mtnmarc's '99 WJ build thread - Page 44 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > mtnmarc's '99 WJ build thread
ORS4x4: New Product!Aluminum Quick Release Fire Extinguisher Mounts from ORS4xKinetic Recovery Rope from ORS4x4
Unread 06-24-2013, 09:58 PM   #646
mtnmarc
Originally Posted by wj4play View Post
I guess in Cali having a heater is kinda like having AC at the North Pole
Hahah. I'll fix the problem before the winter.... maybe.
I just don't have the time to fix it before July. Maybe if I spent less time on jeepforum
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 07-02-2013, 09:13 PM   #647
mtnmarc
I've got some updates. Been working on the jeep after work the past 2 days.
Replaced both o2 sensors. Front and rear gear oil. Rear might have to get flushed again soon. Front looked good. Adjusted the rest upper control arms to fix my pinion angle. Might have extended them and inch or so. And I've been cutting the front under the head lights. Drivers side mostly done. Gunna have to rework an evap thing under the drivers head light.
It looks close. There is 6 inches of shock showing, and there is almost 7 inches from the tire to the head light bucket at full lock right. I'll have to cut the passenger side and flex it to see if I need to cut more, or ditch the stock head lights and get some hid driving lights and have Greg fab up some lights mounts with the factory grill.
OK, enough talk, pictures...
Drivers side cut
Drivers side without the plastic front clip.
Passenger side not cut too much.
Unread 07-02-2013, 09:15 PM   #648
mtnmarc
Clearance from the backside.
From the front
From the side
I also bypassed the heater core. This part for anyone who is as lazy as me.
Riebes part
Unread 07-02-2013, 09:17 PM   #649
mtnmarc
And some fun at work. All tires still on the ground.
Unread 07-03-2013, 11:28 AM   #650
Bama_WJ
Trimming looks good. It's crazy how much it opens up without the sheet metal under the headlights.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 07-03-2013, 05:59 PM   #651
Geo-Nemesis
removing all that metal will weaken the unibody?
'02 Black Overland H.O. V8
Geo-Nemesis is offline   Reply With Quote Quick reply to this message
Unread 07-03-2013, 08:49 PM   #652
wj4play
No the structural supports is mainly the u shaped bar that bends down to the lower radiator support as well as the lower boxed sides
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline   Reply With Quote Quick reply to this message
Unread 07-04-2013, 12:07 AM   #653
mtnmarc
Picked up a Taurus fan from wjcreep today. Gunna take out the stupid fan clutch and probably just swap change the water pump since it is making some noise.
It won't weaken the unibody, just the fender a little. But I don't care, I think I'll need to cut the fender more anyway.
Got some work to do before the weekend, planning on a fordyce trip.
Unread 07-04-2013, 11:34 AM   #654
macbethpoe1
So are you going with a dual electric fan setup? Or just electric? Or just taking the fan clutch out for now?
macbethpoe1 is offline   Reply With Quote Quick reply to this message
Unread 07-04-2013, 11:52 AM   #655
mtnmarc
If I can source all the parts in time, it will be just electric.
The Taurus fan pulls a lot of air, and I'm hoping that will cool my jeep a little better than the fan clutch.
I don't think I'll have time to get a dccontrol 2 speed fan relay, which is controlled by a thermistor. I'll just have to wire it to a 70 amp relay and run it always on high speed.
Unread 07-04-2013, 12:53 PM   #656
wj4play
Be sure to make a plug on the fan side Incase your relay/switch burns up - that way you can Hotwire it to get home without overheating
Unread 07-05-2013, 08:38 AM   #657
mtnmarc
That's a good idea. The switch really shouldn't burn up. Its only controlling the 12v supply with minimal amps. I've heard the Taurus fan pull a lot of power on high, if anything, I would need a larger rated relay for the power side of the fan.
Unread 07-05-2013, 09:30 AM   #658
TJSWJ
Interested to see how you mount it. Ive been saving a few of the taurus fans from cars weve scrapped. Planned on doing this swap sometime.
[URL="http://www.jeepforum.com/forum/f197/tjs-01-wj-build-thread-1023461/"]4.5" Claytons, 33's, 231hd, locked, and more. Click here for details[/URL]
TJSWJ is offline   Reply With Quote Quick reply to this message
Unread 07-05-2013, 11:22 AM   #659
mtnmarc
Its a pretty big fan. And it has a fan shroud. So best case scenario, it bolts up pretty easily. I know I'll have to take my whole front end apart. Its cooler today so I may try to tackle part of it today after work.
Still need to cut the passenger side under the head light too. Time is running out. Cutting is more important right now. I need flex. Hahah.
Unread 07-05-2013, 11:25 AM   #660
TJSWJ
Sounds like a drug. Yo, yo, you got any of that flex?
