My build - Expedition Rig - 2003 WJ 4.7 HO - Page 12 - JeepForum.com
 3Likes
post #166 of 1686 Old 02-25-2009, 11:20 PM
nelson1248
what is the difference from that and a CB? why not run either or instead of both? what is a ham used for anyways? is it better thatn having a CB if so why not ditch the CB and stick to the ham?
sorry for all the questions just trying to understand what i dont know!
MOPAR or NO CAR
nelson1248 is offline
post #167 of 1686 Old 02-25-2009, 11:29 PM Thread Starter
theksmith
2003 WJ
hey no problem,
well the world of ham can get complicated, but it basicly boils down to many people don't have ham radios because you have to take a little test and get a license or because they just don't know about them or because they can be more expensive... so you pretty much have to keep your cb to talk to the average guy on a club run.
they are better than cb for so many reasons, better sound quality, much more power means talking longer distances, with the right setup you can talk around the world! there are even auto-patches in some locations that will let you tie into the phone lines and make phone calls from the radio!
theksmith is offline
post #168 of 1686 Old 02-25-2009, 11:37 PM
nelson1248
wow sound like quite some steroids for a radio!
well i been looking into getting a cobra 75 any details on this CB?
cons and pros on this?
is it mandatory that you get a license to work a ham or could you operate it with out a license? what are the consequences of operating a ham with out a license?
is there any? or is the license just pretty much like a i know how to use a ham kinda deal?
MOPAR or NO CAR
post #169 of 1686 Old 02-26-2009, 07:12 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
The FCC comes and tracks you down...then they arrest you.
So no, you can't operate one w/o a license. You can monitor ham frequencies w/o a license though.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #170 of 1686 Old 02-26-2009, 10:04 AM Thread Starter
theksmith
2003 WJ
Originally Posted by nelson1248 View Post
...well i been looking into getting a cobra 75 any details on this CB?
cons and pros on this?...
the correct install of good wiring and good antenna willl make more difference than anything else including how expensive the cb itself is. readup on firestik.com about antennas, wiring, ground planes, etc.
if space is an issue the Cobra 75 WXST is certainly your best bet. I know several people in local clubs with them and they work great.
i personally have a Midland 75-822 and it has been a great compact radio for me. i originally bought it becuase it worked as a handheld as well as vehicle mount, this allowed me to use it even before i had a real antenna.
the only reason i would recommend the Cobra over the Midland is that the Cobra has an external speaker connection on it's base. otherwise, the Midland is a more flexible and IMO better looking unit.
and with that, i'm getting in the jeep and headed west now... peace!
post #171 of 1686 Old 02-26-2009, 10:22 AM
Shinobi
Originally Posted by WJ Freak View Post
How about this? I had DW after my lift, so my mechanic threw on a Rancho stabilizer when he was doing the realignment for me, which didn't stop the DW. I swapped it for Kevin's Hard-KOR stabilizer, but I still had DW on a highway on my way to work, in the exact same spot every day, when I was going over 60 mph. Now, this was before I got my M/Ts, so my Revos were probably fairly out of balance, but I decided to use the Rancho stabilizer I was going to return, as a secondary and fabricate my own mounting brackets. Here's the result:
I got all of the parts for less than $30 at Lowe's. This set-up is amazingly sturdy. It's made up of all grade 8 steel. I always check it before, during and after 'wheeling to make sure it doesn't loosen up or shift. It hasn't budged since I installed it almost a year ago and have been 100% DW-free. I have a full write-up on the install, if you need it.
Nice I would really like to know how you did that !!! great job man
Shinobi is offline
post #172 of 1686 Old 02-26-2009, 10:21 PM
WJ Freak
Originally Posted by Shinobi View Post
Nice! I would really like to know how you did that !!! great job man
Thanks! Well, here goes...
This may sound a bit strange, but I went to Lowe's, looking for some kind of clamp and wound up getting 2 pipe clamps that you'd use to seal holes in pipes. They're flexible but strong, combining metal and brass with a rubber inner lining, which wound up gripping the tie rod and track bar very well. I felt they'd be plenty strong for the task of stabilizing with the Rancho. The beauty of them is that they'll fit any size track bar. I then found some grade 8 bolts that fit and were long enough to close up the ends of each bracket and connect the Rancho. Make sure your stabilizer has sleeves at each end. They may be too big for the bolts, in which case you'll need additional smaller diameter sleeves to go in each end. You may have to tap them into place. I then got about a dozen large washers, 4 lock washers and a few grade 8 nuts with the locking plastic inner lining.
