My build - Expedition Rig - 2003 WJ 4.7 HO - Page 4 - JeepForum.com
 3Likes
post #46 of 1687 Old 07-04-2008, 07:54 AM
MuddyLuxury
MuddyLuxury's Avatar
i lifted mine higher than that write up, so i had to cut a section of the frame rail and re-enforce it in a half moon dip.
I can take pictures and send them to you if you PM me an email addy
-Jeb
99 WJ 4.7V8 selc-trac swap
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
in the works... lots deployments are great for jeep budgets
Go Doorless!
Things i need..
good spots in the mid atlantic to camp, hike, fish, kyak and wheel, if you know please share
Originally Posted by 5.9 ANDY
i would do the rear.
MuddyLuxury is offline
post #47 of 1687 Old 08-28-2008, 01:46 AM Thread Starter
theksmith
2003 WJ
installing IRO rear bump-stop extensions
i did this a while back, thought i would post a mini write-up for anyone that might be planning to do it.
make sure you use jackstands and do everything safely and don't blame me if anything goes wrong...
first, disconnect one link of the rear sway-bar (if you have one still), this makes it easier to articulate the axle with the jack.
use spring compressors to squeeze the coil down enough that you can get it off the bump-stop. i used the jack to first squeeze the coil a lot, so i didnt' have to run the spring compressors down manually except the last few turns, then let the jack back down.
pray that the cheap harbor freight spring compressors don't break. lay the coil out of the way, never let it point at your body/head.
spring's out.
drill as straight as you can up into the bump-stop hit plate. i used a 27/64" bit, worked for me. thre is a dimple in the center of the plate already, so the drill will self-center. i bought a cheap right-angle ryobi drill since i already had some other ryobi tools/batteries/chargers. the metal is fairly thin and will drill fast. the right-angle drill comes in handy for other things like mounting rock-rails.
tap the hole using a 7/16" - 14 (coarse) tap. again i just used a cheap harbor frieght tap & die set, but it worked fine for this. just remember that the tap's are hardened and therefore brittle, so don't put any side stress on them. if you brake it off in there, you will have a hell of a time drilling it out. move in a few threads at a time, then back out a couple turns and then back in.
here is the IRO bump-stop extension, i put the mounting bolt inside it, then taped over the end to keep the bolt from falling out as i dropped the whole package into the coil later.
here is the coil back on the perch, with the extension and mounting bolt dropped into the spring. i went ahead and put some threadlock on the threads of the bolt just before i dropped all this back in. the allen wrench needed is a 3/8".
again i used the jack to squeeze the coil and take most pressure off the spring compressors. loosen the last little bit of tension from the compressors, then remove them.
let the jack and axle down as far as you can, so that there is a large amount of space between each coil turn. then you can get your fingers into the coil enough to turn the extension and bolt to get it started. then you may have to raise the axle just a little to find a good point at which your allen wrench will fit between a space in the coil. tighten it up good!
rinse and repeat for the other side, put your sway-bar link back on, wheels/tires, and you're done.
theksmith is offline
post #48 of 1687 Old 08-28-2008, 05:09 AM
NewJeepFever
Ok, I have got to know, what wheels are those, they are beautiful!
NewJeepFever is offline
post #49 of 1687 Old 08-28-2008, 10:32 AM Thread Starter
theksmith
2003 WJ
thanks, 17"x8" eagle alloy 140's
post #50 of 1687 Old 09-05-2008, 01:43 PM Thread Starter
theksmith
2003 WJ
custom exhaust to work with claytons arms
ok, so i finally got my exhuast finished. i know everyone has a different take on how to accomplish an exhaust with the clayton long arms, so here's mine:
I used the following parts...
