My 5.9 Build Thread (finally) - Page 4 - JeepForum.com
post #46 of 232 Old 06-05-2011, 06:21 PM
Greengc4x4
Originally Posted by ZJ5point2GCL View Post
I got them from rough country, but there are other companies that make them too, i just got the rough countries because i figured the braces had a better chance of fitting.
they are just upfront, since cherokees are leaf sprung. but they are aren't necessary in the rear, like how people just have front long arms. since the rear axel trails the CA's and the CA's are longer than the fronts to start with, having the rear arms at a steep angle really doesn't matter a whole lot, well at least compared to the front.
they drop both upper and lower CA's down the same amount so the geometry stays the same, it basically cancels out a 4.5'' lift by just moving everything down a bit. the bracket ties the uppers and the lower mounts together.
you can find out at lot about them in the XJ forums.
I understand how they work I asked about the rear, because I wonder if the front lowers would work in the rear as well?
The reason most people only have front long arms because they cant afford or dont have the means to truss the rear axle and change teh suspension around that much. Front long arms are bolt in for the most part.
Greengc4x4 is offline
post #47 of 232 Old 06-05-2011, 06:56 PM Thread Starter
ZJ5point2GCL
I doubt they'd work in the rear, unless some how it has the same spacing as the front. But I don't think it is.
The upper and lower is all attached, it's not two separate brackets.
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #48 of 232 Old 06-05-2011, 08:36 PM
Greengc4x4
Ohhhh, well that sucks. lol
post #49 of 232 Old 06-08-2011, 01:19 AM Thread Starter
ZJ5point2GCL
Got a new windshield installed today, its and extra thick one, and its noticeably quieter on the highway. Its also amazing how pitted a windshield can get in 8 months.
Also Changed the filter, adjusted the bands and fresh ATF. To my relief the pan was extremely clean, almost nothing on the magnet. Made a hell of a mess, i mean like it looks like a massacre under my jeep, dropping the trans pan is horrible. Why can't it be like my trucks with a spin on filter and a magnetic drain plug.
post #50 of 232 Old 06-10-2011, 12:16 AM Thread Starter
ZJ5point2GCL
Did this
http://www.jeepforum.com/forum/f13/2...e-fix-1225426/
and made a mini write up
also changed my track bar bushings, i got a bad batch or something from IRO and they were super soft.
post #51 of 232 Old 06-10-2011, 12:51 AM
ZJ_flexxxer
1994 ZJ
hey man i'm interested in how you did your control arm brackets. i see you used them on the front, but what about the back? i'm still on short arms and i'm on a tight budget, i really can't afford LA's so those brackets have got me thinking
MY OTHER TOOLBOX IS A JEEP
94 ZJ Laredo--lifted 4.5", rocker rails, front end/t-case/gas tank skids, tube doors, wj knuckle/brake swap, soft 8's, 32x10.50 tsl's
87 MJ Comanche--zj d44 rear w/ disc brakes, wj knuckles/brakes w/ drilled & slotted rotors,6" lift in progress
90 XJ Laredo--D.D., satin black paint job, 15" ecco's, the redheaded step child of my jeeps
87 XJ Wagoneer--R.I.P. =(
ZJ_flexxxer is offline
post #52 of 232 Old 06-10-2011, 01:49 AM
WhiteOut
WhiteOut's Avatar
I think he is on short arms in the back, all adjustable. I haven't had any issues with flex in the back with adjustable short arms.
WhiteOut is offline
post #53 of 232 Old 06-10-2011, 08:09 AM Thread Starter
ZJ5point2GCL
The rear just has 4 adjustable CA's
There arnt any available for the rear that I know of since they are intended to be used with XJs and they are leaf sprung.
But they really are not needed. Since the rears have longer CAs to begin with. And since the axel trails them the angle of the CAs can be much steeper than the front without cause ride or flex issues.
post #54 of 232 Old 06-10-2011, 11:01 AM
ZJ_flexxxer
1994 ZJ
yea thats what i pretty much figured, thanks for the info though. and one hell of a job on this niner
post #55 of 232 Old 06-10-2011, 01:19 PM
tato1111
Any more info on that front driveshaft adapter? ive never heard of such a thing.
White zj 6in. 33x12.5 1995
<--Mods in profile
tato1111 is offline
post #56 of 232 Old 06-10-2011, 07:08 PM Thread Starter
ZJ5point2GCL
Check out my other thread http://www.jeepforum.com/forum/f13/d...shims-1150577/ post #20 on.
That should give you everything you need to know. but let me know if you have any more questions.
post #57 of 232 Old 06-10-2011, 07:13 PM Thread Starter
ZJ5point2GCL
Installed 4 new door speakers (again) this time aftermarket. sounds much better, now has some bass which was pretty damn novel for the stock infinitys
Just drove it to red deer and back and only averaged 12 MPG, but i was on the Albertan autobahn average speed was 85-90 MPH and there was a cross wind you could barely stand up in, so not too bad all considered.
post #58 of 232 Old 06-10-2011, 07:17 PM Thread Starter
ZJ5point2GCL
post #59 of 232 Old 06-10-2011, 09:18 PM
SnowLeopard
What brand speakers did you get? I love Polk myself, but the blasted rubber surrounds are damaged thanks to the audio shop installers. I didn't know enough about what I was doing back when I had it installed to do the speakers myself. I should have done so. They used a type of self-tapping screw with a flat, washer-type surface that ate into the surround and over time tore into it, splitting it. The speakers will rattle sometimes, but still work pretty well. I just need to get some type of repair kit for them one of these days.
12mpg at 85-90mph in a 5.9 doesn't sound bad at all. I'd get less than 12mpg on a calm day on flat terrain going that speed with the 4.0.
SnowLeopard is offline
post #60 of 232 Old 06-11-2011, 12:13 AM Thread Starter
ZJ5point2GCL
I bought some Audio Research's. no idea if they are any good, i bought them last minute since i was driving up to red deer today, i thought i'd just stick em in.
Sucks about your speakers, but at least you didn't go to best buy, and them duct taping them in because they aren't the right size. They did that to my other jeep with some JL's
depending where you speaker is damaged, black RTV works really well to repair them
Sounds kinda dumb, but theses jeeps don't have converter box thingys for the steering wheel controls that i know of, and i hate the look of after market decks unless its like a double din touch screen type. most of them just look ricey. but i am pretty happy for now.
i am pretty impressed with how well the jeep drove at speed. i could do 90 all day very comfortably. steering was easy no white knuckling. even with 70 MPH wind gusts it was very composed. and the power from the little V8 is incredible.
i don't think my ford would even do 12mpg at those speeds, plus it would only have 10 more MPH before it hits the governor, needs a chip bad. but i am happy with it, next time, i am going to put the 91 tune on, since every last FT/LBS and BHP counts
Finally a build thread!!!!-cache-..project wannabe pre-runner!! -cAcHe- Grand Cherokee General Discussion 209 12-28-2014 05:30 PM
Volcom02WJ's Finally got around to it build thread!!!! Volcom02Wj Grand Cherokee General Discussion 81 05-05-2012 03:38 PM
vansskaterfreeks 5.9 build thread... finally vansskaterfreek Grand Cherokee General Discussion 23 05-20-2010 08:00 PM
Dillonzjs 1995 5.2 build thread finally has a small lift lol Dillonzj Grand Cherokee General Discussion 318 04-17-2010 11:31 PM
97casteeltj's build thread (finally) 97casteeltj Wrangler General Discussion 42 10-29-2008 10:43 AM
