Mwyatt's WJ Build - Page 23 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Mwyatt's WJ Build
*STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light BaRuffstuff 10 year saleRegear now with Gear Packages from JeepHut.com
Unread 03-21-2013, 11:29 PM   #331
mtnmarc
my 35s are junk now. cords showing and chunking bad. a little too much skinny pedal on rocks... hahha.
but yeah ill show him that.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 03-22-2013, 05:47 PM   #332
MWyatt
Got the roof rack rails painted up today and had O'Reillys order the NSS connector, picking it up tomorrow morning.
Marc, want to shed some light on the ZJ radiator swap you mentioned in black04wj's thread? I'm interested in that since my lower support is pretty dented. The front clearance would help a ton!
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
http://www.jeepforum.com/forum/f197/mwyatts-wj-build-1180994/
"If you can't fix it with a hammer, then you have an electrical problem."
MWyatt is offline   Reply With Quote Quick reply to this message
Unread 03-22-2013, 10:08 PM   #333
mtnmarc
Greg has a 5.9 zj radiator in his. You need to notch the frame rails to fit it since its wider.
Unread 03-23-2013, 01:34 AM   #334
MWyatt
Hmm.... maybe a summer project. I would love to eliminate that lower rad support!
Unread 03-23-2013, 02:56 PM   #335
MWyatt
Replaced the NSS connector today, hopefully it fixes my reverse lights. If not I'll try replacing the plug on the tranny.
Old plug, I think it was time for a new one....
Unread 03-24-2013, 07:59 PM   #336
MWyatt
Ordered some speakers for this write-up: http://www.nagca.com/forum/showthread.php?t=45992
Drove it back to college today, 205 mile trip and averaged 18.6 mpg (hand calculated). Not bad!
Unread 04-27-2013, 08:28 PM   #337
MWyatt
Found a ramp near my school! Swaybars are still on, I could easily move to 33s I feel.
Unread 04-30-2013, 08:16 AM   #338
mtnmarc
You need...... 35s.....
Unread 12-12-2013, 07:38 AM   #339
connorsaul
Hello, did you apply the 3/4" spacers only in the front or did you put them on the front and rear? I'm looking to run this same setup. 3" IRO lift with 31x10.5r15 on my 04 WJ
connorsaul is offline   Reply With Quote Quick reply to this message
Unread 12-13-2013, 01:45 PM   #340
MWyatt
I had them front and rear. If you are planning to cut your fenders as well don't waste your time with 31s, you are going to want 33x10.5s before you know it
Unread 12-17-2013, 05:47 PM   #341
MWyatt
Ended up selling it over summer actually. Miss having a jeep pretty bad. Thinking about picking up an '04 H.O. 4.7 or a decent limited with low miles soon. Gonna build it right the first time come around the next jeep.
