My build - Expedition Rig - 2003 WJ 4.7 HO - Page 55 - JeepForum.com
 3Likes
post #811 of 1687 Old 05-10-2011, 09:19 AM Thread Starter
theksmith
2003 WJ
Originally Posted by Ricochet88 View Post
Do it!!!
i'm trying to talk a friend from CA into coming with me to split some of the cost right now!
theksmith is offline
post #812 of 1687 Old 05-10-2011, 09:19 AM Thread Starter
theksmith
2003 WJ
found this pic that a friend took while we where in CO last year:
post #813 of 1687 Old 05-10-2011, 10:13 AM
Ricochet88
Nice!
Rick "woody"
93 zj wagoneer pkg, 5in iro lift, 33/10.5/15 bfgoodrich km2
my build thread
R.I.P. TROY EDWARDS "bigbluezj94"
Ricochet88 is offline
post #814 of 1687 Old 05-24-2011, 06:37 PM Thread Starter
theksmith
2003 WJ
so really bummed right now as my JK axles are all done but i have horrible vibes that the shop can't seem to get rid of.
before i had some vibes at 75 and bad at 80+. now i have bad vibes at 65 and the jeep is unusable at 75. someone already pointed out that this is probably because i changed to lower gears during the swap, so the driveshafts are spinning faster sooner.
the shop has tried pointing the darn pinion all over the place and the vibes don't go away. they are actually worse when the pinion is at the textbook angle pointing directly at the t-case or a degree under. so far it's at it's best pointing even further down than you would expect.
i'm at a loss. someone recomended going to a double double-cardan shaft, but not sure if there are drawbacks there and it just seems like there must be something that is the "root problem" here. another person suggested double checking the output bearing on the t-case which i will do. shop said get a free-spin hub conversion, but they are only made by one company and require tons of expense and work since you have to change bolt patterns. any other thoughts?
post #815 of 1687 Old 05-24-2011, 06:42 PM
MoonyJohn
What driveshaft are you running now? Just a single u joint shaft? I would assume it would be the ds.. if you got the double cardan, i would think they would disappear?
MoonyJohn is offline
post #816 of 1687 Old 05-24-2011, 06:46 PM
squashman702
1994 ZJ
Sounds a lot like how my TC is acting with my 4.10's.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #817 of 1687 Old 05-24-2011, 06:48 PM
justanotherjpr
If you have single joint shafts the double cardan has no draw backs and will fix you right up.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #818 of 1687 Old 05-24-2011, 07:06 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
I think he already has a DC DS F&R - am I correct? What "people" were suggesting is a DC at both ends of the DS. You shouldn't have to do that.
1) If you have a vibration with your old setup, you were wearing on your u-joints. They might be due for a repair.
2) Try removing the F&R drive shafts (individually of course) and see if you can isolate where it is coming from.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #819 of 1687 Old 05-24-2011, 07:19 PM
Shinobi
I did have some vibs when I first did the swap, well still do but it isn't bad .. with my front DS disconnected , I still got vibs and it added major DW... So I am going to have them rebalanced my DS before GSW
but I would try what arlo said.
Shinobi is offline
post #820 of 1687 Old 05-24-2011, 08:07 PM Thread Starter
theksmith
2003 WJ
the driveshafts are both brand new double-cardan 1350s done at same time as swap. i should have posted this the first time - but when the front is removed, there is aboslutely NO vibes - so yes we have the issue somewhat isolated.
the old setup that had some vibes was with double-cardan 1310s, again they were done brand new at the time of my first axle swap, and also removing the front would make it drive with no vibes then too. i had the front re-balanced TWICE to make sure that wasn't the problem, then gave up.
if anything, i would have expected my vibes to go away due to the new axles being hi-pinion and therefore having less angle on the front shaft.
since nearly everything (both driveshafts and both axles, gears, etc) has changed twice now except the t-case - i'm leaning towards there being a t-case front output issue. it is a used 242HD with like ~50k miles on it. other than output bearing, what inside the case could affect the front only? can the output shaft be bent, how likely would that be really? are there certain internals that i could have put back together wrong when i did the SYE?
and arlo is correct - the one suggestion was to put in a double-double-cardan in the front. but i feel like this would be just fixing a symptom and not the root cause.
post #821 of 1687 Old 05-24-2011, 08:41 PM
ArloGuthroJeep
Mr. Hyde!
