mtnmarc's '99 WJ build thread - Page 33 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > mtnmarc's '99 WJ build thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 05-05-2013, 05:09 PM   #481
doorjamm
I'm thinking a rubicon run in June or July would be nice. I know a couple people that would like to come, not WJs, but people nonetheless.
doorjamm is offline   Reply With Quote Quick reply to this message
Unread 05-05-2013, 05:39 PM   #482
mtnmarc
I'm not sure exactly the date it will be done Ryan. If its done, I'll go with you guys.
I already plan on a con trip in late June with the auburn jeep club. Any trips I hear about, I want to go on. Ha. Work is the big factor though. Having split days off sucks. I go wheeling with my boss so I'll try to get him to switch my schedule to be able to go on trips easier.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 05-05-2013, 08:58 PM   #483
MWyatt
My buddy is planning a Rubi trip on the 15th of June I believe. Anyone know if Strawberry will be open this year?
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
http://www.jeepforum.com/forum/f197/mwyatts-wj-build-1180994/
"If you can't fix it with a hammer, then you have an electrical problem."
MWyatt is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 01:04 PM   #484
wvracer821
wvracer821's Avatar
any chance we can get the numbers you used for the 3 link calculator? im working on designing a similar setup and ive been playing around with the calculator a little but not real sure what numbers to use. on a different note this thing is going to be kick *** when its done
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread: http://www.jeepforum.com/forum/f197/...build-1436556/
http://www.pirate4x4.com/tech/
wvracer821 is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 03:13 PM   #485
mtnmarc
I've never been to strawberry trail. Its up 50 right?
And I'll have to talk to Greg about the calculated number. I know he's switched it up a few times with clearance issues. And thanks, its been a long time saving parts and all that. And its awesome that Greg is at the shops he's at and has time to deal with all the issues that have come up.
I've been looking at fuel cells recently after it passes smog this year, I'm thinking about putting a fuel cell in the back and clearing up some space to slide the axle back and cut more in the rear fender wells. Haven't looked into too much detail, as I just want to get it back and go wheel the crap out of it. I'm sure there is a way to keep all the evap system stuff functioning with a fuel cell, just need to do more searching.
Unread 05-06-2013, 03:33 PM   #486
scarrskey
I've never been to strawberry either and haven't checked the land use section on pirate in a while. I know there has been a lot of Northern California closures. I'm hoping to make the rubicon an every other weekend or every third weekend event this summer. Was pretty much that way last year. I live so close that we can take a lot of overnight trips. I'm down for almost anytime I have off work.
[URL="http://www.jeepforum.com/forum/f22/scarrskeys-99-wj-build-1184094/"][SIZE="4"][COLOR="DarkRed"]My Build[/COLOR][/SIZE][/URL][FONT="Impact"][/FONT]
scarrskey is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 03:45 PM   #487
mtnmarc
I currently have Wednesday and Sunday off. But if we hire a new kid, I'll have a rotating schedule with Saturday Sunday, or Sunday Monday off. So hopefully that happens soon. I could always head out Saturday after work and camp.
Unread 05-06-2013, 03:56 PM   #488
scarrskey
I start with cal fire on Monday the 27th the weekend right after Memorial Day. Have no idea what my schedule will be expect that it's 3 on 4 off. Hopefully all 3 days land in the middle of the week.
Unread 05-06-2013, 04:44 PM   #489
wj4play
Need this now
Sent from iPhone
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 07:15 PM   #490
mtnmarc
I may have to do something like that. But a fuel cell is more aestheticly pleasing to the eye. Ha.
Progress today. Bracing the coilover mount.
Some plating to the lower control arm mounts.
Unread 05-06-2013, 07:27 PM   #491
scarrskey
Go ahead and tell Greg he might as well just go ahead and make a second set of the front and rear coilover mounts for good measure. Seems to me there is another white WJ in the Sacramento area that wants some new CO's.
Unread 05-06-2013, 08:51 PM   #492
doorjamm
Where are the lca mounts going on the frame?
Unread 05-06-2013, 09:29 PM   #493
mtnmarc
buy my 12"s. i found a place with hella good deals on fox and king coilovers, emulsion, reservoir and piggybacks. might have to go 16" in the front and move the 14"s out back that will be decided later. that would also make me go into the body in the back, darn, time to cage it
the lower control arm mounts and going next to the cross member. greg cut the outer 2 bolts off for clearance. im hoping a more high clearance tube cross member will come out of it
Unread 05-06-2013, 09:38 PM   #494
doorjamm
You planning on doing anything with the exhaust since the third cat is so out there? And any ideas of clocking the transfer case?
Unread 05-06-2013, 10:35 PM   #495
mtnmarc
I only have one cat and its out of the way of the cross member. No real way to clock the t case without smashing up the floor board.
