear Window Wiper/Washer
JJBS - Dual Note Electric Horns
JJJP - 12V Auxiliary Power Outlet
JKAS - Locking Glove Box
JKPS - 12V Auxiliary Power Outlet
JKYS - Power Accessory Delay
JPBS - Power Locks
JPDS - Power Windows, Driver One-Touch
JTFP - Power 10-Way Heated Memory Seats
K4BS - STRIPE/BADGE/MOLDING/COLOR
LACS - Illuminated Entry
LAGS - Warning Chime
LAZP - Vehicle Information Center
LBBS - Courtesy Lamps
LBCS - Glove Box Lamp
LCBS - Door Courtesy Lamps
LCES - Rear Courtesy/Reading Lamps
LDBS - Cargo Compartment Lamp
LETP - Traveler/Mini Trip Computer
LEWS - Radio/Driver Seat/Mirrors Memory
LMBS - Halogen Headlamps
LMGP - Automatic Headlamps
LNJS - Fog Lamps
LPSS - CHMSL Lamp
LSAS - Security Alarm
MDAS - Front License Plate Bracket
MFWS - Bright/Body Color Grille
MHAS - Black Windshield Moldings
MTBP - 4.7L HO Badge
MVAS - Limited Badge
MVBS - Grand Cherokee Badge
MVCS - Jeep Badge
MVEP - V-8 Badge
MWES - Side Roof Rails
MZBP - Quadra Drive Badge
NAS - 50 State Emissions
NBVP - Low Emission Vehicle (LEV)
NFPS - 20.5 Gallon Fuel Tank
NHFP - Power Steering Cooler
NHMS - Speed Control
NMHP - Hydraulic Engine Cooling
PXR - Brilliant Black Crystal Pearl Coat
QXRS - Brilliant Black Crystal Pearl Coat
RAAC - All Radio Equipped Vehicles
RBPP - AM/FM Cass/CD Radio w/Changer Ctrl
RCES - Infinity Speakers
RDDS - Fixed Long Mast Antenna
RDPP - 10-Disc Remote CD Changer
RDZP - Steering Wheel Mounted Audio Ctrls
SBAS - Power Rack and Pinion Steering
SCLS - Leather Wrapped Steering Wheel
SDAS - Normal Duty Suspension
SUAS - Tilt Steering Column
TBLS - Inside Mounted Spare Tire
TBWP - Full Size Matching Whl Spare Tire
TWGP - P235/65R17 BSW AS Perf Tires
TZAP - Goodyear Brand Tires
WGW - 17" Aluminum Chrome Clad Wheels
WLZC - All Aluminum Wheels
XFHP - Class IV Receiver Hitch
XFKP - 7 Pin Wiring Harness
XFLP - 7 to 4 Pin Wiring Adaptor
XGDP - Universal Garage Door Opener
XGM - Tire Pressure Monitoring Display
XPFS - Protective Coating and Remover
YAAS - Build To U S Market Specifications
YEP - Manuf Statement of Origin
YGAA - Without Billable Fuel
ZKGP - Spring - Left Front
ZKYP - Spring - Left Rear
ZYGP - Spring - Right Front
ZYYP - Spring - Right Rear
Z6BP - GVW/Payload Rating
post #96 of 1687 Old 01-07-2009, 06:35 AM
consalvochris
I am really liking your WJ build up, makes me want to sell my ZJ - Just curious, how much $ do you think you have in it right now?
Expedition ZJ
8.8 - 6 inch long arms - 35's
M100 trailer
Spring over lift on 35's
consalvochris is offline
post #97 of 1687 Old 01-07-2009, 01:45 PM Thread Starter
theksmith
2003 WJ
Thanks! it would be depressing to add up everything, especially as the value of the Jeep itself has dropped so much in the past year. I bought it for $12k, then just in the lift and install there is another $3,600. The wheels and tires were nearly $2k. Then all of the little things really add up too, like brake lines, tow hooks, steering stabilizer, tie-rod, rotors, spring retainers, skid plates, headlights, addco, etc. I haven't done lockers, gears or bumpers yet.. those will be the big price tag items eventually.
post #98 of 1687 Old 01-07-2009, 02:00 PM
-Shoey-
2010 KK Liberty
Wow.....hard to beleive it was an almost $40,000 vehicle new.
2010 KK Renegade
USN Jeep Club #115
-Shoey- is offline
post #99 of 1687 Old 01-13-2009, 06:37 PM Thread Starter
theksmith
2003 WJ
silly yes, but i thought it was fun.... since my jeep is kinda Evil (all blacked out and no logos), i made a Decepticon sticker for my shorty t-case knob today:
post #100 of 1687 Old 01-13-2009, 07:27 PM
GibsJeep
Thats cool.........Wait until you see what i decided to go with .
GibsJeep is offline
post #101 of 1687 Old 01-19-2009, 06:12 PM Thread Starter
theksmith
2003 WJ
swaybar disconnect holders:
parts:
(2 feet) 3/32 coated braided wire cable
(4) 3/32 aluminum cable ferrules
(2) Swivel Thumb Clips
(2) eye bolts
(4) washers
(4) nuts
post #102 of 1687 Old 01-19-2009, 06:14 PM
MoonyJohn
^^ Thats a good idea. I like that alot. Nice build!
MoonyJohn is offline
post #103 of 1687 Old 01-19-2009, 07:20 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
parts:
(2) eye bolts
(4) washers
(4) nuts
Nice, almost exactly like mine
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #104 of 1687 Old 01-25-2009, 10:25 PM Thread Starter
theksmith
2003 WJ
actuall lift height
had someone ask me what my center-of-hub to fender measurements are with the teraflx springs:
rear 22.25"
front 23"
i never measured mine stock, but generally accepted wisdom is that stock on the WJ is 18", so that means i netted 5" front and 4.25" of lift rear.
that makes a nice level stance... untill you load the rear. with a full tank of gas, full size spare, lots of tools, recovery gear, and some survival crap in the back, i loose nearly 1" in the rear.
post #105 of 1687 Old 01-25-2009, 10:51 PM
k9popo
Thanks for doing that for me BTW!!!
My Tera springs measure exactly the same...
k9popo is offline
LoD Expedition Tire Carrier Follow-Up... Finulanu Wrangler General Discussion 10 05-30-2011 09:12 PM
***My Mall Ready Expedition Build*** k9popo Grand Cherokee General Discussion 67 12-01-2009 05:19 PM
My 2003 4.7L WJ build... (ok... the wife's WJ) 65Mustangs Grand Cherokee General Discussion 24 06-27-2009 11:26 PM
Distance/Expedition suspension paddingtonbear ZJ Grand Cherokee Forum 8 05-06-2008 05:41 PM
Set up for expedition/ extended travel? DenverCruiser ZJ Grand Cherokee Forum 30 12-02-2005 01:14 PM
