mtnmarc's '99 WJ build thread - Page 38 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > mtnmarc's '99 WJ build thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 05-29-2013, 11:32 PM   #556
AgitatedPancake
Or just bolt another one on like factory. Cutting and welding sounds like a lot of work.
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 05-30-2013, 12:28 AM   #557
W2001J
Bro! Idk what set up you had. Haven't been there in a couple weeks!
93 ZJ Under Construction
Build Thread
W2001J is offline   Reply With Quote Quick reply to this message
Unread 05-30-2013, 12:31 AM   #558
AgitatedPancake
haha there aren't many axles that have brake caliper brackets cast into them, just some TTB ford stuff and I think unit bearing dana 60's. Check out post number 538, about 30 posts back. You can see the brake brackets
If the bracket was one with the knuckle that would be opening a whole new can of worms lol
Unread 05-30-2013, 01:27 AM   #559
W2001J
Ahhhh front axle. Got it!
Build Thread
Unread 05-30-2013, 02:59 PM   #560
TJSWJ
Replacement caliper bracket is in route
[URL="http://www.jeepforum.com/forum/f197/tjs-01-wj-build-thread-1023461/"]4.5" Claytons, 33's, 231hd, locked, and more. Click here for details[/URL]
TJSWJ is offline   Reply With Quote Quick reply to this message
Unread 05-30-2013, 03:01 PM   #561
AgitatedPancake
Thanks a ton man, a good bracket is definately the right way to fix this thing so it is much appreciated!
Unread 05-30-2013, 03:25 PM   #562
TJSWJ
You guys are both welcome. Like I was telling Marc, we all gotta help eachother, sometimes it aint about making money. I just want to see this thing in action! You did a hell of a job! It should be there this Saturday.
Unread 05-30-2013, 06:17 PM   #563
dillonjm
I am really glad you mentioned that bolt, I forgot to install mine when I did the front brakes and your ordeal reminded me.
[B]03 Rubicon[/B] (Weekend Toy) [URL="http://www.jeepforum.com/forum/f176/marshals-03-rubi-2822258/"]Build thread[/URL]
[B]11 Ram 2500 [/B] - H&S tuned 6.7 Cummins (DD/Tow Rig)
[B]05 Liberty Limited[/B] (Wife's): Minor mods, OME/JBA Suspension, 245 70/17 Duratracs
dillonjm is offline   Reply With Quote Quick reply to this message
Unread 06-01-2013, 05:18 PM   #564
AgitatedPancake
Dillon, we found out exactly how important that bolt is, and all I can say is you'd be having a bad day without it haha. From the short test drive Marc and I did a few days ago (less than a mile), the H block was half way to removing itself.
TJSWJ, the bracket came in today and I got it installed. Apparently this one uses a 3/8" bolt which caught us by surprise, but not enough to slow us down . Marc left for home with the WJ about 15 minutes ago. Here's to smooth sailing on the trip home!
Unread 06-01-2013, 05:26 PM   #565
sdmayhew
Flex videos! Let's see them
1993 ZJ Clayton long arms with Johnny joints, custom front axle W yota center, D44 chevy outers, fabtech dirtlogic 2.25, front bilsten rear shocks, tacoma rear axle, 4.88, arb rear, 5 speed, poly motor mount inserts, NP241OR 4-1 ,receiver front for xcr 8k winch
sdmayhew is offline   Reply With Quote Quick reply to this message
Unread 06-03-2013, 09:26 AM   #566
TJSWJ
Come on Marc, you had all weekend to play and take pics. Dont keep us waiting......
Unread 06-03-2013, 01:40 PM   #567
mtnmarc
Hahah. I have had since Saturday, but.....
And this time its not my Jeep! We took my buddies 4runner Saturday to get my jeep. On the way back, the rear pinion bearing seized and locked up the tires at freeway speed on highway 80. I was behind him and saw the whole thing. Managed to get on the shoulder and slid sideways for about 200 feet. It could have been REALLY bad, especially with no doors, a dog, and a ton of snap on tools in the back.
We were on the side of the freeway for about 2 hours. And got towed by a ford :-( but it all worked out.
I still have to get the shocks filled with nitrogen. Driving it home and to work one day without it, and man it was soft. Hopefully I'll have some flex shots later in the week. No speedo sucks, but I'll be fixing that soon. It stalls slowing down from freeway speeds at times, I'm guessing from the lack of speed reading. And it drives way better than it did before. No death wobble, slight vibe at 65 from rear pinion angle. Easy to adjust. Other than that, its 100 times better than before. Cruising 65 mph, rpms are around 2100 with the 5.38s and 37s. Before I was could barely cruise 55-60 and hold speed easily with 3.73s and 35s.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 06-03-2013, 03:32 PM   #568
wj4play
Of I remember right Greg's (ap) wj trams died from not having a speedo input. Might wanna fix that soon. Glad everything else is working out for ya
Sent from iPhone
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline   Reply With Quote Quick reply to this message
Unread 06-03-2013, 04:36 PM   #569
AgitatedPancake
The ultimate failure of my trans happened when the ATF mixed with coolant and all sorts of bad stuff happened. Though I can't deny that some of the problems were probably related to the speedo haha
Unread 06-03-2013, 05:00 PM   #570
doorjamm
So the radiator was the main cause for failure?
And is that why you ultimately started the nv3500 project?
doorjamm is offline   Reply With Quote Quick reply to this message