(1) 2.5" ring clamp
(1) 2.5" ID to 3" OD adapter/reducer
(1) Magnaflow high flow 3" converter
(1) Flowmaster 50 Delta Flow muffler (3" center inlet, offset outlet)
(1) 3" ring clamp
(1) 3" mandrel bent turn-down
(1) muffler hanger from ebay:
(2) self-tapping bolts
(1) can high-temp ceramic header paint
i had to trim every piece down 1/2" to 1" to make it all fit. used a dremel to notch the adapter inlet to match the original pipe, bent the hanger with a hammer and vice, then just took it all too a guy to weld it up clean for me, painted it with header paint, then i clamped and bolted it down.
these are the type of quality ring clamps i used, they make a tight, even, crimp on the fittings (instead of crappy u-bolt clamps):
i clamped instead of welding the final turn-down in case i have any problem with emmisions and have to temporarily run a flex tube out to the back of the truck to pass.
post #51 of 1687 Old 09-05-2008, 02:07 PM
WJChris
WJChris's Avatar
found it........
( I was asking about the gas tank lift thread.. heh sorry.)
WJChris is offline
post #52 of 1687 Old 09-05-2008, 02:24 PM Thread Starter
theksmith
2003 WJ
Originally Posted by WJChris View Post
found it........
post #53 of 1687 Old 09-05-2008, 06:37 PM
GibsJeep
Nicely done ksmith .
GibsJeep is offline
post #54 of 1687 Old 09-20-2008, 10:20 PM Thread Starter
theksmith
2003 WJ
just updating the thread with a link to my "removable rear seat bottom" thread:
http://www.jeepforum.com/forum/f310/30-minutes-more-cargo-room-wj-608241/
should have some other updates soon, ordered everything to do the cb antenna install, and ordered LED replacement bulbs for the entire interior. also went wheeling and shot out a front spring, so ordered a couple more goodies from IRO to keep that in check.
post #55 of 1687 Old 09-24-2008, 09:00 AM Thread Starter
theksmith
2003 WJ
a little more test wheeling and lost a spring again, here's the video... http://vids.myspace.com/index.cfm?fu...deoID=43426923
parts on the way from IRO already, spring hold-downs and retainers:
post #56 of 1687 Old 10-20-2008, 11:49 AM Thread Starter
theksmith
2003 WJ
well it's not a mod, but this gives me more money for WJ mods... and it's my thread, so i'll post a goodbye to my XJ that sold friday... Farewell old reliable!:
post #57 of 1687 Old 10-30-2008, 12:19 AM Thread Starter
theksmith
2003 WJ
finally got my brake hose issue resolved this past week, i had parkerstorephx.com make me some longer fronts, went steel braided as it only added like 10 bucks:
the rear was fine on length, but i had them do a new one as long as i was at it:
changing anyting to do with brakes is a messy PITA!
post #58 of 1687 Old 11-04-2008, 03:38 PM Thread Starter
theksmith
2003 WJ
i don't think i've posted a pic since i put on the JKS supernerfs a while back:
only downside is they make the jeep look lower!
post #59 of 1687 Old 11-04-2008, 03:41 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Looking good
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #60 of 1687 Old 11-04-2008, 03:42 PM Thread Starter
theksmith
2003 WJ
and here's a closeup of the new grille:
i purchased some raw material from grilleguy.com, then fabbed it up. kinda a pain in the *** to install, and we'll see if it holds. let me know what you think, i like it better than stock at least.. not sure if i'll keep it long term or try something else.
LoD Expedition Tire Carrier Follow-Up... Finulanu Wrangler General Discussion 10 05-30-2011 09:12 PM
***My Mall Ready Expedition Build*** k9popo Grand Cherokee General Discussion 67 12-01-2009 05:19 PM
My 2003 4.7L WJ build... (ok... the wife's WJ) 65Mustangs Grand Cherokee General Discussion 24 06-27-2009 11:26 PM
Distance/Expedition suspension paddingtonbear ZJ Grand Cherokee Forum 8 05-06-2008 05:41 PM
Set up for expedition/ extended travel? DenverCruiser ZJ Grand Cherokee Forum 30 12-02-2005 01:14 PM
