mtnmarc's '99 WJ build thread - Page 32 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > mtnmarc's '99 WJ build thread
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 05-02-2013, 06:34 AM   #466
Bama_WJ
I see now. I thought that big protrusion where the coil sits was going to get cut out in order to fit the coilovers.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 05-02-2013, 06:41 AM   #467
dillonjm
Any reason why you didn't run the coil over mounting bracket to the axle tube instead of your link bracket? Or is this just s partial bracket mockup?
[B]03 Rubicon[/B] (Weekend Toy) [URL="http://www.jeepforum.com/forum/f176/marshals-03-rubi-2822258/"]Build thread[/URL]
[B]11 Ram 2500 [/B] - H&S tuned 6.7 Cummins (DD/Tow Rig)
[B]05 Liberty Limited[/B] (Wife's): Minor mods, OME/JBA Suspension, 245 70/17 Duratracs
dillonjm is offline   Reply With Quote Quick reply to this message
Unread 05-02-2013, 12:53 PM   #468
AgitatedPancake
Dan I'm not personally a fan of putting the lower control arm mount on top of the axle tubes like most people do. It makes you have to stuff more of the coilover into the engine bay than I feel is ever really necessary. This location actually worked out great, I didn't even have to remove the AC drier like I expected. On the drivers side, the mount squeezes just BARELY into the pocket between the abs pump, master cylinder and brake booster.
Dillon, it will also be attatched to the axle tube, but this is the best orientation for packaging the mount down there, and still being able to get the control arm bolt out without the mount being in the way haha.
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 05-02-2013, 03:32 PM   #469
mtnmarc
Pictures of the clearance.
And then Greg's awesome idea.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 05-02-2013, 03:57 PM   #470
wj4play
Now Greg ..those hex head tabs... .. That's just showing off
Sent from iPhone
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline   Reply With Quote Quick reply to this message
Unread 05-02-2013, 04:43 PM   #471
adavis39
freaking genius with those tabs. I first looked at the pic and thought it was dumb to have to remove the coil to get the arm off........then I looked harder and had to slap myself for judging you too quickly....excellent work man!!!
EDIT: when I first saw the pic it was where Mark had posted it in another section of the forum. he only included the second pic. so im not completely blind haha
2002 WJ Limited [B]4.7[/B]: 6" Clayton REALLY long arms....yep, they are longer than yours [B]SOLD : ([/B]
1998 Platinum [B]5.9[/B] DD
2007 WK Overland [B]5.7[/B] wifes DD
TNJEEPS.COM
BUILD: [B][url]http://www.jeepforum.com/forum/f197/utwj-build-other-crap-1399123/[/url][/B]
[B]"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"[/B]
adavis39 is offline   Reply With Quote Quick reply to this message
Unread 05-02-2013, 08:50 PM   #472
sdmayhew
Dang greg that's showing off
1993 ZJ Clayton long arms with Johnny joints, custom front axle W yota center, D44 chevy outers, fabtech dirtlogic 2.25, front bilsten rear shocks, tacoma rear axle, 4.88, arb rear, 5 speed, poly motor mount inserts, NP241OR 4-1 ,receiver front for xcr 8k winch
sdmayhew is offline   Reply With Quote Quick reply to this message
Unread 05-03-2013, 07:38 PM   #473
AgitatedPancake
Haha! you guys are funny, gotta do something trick every once in a while to mix things up a bit
Don't count yourself out too fast now! You do have to unbolt the coilover to remove the control arm bolt, it's the only way I could get things packaged in a way that fit all the constraints well. Ideally it wouldn't be like that, but I put more importance on placing the shock where I think it'll work best, even though disassembly might take an extra couple minutes .
I'm just letting you guys know, this thing looks GOOD with the front coilovers under it...that's been todays fun!
Unread 05-04-2013, 12:47 PM   #474
mtnmarc
Full bump. A little less than an inch of shaft showing will prevent the shocks from ever bottoming out and blowing out a seal or worse. At this point, the lower control arms are flat on the frame rails.
Unread 05-04-2013, 11:47 PM   #475
dillonjm
Reading back a ways, did you use a special reamer for your pitman warm to accept the larger TRE or just measure out the size of the tapered shaft and take it down to that depth on the reamer?
Unread 05-04-2013, 11:54 PM   #476
AgitatedPancake
Just a 1.5" per foot reamer (that is the taper of all GM 1 ton TRE's), go until the TRE seats far enough to get a cotter pin through the castle nut and you're good. If you go a little farther than that, you can put a washer under the nut to give proper spacing for the cotter pin.
Unread 05-04-2013, 11:57 PM   #477
dillonjm
Thanks.
Gotta do mine here before too long.
Unread 05-05-2013, 12:05 AM   #478
AgitatedPancake
Heck yeah. What I do to make life easier is measure the diameter of the threaded shank, IIRC the ES2233L and ES2234R are 5/8" and the ES2027L and ES 2026R drag link ends are 11/16" but the same 1.5" taper per foot. That makes it so you have less to cut with the reamer. If your not too familiar with reamers they are awesome. If you're doing it by hand, just a nice slow even speed with as much weight as you can smoothly apply. If you get any binding/deflection watch it because I've heard of people breaking reamers. I haven't had any issues myself yet, doing about 50% by hand and 50% in a drill press. They cut material like nobody's business, just put some sort of oil to keep cutting temps down and go to town
Unread 05-05-2013, 02:15 PM   #479
mtnmarc
Upper control arm mount.
Reamed out.
3/8" spacer was needed to make a little clearance.
Droop to the floor.
Unread 05-05-2013, 02:54 PM   #480
scarrskey
Looking good man. Is it going to be ready before Memorial day. We are thinking of either a Rubicon or Moonrocks trip that weekend. My new 3 link worked awesome on the trail can't wait to see yours perform.
[URL="http://www.jeepforum.com/forum/f22/scarrskeys-99-wj-build-1184094/"][SIZE="4"][COLOR="DarkRed"]My Build[/COLOR][/SIZE][/URL][FONT="Impact"][/FONT]
scarrskey is offline   Reply With Quote Quick reply to this message
