mtnmarc's '99 WJ build thread - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > mtnmarc's '99 WJ build thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 06-25-2011, 07:16 PM   #106
mtnmarc
Buffed my headlights today. I work at a dealership so I had one of the detailers give me a hand
I love the results. So I decided to super clean the whole jeep.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 06-25-2011, 07:21 PM   #107
mtnmarc
Originally Posted by motodude248 View Post
Same thing happened to my brake lights. I took them off and pulled the bulbs. Turned out that the contact points had bent and broke. Not sure if its the same issue but might be worth checking.
I'll check it out. It's just two screws. Probably tomorrow on my day off.
Unread 06-25-2011, 07:27 PM   #108
Akrobatiks
Looks good all clean bro...! I had the same issue when I put my stock tailights back in while I was waiting for replacement tails after the fall... I bent the contacts a bit and they workd fine...
2001 WJ Limited 4.7L Black on Black --- [B]Interior Modifications...[/B] Alpine INA-w900 navigation unit, 2 9-inch headrest LCD's, Alpine PDX-F4 125w x 4 Multi-channel Digital amplifier, Alpine Type - X Component Interior Speakers, Alpine PDX-M12 1200w x 1 Digital Mono Sub Amplifier, 2 MTX - 9510's, Custom built subwoofer enclosure, Sirrius Satellite Radio, Backup Camera, Viper 5901 Remote start/alarm, Passport Escort 9500ci Radar Detector/Laser Shifter, Optima Yellow Top Battery, Cobra 29 LTD BT CB Radio --- [B]Exterior Modifications...[/B] 6" Clayton Long arms, Bilstein 5100's, Addco Front and Rear Sway bars, IRO extended rear sway bar links, JKS Trackbar, JKS quicker front disconnects, IRO front upper and lower coil retainers, Rough Country Dual Steering Stabilizers, 17" Fuel Hostage Wheels, 285/70 Goodyear Wrangler Duratracs, Westin Safari bar, PIAA 525 dual beam off road lights, CCFL Halo Projector Headlights w/ Super Vision 6000k HID bulb kit, 100w PIAA 4000k halogen high beams, LED 360 Amber LED signal bulbs, LED Tail Lights, Jet Accu-Speed Computer chip, Flashpaq jeep power programmer, AVS rain gaurds, Yakima 4 Snowboard rack, Curt tow strap receiver mount, Hornblasters Shocker 240 Train Horn Kit, Rigid E-Series 40" LED light bar, Mean Green H.O. Alternator, JCR Stage 3 Sliders, Blue Torch d30/d44a diff covers, KOR Steath rear tire carrier/bumper. LSR winch mount front bumper, Warn xd9000, KOR under Belly skid...
[CENTER][URL="http://www.jeepforum.com/forum/f197/akros-2001-wj-build-1132013/"][B]Akrobatiks Build Thread[/B][/URL][/CENTER]
[CENTER][SIZE="4"][B][URL="www.jamielinkphotography.com"]www.jamielinkphotography.com[/URL][/B][/SIZE][/CENTER]
Akrobatiks is offline   Reply With Quote Quick reply to this message
Unread 06-27-2011, 12:33 AM   #109
mtnmarc
ya, i pulled the housings and swapped them and the drivers side worked. so the connections inside the housing was messed up. pulled it apart and saw a burnt part in the plastic. idk how, but i just bent it to contact the spots and called it golden for now.
and thanks
Unread 07-02-2011, 09:30 PM   #110
mtnmarc
Picked up my tires from Andy today.
Best tire.16/32nds
Worse tire still has 9/32nds
Unread 07-05-2011, 05:48 PM   #111
MWyatt
Are you still planning on swapping out your 44a? when can I have it :P
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
http://www.jeepforum.com/forum/f197/mwyatts-wj-build-1180994/
"If you can't fix it with a hammer, then you have an electrical problem."
MWyatt is offline   Reply With Quote Quick reply to this message
Unread 07-05-2011, 10:40 PM   #112
mtnmarc
Yes I am. It's gunna be around 3 months til I can get that axle out. If my Wj wasnt my dd, I'd be making a deal with you right now
Unread 07-06-2011, 01:15 PM   #113
MWyatt
3 months is perfect!
Unread 07-06-2011, 04:53 PM   #114
mtnmarc
alright
ill pm you when the time comes closer, id even be down to help with the install.
Unread 07-07-2011, 11:39 AM   #115
MWyatt
The help would be appreciated! You aren't getting rid of the front D30 are you?
Unread 07-07-2011, 12:02 PM   #116
mtnmarc
Yes I am. A full float 14 bolt rear and high pinion 44 up front.
Unread 07-07-2011, 12:10 PM   #117
MWyatt
In that case... I'll take the front to when you get rid of it
Unread 07-07-2011, 12:23 PM   #118
mtnmarc
It needs ball joints. I've just been neglecting doing them cuz I'm gettibg rid of it soon.
Unread 07-07-2011, 04:16 PM   #119
MWyatt
That's no biggie. How are the 3.73 gears on 33s? And is your 44a a open diff or limited slip?
Unread 07-08-2011, 01:28 PM   #120
mtnmarc
33s aren't bad. But it is nice to have the 4.7. On minor hills it kicks out of over drive pretty fast
And yes they I believe they are open, perfect if you want to throw an Aussie locker in there. I'll double check when I get home.
