Mwyatt's WJ Build - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Mwyatt's WJ Build
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 04-06-2011, 03:54 PM   #31
MWyatt
The iron-y is for the drivers right? So what do you do about the passenger upper control arm?
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
http://www.jeepforum.com/forum/f197/mwyatts-wj-build-1180994/
"If you can't fix it with a hammer, then you have an electrical problem."
MWyatt is offline   Reply With Quote Quick reply to this message
Unread 04-06-2011, 04:21 PM   #32
scarrskey
Yes, the Y is the driver's side. The passenger side does not have any arms connecting to the upper mount......hence the 3-link design.
[URL="http://www.jeepforum.com/forum/f22/scarrskeys-99-wj-build-1184094/"][SIZE="4"][COLOR="DarkRed"]My Build[/COLOR][/SIZE][/URL][FONT="Impact"][/FONT]
scarrskey is offline   Reply With Quote Quick reply to this message
Unread 04-06-2011, 07:33 PM   #33
heretolearn
OP what did you use to paint the cladding with? I am looking to do the same thing to mine
2002 Laredo for sale
heretolearn is offline   Reply With Quote Quick reply to this message
Unread 04-06-2011, 08:43 PM   #34
MWyatt
scar - I totally read over that
heretolearn - I used Krylon Fusion spray paint in the "satin" black finish. Its great! No real prep work, just clean it really well with warm soapy water. I put 3-4 coats on.
Unread 04-07-2011, 11:28 PM   #35
MWyatt
Got my Solid diff cover today, installing it this weekend along with a fuel filter.
Unread 04-27-2011, 06:02 PM   #36
MWyatt
Ordered a set of Teraflex springs today. hopefully with graduation next month I'll rake in enough cash to get the rest of the necessary parts to finish the new lift.
Unread 04-29-2011, 10:28 PM   #37
MWyatt
Scratch that on the springs. Had an "epiphany" yesterday. Gonna stay with my lift, add a 3/4 spacer, skids, sliders, and adjustable control arms. When these tires are done I'll cut the fenders and slap 33x11.5s on.
Unread 04-29-2011, 11:12 PM   #38
mtnmarc
Nice jeep man.
Good way to save on that extra 1/4 inch and get some sliders.
The teraflex springs are nice, but after 2 years on my jeep, they have sagged a lot and lean passenger at least 1.5 inches.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 04-30-2011, 12:34 PM   #39
MWyatt
Thanks man. I plan on trying to stay lower in lift and just make it plenty protected. Anyways I'm more of a trail guy than a crawler.
I see your in grass valley, perhaps we will cross paths sometime!
How do you like your IRO CA's? I'm trying to plan which ones I want. I'm between IRO and Iron Man.
Unread 04-30-2011, 01:11 PM   #40
mtnmarc
I'm sure we will. Ha.
After my jeep has gone under the knife, we should go wheeling.
My Iro ca's are nice, nothingreally to compare them to, but the have worked well for me. I'd go Iro just for their customer service. It's awesome.
Unread 04-30-2011, 04:29 PM   #41
MWyatt
What are you doing to it? I want to make a trip to Strawberry Pass this summer. I know there are a couple other WJ guys in the area maybe we could plan some sort of trip.
IRO's CS is great! Thanks for the info.
Unread 04-30-2011, 05:19 PM   #42
mtnmarc
Check my build thread.
A lot of work. Ha.
Unread 04-30-2011, 06:35 PM   #43
scarrskey
I would be in
Unread 05-01-2011, 10:21 AM   #44
mtnmarc
Originally Posted by scarrskey View Post
I would be in
That would be funny if we all went wheeling. All 3 of our jeeps are very very similar.
White 99 laredos with black rims.
Unread 05-01-2011, 02:52 PM   #45
MWyatt
Well today I heard anew "noise" i hadn't heard before so I looked and found "splattered" oil in my drivers side front wheel well, with a drip on the control arm and shock. Also found "rips" in my front drive shaft on the joint conectgetd to the transfer case. Yay