Mounting was a little tricky, keeping the clamps tight while I tightened each of the stabilizer ends. The trick I found was using enough large washers, which fit perfectly into the two prongs on either side of the clamps. I stacked 2 on either side of each clamp and 1 on each side of the stabilizer mount ends (so 2 per end). Here's the order for each mount: bolt, 2 washers, clamp, clamp, 2 washers, washer, stabilizer end, washer, lock washer, nut. The bolts you get should be long enough for at least an inch of extension after everything is tightened up. I believe I got 6" bolts.
For positioning, see my photos and/or the photos on Kevin's site where he shows his dual setup. Here's a link to my thread:
http://www.jeepforum.com/forum/showt...=433984&page=2
That's about it. Let me know if you have more questions or want some additional pics.
I had actually thought about putting a kit together and selling it to guys here. If I did, I'd make some illustrated instructions too. Do you think $60 shipped would be a fair price?
Thanks,
Todd
!!!!!!!FOR SALE!!!!!!!! '02 WJ Graphite Limited 4.7 with all options; IRO 5.5" coils; JKS U/L CAs; RK Adj. TB; MX-6; JKS Discos; JKS BPEs; Hard-KOR SS; KOR Endlinks; Rear Addco; IRO A-arm spacer; BS Ext.; Ext. SRs; 255/75-R17 BFG M/Ts; 17" Chrome Torque Wheels; SpiderTrax; Westin Safari Bar; KC 600 Series HiLites; Rock Rails; Smittybilt TL Guards; Smittybilt Blk Hitch Shackle w/Lock; H.O. Intake/Spectre Cone Filter.
WJ Freak is offline
post #173 of 1686 Old 02-27-2009, 06:45 PM
MEinSoCal
hey WJ FREAK, i'm also very interested in your parts list and write up. i do have the rancho SS as well, but because my mounts are all bents, it seems like my steering stabilizer is not really working the way it should be. looking forward to your follow up pics!
MEinSoCal is offline
post #174 of 1686 Old 02-27-2009, 07:57 PM
malibubts
Nice rig!
Quick question though. Your headlights look a little different, did you remove the yellow reflectors on the sides and bottom. ?
malibubts is offline
post #175 of 1686 Old 02-27-2009, 08:13 PM
-Shoey-
2010 KK Liberty
They're clear ones, you can get em off ebay, I've got them too.
2010 KK Renegade
USN Jeep Club #115
-Shoey- is offline
post #176 of 1686 Old 02-27-2009, 08:39 PM
malibubts
Have you ran into a cop related issues with them because the signals aren't yellow?
post #177 of 1686 Old 02-27-2009, 08:43 PM
SET2JET
just use amber bulbs instead of clear
SET2JET is offline
post #178 of 1686 Old 02-27-2009, 08:43 PM
-Shoey-
2010 KK Liberty
The bulbs are the legal amber, but you don't need the amber reflectors. And I'm in Ohio a lot, and don't have any issues.
2010 KK Renegade
USN Jeep Club #115
-Shoey- is offline
post #179 of 1686 Old 02-27-2009, 08:46 PM
malibubts
Alright. Thanks for the info. I really like that look that taking those reflectors out gives, plus my housings are filled with junk and could be replaced.
post #180 of 1686 Old 02-27-2009, 08:49 PM
-Shoey-
2010 KK Liberty
You can either take em apart, or go on ebay and score you a set. I don't think if you take them apart that you can get the amber in the upper edge out, but I'm not 100% sure on this.
2010 KK Renegade
USN Jeep Club #115
-Shoey- is offline
LoD Expedition Tire Carrier Follow-Up... Finulanu Wrangler General Discussion 10 05-30-2011 09:12 PM
***My Mall Ready Expedition Build*** k9popo Grand Cherokee General Discussion 67 12-01-2009 05:19 PM
My 2003 4.7L WJ build... (ok... the wife's WJ) 65Mustangs Grand Cherokee General Discussion 24 06-27-2009 11:26 PM
Distance/Expedition suspension paddingtonbear ZJ Grand Cherokee Forum 8 05-06-2008 05:41 PM
Set up for expedition/ extended travel? DenverCruiser ZJ Grand Cherokee Forum 30 12-02-2005 01:14 PM
