Mwyatt's WJ Build - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Mwyatt's WJ Build
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-13-2011, 07:31 PM   #91
scarrskey
The more the merrier. Since I'm not bringing much to the table I guess I'll supply the beer
[URL="http://www.jeepforum.com/forum/f22/scarrskeys-99-wj-build-1184094/"][SIZE="4"][COLOR="DarkRed"]My Build[/COLOR][/SIZE][/URL][FONT="Impact"][/FONT]
scarrskey is offline   Reply With Quote Quick reply to this message
Unread 07-13-2011, 07:55 PM   #92
mtnmarc
the rear, i folded it up (rolled) and used epoxy. seems to hold well for now. hammer time
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 07-13-2011, 10:31 PM   #93
MWyatt
scarrsky, bring whatever you want. I'm only 18 so no beer for me
mtnmarc, sounds good. Ill have to pick up some epoxy before this happens. would rubberized undercoat work?
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
http://www.jeepforum.com/forum/f197/mwyatts-wj-build-1180994/
"If you can't fix it with a hammer, then you have an electrical problem."
MWyatt is offline   Reply With Quote Quick reply to this message
Unread 07-14-2011, 02:15 AM   #94
mtnmarc
Only 20 here too
I think rubber under coating would work even better. I just went with what I had laying around.
Unread 07-14-2011, 04:13 PM   #95
scarrskey
Guess it'll have to be O'douls.......
Unread 07-14-2011, 05:05 PM   #96
MWyatt
Parts came in today. Wix fuel filter and an ACDelco Power Steering Line. Install this weekend.
Unread 07-14-2011, 05:14 PM   #97
mtnmarc
Did you get them from rock auto?
Unread 07-14-2011, 05:14 PM   #98
MWyatt
yessir
Unread 07-14-2011, 05:22 PM   #99
mtnmarc
Ok, ill tel you my thoughts about rock auto.....
First thing I ordered from them was a heater core. Looked good. Pulled out the stock one and it was significantly larger than the rock auto one. Said ok, put it in anyways and called it golden. Drove the truck ONE day, heater core blew again.
Second thing.... ordered a water pump, thermostat, and drive belt. All the pretty good ones, but not the best. Drive belt is already starting to fray and show bad signs of wear, at maybe 7,000 miles or near 6 months. My water pump bearing is already crapping out as well and it was replaced at the same time.
So needless to say, I'm very hesitant to go back to them. But their service was very fast.
Unread 07-14-2011, 05:29 PM   #100
MWyatt
what brands did you buy from them? the parts I ordered are from pretty well known companies. not "rock-auto" brand. That's good info to know though, ill keep an eye on these parts.
Unread 07-14-2011, 05:40 PM   #101
mtnmarc
Off hand I don't recall. But ill check when I get home and check the receipt.
Unread 07-16-2011, 05:40 PM   #102
MWyatt
Changed the power steering line and fuel filter today. Fuel filter wasn't too bad to change and PS line was a breeze. Hopefully no more leaks up front and some better mpgs
Unread 07-16-2011, 08:59 PM   #103
mtnmarc
Since those parts are decent brands, I don't think you will have a problem with them.
Unread 07-16-2011, 09:52 PM   #104
MWyatt
yeah I knew the wix filter would be goo because that's what practically everyone on here changes theirs with. And the power steering line fit no problem and seemed like it was made pretty well.
Time to try to convince my dad to let me cut my fenders this week.
Unread 07-18-2011, 02:14 AM   #105
mtnmarc
hooray for cut fenders
