My 01 Limited build: Minivan on Steroids!!! - Page 6 - JeepForum.com
post #76 of 115 Old 04-24-2013, 06:56 AM
GCjunkie93
Very nice!...for a street queen
Are they gunna send new shocks for the front?
GCjunkie93 is offline
post #77 of 115 Old 04-24-2013, 08:36 AM Thread Starter
GODMODEX
I haven't called yet, I might leave it... the stiffer shock up front sorta helps balance out the rear. And she'll be offroad soon!
01 TJ, 32RH, 4.0, 8.8, hpd30, 35's, metalcloaks
07 CBR600RR, full Akra exhaust, PC V, etc.
GODMODEX is offline
post #78 of 115 Old 04-24-2013, 11:03 AM Thread Starter
GODMODEX
adjusted the caster a bit. it's between 3.5-4.5 according to my little app on my phone still need to play with the draglink and remeasure my toe but I think the toe is pretty good. The brake steer decreased with the caster adjustment as well. weird.
anyways, moar pictures
And I promise some wheeling pics soon! just gotta get bumpstops, coil retainers, my spare wheel mounted in my spare tire, and some recovery gear cuz mine is worn out
GODMODEX is offline
post #79 of 115 Old 04-24-2013, 11:17 AM
adavis39
looking good....now take that rear sway bar off and start cutting
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #80 of 115 Old 04-24-2013, 11:25 AM Thread Starter
GODMODEX
Dude I had the grinder out last night to trim just so I could turn, and I just about chopped my fenders off and halved my rear bumper and yeah, that rear sway bar is tiny. I doubt it will do much. My old rig had no sway bars and I loved it. It was a bit different than this, but still...
GODMODEX is offline
post #81 of 115 Old 04-24-2013, 11:27 AM Thread Starter
GODMODEX
A couple mods I REALLY wanna do: tank tuck, and make some quick discos. I also would like some exhaust
GODMODEX is offline
post #82 of 115 Old 04-24-2013, 11:31 AM
BLACK04WJ
I will give you my disconnect pins when I bring you my muffler
and the tank tuck is easy!
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #83 of 115 Old 04-24-2013, 11:32 AM
adavis39
just cut the muffler off......itll will give you plenty of room whenever you got o rear long arms and sounds awesome on the v8. and its free!
TNJEEPS.COM
BUILD:
adavis39 is offline
post #84 of 115 Old 04-24-2013, 11:33 AM Thread Starter
GODMODEX
Sounds good to me black04wj! I lack a welder is my only problem for the tank tuck... and adavis I would, but from what I've experienced with my other vehicles they like a little backpressure from the muffler, especially for bottom end torque. With 2 precats and a main cat I might have enough backpressure anyways tho... gotta get a muffler to keep her legal tho
GODMODEX is offline
post #85 of 115 Old 04-24-2013, 11:41 AM
BLACK04WJ
i didnt weld anything when i did mine
and yeah, you need a full exhaust to be legal here in Utah lol
where I live, they dont care much so I can get away with it cut off
Oct '12 GCOTM
post #86 of 115 Old 04-24-2013, 12:48 PM Thread Starter
GODMODEX
Did you use nutserts or just bolts?
GODMODEX is offline
post #87 of 115 Old 04-24-2013, 01:48 PM
BLACK04WJ
nutserts on mine.
Oct '12 GCOTM
post #88 of 115 Old 04-25-2013, 02:00 PM Thread Starter
GODMODEX
BLACK04WJ Did you have the actual install tool or did you just use the method with two wrenches? Small update also, the issue is with my brakes somewhere. Gonna tear down and clean all my calipers, and bleed all the old fluid out. Trans fluid change will probably happen sunday, along with swapping and warrantying a cv I just replaced february that puked its guts. Might also need new front driveshaft u joint ( getting some speed related squeeking noise) but I'll replace the cv first to see if that does it. Gonna try to find some scrap 2x6 to make bumpstops out of saturday or monday, and get my coil retainers installed, and heater core bypassed in there somewhere. Always something that needs to be done!
GODMODEX is offline
post #89 of 115 Old 04-25-2013, 02:14 PM
BLACK04WJ
I just used the 2 wrench method. out of the 6 nutserts, only one didnt work with that method lol.
Oct '12 GCOTM
post #90 of 115 Old 04-25-2013, 02:18 PM Thread Starter
GODMODEX
That's the method I'll probably use then, did you order yours or is there somewhere local that carries them?
GODMODEX is offline