Your drive shafts are interchangeable aren't they? Try swapping them around. That'll eliminate the DS as the culprit.
post #822 of 1687 Old 05-24-2011, 11:31 PM
ReconZJ
ReconZJ's Avatar
OK, I'll throw in my $.02 here, with the caveat that I'm only attempting to resolve any doubts you have about what you already know. It seems you've systematically and logically isolated the problem area. So with that said, here goes:
I agree that you've isolated where area the problem lies.
OK, you had this problem with your former axle setup, and with the front ds removed, didn't have the problem. That seems to confirm your first point above. Also, assuming you had a reputable shop do your driveshaft work, I wouldn't think ds balance is the problem. And I believe you most likely did source a reputable shop do this work, after reading all your posts on your build. So again, my guess is that this is not the problem area.
I agree, but since you did have a vibration problem with your old setup, and you've now corrected (or changed) your driveline angels, it now appears that driveline angles weren't the real problem. Of course, you wouldn't know that until you got to this point, with new axle assemblies and corrected (lessened) angles.
Well, I haven't broken into a tc, so I can't directly give any input from that perspective. However, based on the above history and the things you've already done to troubleshoot this problem, I'd say that there was something wrong with that tc as a component in your old setup, and the problem was not related to driveline angles. Was there something wrong before you swapped the SYE? I think that's the probably source of the problem, and that's where I'd start checking. Did you put it back together incorrectly when you did the SYE swap? Well, I suppose that's possible too, but that would only have exacerbated an existing problem. That's where I'd begin - pull the tc, dissassemble and inspect the internals, starting with the front output shaft.
Definitely agree with this - although, Arlo's suggestion may work, I think you really want to figure out what the root problem is, not cover it up with a "work around".
'14 WK2 Summit 3.0 CRD Deep Auburn Pearlcoat
'97 ZJ - lifted, locked & loaded
'81 280ZX - original condition, p/t DD, weekend cruiser
'72 240Z - in storage, needs everything
'02 S10 Xtreme - for sale soon
ReconZJ is offline
post #823 of 1687 Old 05-25-2011, 05:06 AM
patrick983
have you measured the angle at the t case end? ill tell you this in hopes to help: when i put my winch/bumper on the nose of my jeep sunk almost an inch, which pointed my tcase more toward the axle. im almost vibe free. im making a spacer for the t-case crossmember mount to raise it 1/4 in, to further help the angle put on the dble cardan at the transfer case. ill also tell you when i replaced the u joints in my shaft they showed no play, but it helped the vibes greatly. i was desperate as i just had to start dd'ing my wj on the highway. now i dont really get any vibes, very very minor at ~55 but goes away
2000 White V8 WJ LSR-6in-35's-LA's-242HD-Warn SOLD and missed very badly
06 GTO - BC Coilovers, JBA Catless mids, Svede Intake
patrick983 is offline
post #824 of 1687 Old 05-25-2011, 07:07 AM
ArloGuthroJeep
Mr. Hyde!
You can also remove the front drive shaft and spin both the output shaft and the pinion and check for a wobble in there. If you had a runout gauge that would be best.
post #825 of 1687 Old 05-25-2011, 09:45 PM
Ricochet88
Worst case scenario take the front DS out drive to moab the put it back in when you get there wont take you too long to pull it out and put back in. Once your there you wont be going 60+MPH so you'll be vibe free
Rick "woody"
my build thread
LoD Expedition Tire Carrier Follow-Up... Finulanu Wrangler General Discussion 10 05-30-2011 09:12 PM
***My Mall Ready Expedition Build*** k9popo Grand Cherokee General Discussion 67 12-01-2009 05:19 PM
My 2003 4.7L WJ build... (ok... the wife's WJ) 65Mustangs Grand Cherokee General Discussion 24 06-27-2009 11:26 PM
Distance/Expedition suspension paddingtonbear ZJ Grand Cherokee Forum 8 05-06-2008 05:41 PM
Set up for expedition/ extended travel? DenverCruiser ZJ Grand Cherokee Forum 30 12-02-2005 01:14 PM
