mtnmarc's '99 WJ build thread - Page 40 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > mtnmarc's '99 WJ build thread
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 06-05-2013, 09:25 PM   #586
mtnmarc
I saw that they might be different colors.
Black is grounded to chassis. Disconnected the plug at the vss, turned the key on, used a dmm to measure voltage at the plug. Ground was good. And got 12v from orange/white and 5v from orange wire.
Used the wiring diagram to make sure the cab harness colors were the same. They are. Pin 3 and pin 5. Connected those. Test drove and got nothing.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 09:41 PM   #587
AgitatedPancake
Hey Marc are those black/brown wires on the length of sensor wiring you took home with ya? Where that connects to the chassis side, what are the colors? Still black/brown?
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 10:05 PM   #588
mtnmarc
I'll double check in a few hours.
Unread 06-05-2013, 11:24 PM   #589
TJSWJ
The wire with 5v is the signal wire. That needs to be the wire that gets attached to the signal wire for the instrument panel.
[URL="http://www.jeepforum.com/forum/f197/tjs-01-wj-build-thread-1023461/"]4.5" Claytons, 33's, 231hd, locked, and more. Click here for details[/URL]
TJSWJ is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 11:56 PM   #590
mtnmarc
So I may have solved the problem. Won't know tomorrow until I actually do it..
So here's the deal, it may seem confusing. But I'll try to take pictures tomorrow. Anyways....
Sensor wires
Orange-12v
White/orange-signal
Black-ground
Left rear abs harness has 2 wires
Black-12v
Brown signal
Connector for left rear abs wire
Black connects to green
Brown connects to green/blue
And so the signal wire is the green/blue.
Therefore at the cab harness I need to splice white/orange (in pin 3) to green/blue (in pin 6 I believe) and not to green (in pin 5).
I've been talking to Greg and we both think we just nailed it. Its too dark now and without my tools, I can't do much right now.
Unread 06-05-2013, 11:58 PM   #591
W2001J
You don't need a speedo!
93 ZJ Under Construction
Build Thread
W2001J is offline   Reply With Quote Quick reply to this message
Unread 06-06-2013, 12:03 AM   #592
mtnmarc
You're crazy fool. My tranny isn't happy already. Without the speedo, it has harder down shifts.
Unread 06-06-2013, 12:05 AM   #593
AgitatedPancake
Having a speedo is awesome, I'll be making mine work once we figure out Marc's . The automatic trans in these WJ's is sure more happy with one too haha.
ZJ's i'd be a little less worried, but there's no need to ever lose your speedo in a ZJ
Unread 06-06-2013, 12:13 AM   #594
mtnmarc
Its obviously throwing a code too. P0500 no vehicle speed sensor reading.....hmmmmm I wonder why. Hahah.
So it needs to get fixed for smog, which I stupidly enough have to do this year. Perfect time to swap axles, not. But the little headache is worth it.
I want to just work on it now and get it figured out, but my snap on tools at work make life easier. Hah.
I'm glad I'm your test vehicle Greg!
Unread 06-06-2013, 09:20 AM   #595
TJSWJ
Here is what I have
Sensor Wires:
Orange- 5v (in your case we are going to send 12v to it)
white/orange- Signal wire (thats what we are going to send to the pcm)
Black (or yellow pending year)-Goes to a chassis ground.
Left rear wss sensor wires:
Green- 12 volts (connect this wire to the orange sensor wire)
Green/Dark Blue- Signal return ( connect this wire to the white/orange speed sensor wire, this is going to be your signal)
Abs connector:
Pin #6- Gren/Dark Blue (Cut this wire as that is going to be your signal from your new speed sensor)
Pin#3 - White/Orange (cut this wire and connect it to the Green/Dark Blue you cut from pin# 6)
If all my schematic reading is correct, this should give you a speed signal
Edit: after reading the above post it seems you have a black and a brown wire for you Left Rear sensor. In that case:
Black- 12 volts (connect this wire to the orange sensor wire)
Brown- Signal return (connect this wire to the white/orange speed sensor wire)
Unread 06-06-2013, 09:26 AM   #596
mtnmarc
That's exactly what I came up with last night. So the wiring on the mallcrawlin thread is wrong.
They say to connect pin 3 and 5. Not 3 and 6.
I didn't end up driving it to work today, but I plan on working on it when I get home tonight.
Unread 06-06-2013, 09:30 AM   #597
TJSWJ
Awesome, keep us posted.
Unread 06-06-2013, 05:08 PM   #598
dillonjm
30mm@70/sec
dillonjm's Avatar
Interested to see how you get it worked out. I may run my wiring this weekend and use a drill to see if I get it right before my tcase gets here next week.
03 Rubicon (Weekend Toy) Build thread
11 Ram 2500 - H&S tuned 6.7 Cummins (DD/Tow Rig)
05 Liberty Limited (Wife's): Minor mods, OME/JBA Suspension, 245 70/17 Duratracs
dillonjm is offline   Reply With Quote Quick reply to this message
Unread 06-06-2013, 07:27 PM   #599
wj4play
wj4play's Avatar
Interested as well ... I have no actual experience except for my research and reading.
Was a red 99 wj from Illinois that also did the swap - he hooked up the wired like you to a tail shaft vss
Sent from iPhone
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 08:27 AM   #600
dillonjm
30mm@70/sec
dillonjm's Avatar
Get it sorted out?
