mtnmarc's '99 WJ build thread - Page 41 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > mtnmarc's '99 WJ build thread
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 06-09-2013, 07:56 PM   #601
mtnmarc
Connected the white/orange wire to the green/blue wire, still no speedo.
I'm lost now. What else to do.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 08:13 PM   #602
W2001J
Don't need a speedo!
93 ZJ Under Construction
Build Thread
W2001J is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 08:54 PM   #603
mtnmarc
Yes I do.
Unread 06-09-2013, 09:16 PM   #604
TJSWJ
Are you sure your using the correct wss wires. Before you said your wires were black and brown (brown being the signal from the sensor. In that case you should be connecting a brown wire to the Orange/white (pin 3 @ abs connector) wire.
What color wire is white/Orange wire (at the sensor) connected to?
Just for ****s and giggles take a jumper wire and connect it from the sensor signal output wire to pin 3 at the abs. So you will be using the jeep to give the sensor 12v and ground, but you will be using your own wire to transfer the signal to the instrument panel.
Edit: this is a known good sensor right? No chance that it's bad?
[URL="http://www.jeepforum.com/forum/f197/tjs-01-wj-build-thread-1023461/"]4.5" Claytons, 33's, 231hd, locked, and more. Click here for details[/URL]
TJSWJ is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 09:48 PM   #605
mtnmarc
Its a weird situation. At the sensor, the white/orange connects to the brown wire. The orange goes to black. I measured 12v with the key on to the black wire. So that's obviously power. And brown is signal, that's why its connected to the white/orange at the sensor. And black is ground. The ground is good. I tested voltage after connecting the power and ground through the 3 wire connector.
This is where the abs 2 wire connector is under the rear seat drivers side
Brown goes to green/blue.
Black goes to green.
So at the abs module harness I connected the green/blue to the white/orange wire. That is what I'm told is the vehicle speed wire that goes to the pcm. I've been told by a few people that looked at the FSM, they said that's the wire.
Ground is good.
Power is good.
Sensor is brand new. It must not be getting signal. I can try clocking the sensor a different way.
Unread 06-09-2013, 09:51 PM   #606
dillonjm
Instead of driving it each time, try turning the sensor with a drill with the key on to test. This should help rule out installation into the case errors.
If that all checks out, it appears you at least have the wires up to the ABS module correct.
If you cant get a signal the way i mentioned, you can also back track with a multimeter to test the sender itself. Spinning the sensor with the meter checking voltage on the sender wire should indicate if your sensor is actually outputting a signal.
If I get time, I'll run my wiring tomorrow and see what I get.
[B]03 Rubicon[/B] (Weekend Toy) [URL="http://www.jeepforum.com/forum/f176/marshals-03-rubi-2822258/"]Build thread[/URL]
[B]11 Ram 2500 [/B] - H&S tuned 6.7 Cummins (DD/Tow Rig)
[B]05 Liberty Limited[/B] (Wife's): Minor mods, OME/JBA Suspension, 245 70/17 Duratracs
dillonjm is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 10:13 PM   #607
CRJEeP_wj
Have you looked at wagoners.com/WJ/tech/WIRING/wj-wiring.pdf ? That's how I figured out how to wire my speed sensor to my dd box. Was your jeep originally picking up a signal from the tone rings on your axles? If so, are they sending the same type signal?
02 grand cherokee, hp60 14b, 42s. Stazwork, triangulated 4-link, rear leafs, homemade bumpers and sliders. build thread [url]http://www.jeepforum.com/forum/f197/creep-wj-tons-build-1505917/[/url]
CRJEeP_wj is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 10:22 PM   #608
dillonjm
I pulled the relevant diagrams from that PDF:
Crappy uploads, sorry.
It looks like pin3-pin6 on the abs control. Colors are irrelevant, but I'd cut pin 3 and 6's wires from the controller and tie them together. But I think you said you were already tying 3-6 together.
Pin 5 should be the 12v supply to the sensor, 6 should be the return. Pin 3 is the wire to the PCM, at least according to these diagrams.
Unread 06-09-2013, 10:26 PM   #609
TJSWJ
Ah, forgot about the color change under the seat. I agree with dillonjm, hook up a meter and see if your getting an output. Wouldn't be the first time I've seen a brand new sensor be bad. I also agree with using a drill, that way you can verify the sensor is in deed turning and you don't have some weird mechanical issue with the sensor.
Unread 06-09-2013, 10:28 PM   #610
CRJEeP_wj
I could be wrong but i think i would look for the right rear wheel speed sensor wire where it ties into the c.a.b. and eliminate it and replace with the new signal. If the signal is a different type then you may need a signal converter of some sort.
Unread 06-10-2013, 09:37 AM   #611
TJSWJ
What vehicle is the case and speed sensor out of? That way I can look up the wirring diagrams for that vehicle and make sure you are using the right pins at the sensor.
Looking at a 97 TJ
Pin# 1 would be the signal output (connects to brown wss wire)
Pin# 2 sensor ground (Chassis ground)
Pin# 3 5V supply (in your case 12v)
If your looking at the sensor, pin# 1 is on the left.
Unread 06-10-2013, 09:55 AM   #612
mtnmarc
I think the sensor was for an 01 tj, which should be the same as a 97.
I remember pin 2 was ground (black). I don't have any pictures, but I know solid orange went to power and white/orange was signal.
Following that diagram, its the same as all the others I've seen, the left rear wire colors are different, but they are wired in the right way.
I'll just have to drive it to work tomorrow and try the drill method. And I'll tale tons of pictures to show my exact set up.
Unread 06-10-2013, 11:45 AM   #613
TJSWJ
On a 01 Tj:
Pin# 1 5v supply (or 12v in your case) should be violet/orange
Pin# 2- Sensor Ground, Black/Light Blue
Pin# 3- signal output (connects to brown wss wire) white/orange
Unread 06-10-2013, 03:27 PM   #614
wj4play
here is that post for a 99 wj that swapped TC like you only used a ZJ 242
http://www.jeepforum.com/forum/f197/...99/index9.html
I got the new 242 swapped in and got it wired up. It is reeding about 10% fast right now but it sould be right on with 36s and 5.13s.
For anyone that is curious, the wiring is quite simple. The speed sensor on the 242 is 3 wires:
1) Orange- 5v (I used a 5v source from the power seats)
2) White\Orange- speed signal to PCM
3) Dark blue- signal ground (I just grounded to the e-brake bracket under the rear seat)
I reused the wiring from the rear driverside wheel sensor to get the speed signal to the CAB. Then I spliced it to the white/orange wire coming out of the CAB. The ABS light is on but the brakes dont feel any different so I think it will be okay. PM me if you need any more info on that.
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline   Reply With Quote Quick reply to this message
Unread 06-10-2013, 04:15 PM   #615
TJSWJ
Looking at a 97 TJ
On a 01 Tj:
Looks like its different than the 97 TJ. That could be your problem right there, you need to know for sure what year sensor your using. 97 TJ uses pin#1 for signal output, 01 TJ uses pin#3
