My 5.9 Build Thread (finally) - Page 3 - JeepForum.com
post #31 of 232 Old 05-23-2011, 11:30 PM
aircruiser
aircruiser's Avatar
sick dude! you are right about the rims, they look sick on the jeep in that last pic. i like that wheel idea too. i want to order a set of MB chaos wheels for my jeep but dont want to run them in the winter and end up looking all nasty and corroded like my stock ones. guess ill just have to hit up the wash once a week in the winter haha
aircruiser is offline
post #32 of 232 Old 05-24-2011, 01:27 AM Thread Starter
ZJ5point2GCL
we have similar winters as you, and the salt really doesn't affect them that much, nothing like it did to the factory wheels on my other jeep, but i do wash it at least twice a week in the winter, offroading with wheels like that are going beat them up, but in a year or two i'll get get them powder coated flat black.
Would you get the black MB Chaos? discount tire has them pretty cheap, i bet they'd look pretty good on your white jeep.
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #33 of 232 Old 05-24-2011, 09:58 AM
aircruiser
aircruiser's Avatar
yeah man the black ones..i work at discount tire so ill get them dirt cheap
post #34 of 232 Old 06-02-2011, 10:35 PM Thread Starter
ZJ5point2GCL
what size would you get them in?
and i am jealous how close you live to iron rock, for me the closest decent off-road shop is umm iron rock. actually Kevin's might be a little closer
post #35 of 232 Old 06-02-2011, 10:39 PM
aircruiser
aircruiser's Avatar
hah yeah its convenient but sucks cause im like "oh, ill just go pick up the parts at IRO, **** there goes a paycheck" lol
and im thinking of some 15x8s. not sure though i have some ravines going on tomorrow with my new KM2s
post #36 of 232 Old 06-02-2011, 10:54 PM Thread Starter
ZJ5point2GCL
well not a very exciting update, but i still got some stuff done to it recently.
Last weekend i lengthened my lower CA's 5/8ths of an inch, now my pinion is slightly below the u-joint, but only slightly vibrates off the gas coming down from 100mph or so, so i can put up with it. Now i should have at least factory caster with the offset ball joints.
My alternator only lasted a week and half, now the bearing is squealing like i ran over a cat. so i am going to call some stealerships and see if anyone has a proper new 150 alternator in stock.
Today i put my e3 plugs back in, much smoother idle and allot quieter, and better low rpm power. so i will be keeping in this time.
This is also the first time i used a torque wrench, it was a huge pain in the ***, but i have never tightened any plug this much. spec in the FSM was 30FtLBS which really is allot of torque on a standard ratchet .
I will be spending a week or two in phoenix this summer and considering getting some bilsteins from kolak. Any input?
i had some on the 9er when it was stock, and i wasn't a big fan, but i have heard good things about them on lifted jeeps.
post #37 of 232 Old 06-02-2011, 10:57 PM
SnowLeopard
You can get that alt from Kolak for less than a stealership will charge. It works on the 4.0, too. Ask me how I know. :P
What are the e3 plugs? I don't think I've ever heard of those.
I want your Jeep, man. I really like the work you've done. The control arm brackets you used for an XJ really is an ingenuitive idea. I want you to live closer so you can help me out with my Jeep.
SnowLeopard is offline
post #38 of 232 Old 06-02-2011, 11:24 PM Thread Starter
ZJ5point2GCL
I can get near cost on the alternator, and its going to be an exchange/ warranty through napa. but i would be getting it through kolak otherwise.
was yours new or remanned?
They have an open ground cage, so the spark is kinda projected and not blocked by the ground strap. people either love them or hate them, i really like them, and they are great in LS motors. they have been shown to increase cylinder pressure and a bunch of other good things, Spikes horsepower tested them in an LS and used less fuel to make 5 more HP or something.
I did some testing in my other jeep with them vs new champions. and it was clear how much better they were. i took them out of this jeep because of my MSD box, i just put some .50 gapped autolites, i was hoping a bigger gap might help performance, but i ended up loosing 1mpg across the board, an my idle was nowhere near as smooth. The e3's seem to play well with the high out put ignitions, from all the research ive done.
Plugs are cheap, so i don't mind experimenting with them a bit.
Thanks, I am pretty happy with hows it coming along the second time.
I am still very happy with the drop brackets, a friend and i were talking about how jealous we were of XJ guys having that option over radius arms, and i kept thinking about it, and even though everyone said they wouldn't work. i figured pretty much all the front end ZJ and XJ stuff is the same, i had nothing to loose (other than a bit of cash)
And hell they are even a great jacking point
What part of texas do you live in? i'll probably be in dallas area this summer with my jeep
post #39 of 232 Old 06-04-2011, 11:53 PM
WhiteOut
WhiteOut's Avatar
So the shaft from a 1995 V8 will fit fine? Where in town can I get the flange adapter?
I bought some things that I'll pick up on Monday. So I need to go out and test them.
WhiteOut is offline
post #40 of 232 Old 06-05-2011, 01:28 AM Thread Starter
ZJ5point2GCL
i just checked my other thread on it, i got it from a 1995 4.0 ZJ
and pats driveline near blackfoot has the adapters on stock (usually) they should know what your talking about, if not i should have the part numbers in that other thread.
Also how are you liking your bilsteins? i might pick up a set from kolak when i am in Phoenix.
post #41 of 232 Old 06-05-2011, 01:36 PM
WhiteOut
WhiteOut's Avatar
I really like them, they seem to work a lot better at the higher lift height so you'll be fine. The only problem is they get dirty really fast since the city puts down tons of calcium chloride on the roads.
WhiteOut is offline
post #42 of 232 Old 06-05-2011, 02:15 PM
Greengc4x4
A trick to keeping wheels looking good through winter. Coat them in grease. After winter, give them a good cleaning to remove the grease. Theyll look good as new
Greengc4x4 is offline
post #43 of 232 Old 06-05-2011, 02:17 PM
Greengc4x4
Where did you get those drop brackets? Do you have them front and rear? Upper and lower?
post #44 of 232 Old 06-05-2011, 05:43 PM Thread Starter
ZJ5point2GCL
Thats what i was hoping.
where did you get yours from?
post #45 of 232 Old 06-05-2011, 05:51 PM Thread Starter
ZJ5point2GCL
I got them from rough country, but there are other companies that make them too, i just got the rough countries because i figured the braces had a better chance of fitting.
they are just upfront, since cherokees are leaf sprung. but they are aren't necessary in the rear, like how people just have front long arms. since the rear axel trails the CA's and the CA's are longer than the fronts to start with, having the rear arms at a steep angle really doesn't matter a whole lot, well at least compared to the front.
they drop both upper and lower CA's down the same amount so the geometry stays the same, it basically cancels out a 4.5'' lift by just moving everything down a bit. the bracket ties the uppers and the lower mounts together.
you can find out at lot about them in the XJ forums.
Finally a build thread!!!!-cache-..project wannabe pre-runner!! -cAcHe- Grand Cherokee General Discussion 210 04-11-2017 04:29 PM
Volcom02WJ's Finally got around to it build thread!!!! Volcom02Wj Grand Cherokee General Discussion 81 05-05-2012 03:38 PM
vansskaterfreeks 5.9 build thread... finally vansskaterfreek Grand Cherokee General Discussion 23 05-20-2010 08:00 PM
Dillonzjs 1995 5.2 build thread finally has a small lift lol Dillonzj Grand Cherokee General Discussion 318 04-17-2010 11:31 PM
97casteeltj's build thread (finally) 97casteeltj Wrangler General Discussion 42 10-29-2008 10:43 AM
