mtnmarc's '99 WJ build thread - Page 16 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > mtnmarc's '99 WJ build thread
Jeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineIncome tax season is upon us. We got what u need
Unread 06-22-2012, 08:16 PM   #226
MGDWJ
Originally Posted by mtnmarc View Post
What are some specs on that? What up with your wj?
Kingpin 60 from 35 spline chromos rear HP semi float Dana 60 35 spline full spool f/r 5.13 gears. 14" king coil overs f/r. Rear has 14" fox triple bypass shocks. Trail ready bead locks 40" IROKS. 4.0 HO from a TJ NV 4500 with 4.3 Atlas 2. Chassis is 1.75" .120 dom mastercraft suspension seats with 5 point harnesses.
WJ build thread.
MGDWJ is offline   Reply With Quote Quick reply to this message
Unread 06-23-2012, 11:27 AM   #227
mtnmarc
Everything minus a semi float rear axle.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 06-23-2012, 01:57 PM   #228
MGDWJ
Its actually very strong so far and the buggy only weights like 2200 lbs. Its the only stock 35 spline semi float axle i have seen. I want to take out the spools and instal some selectable lockers and a set of cutting brakes.
WJ build thread.
Unread 06-23-2012, 02:09 PM   #229
AgitatedPancake
That buggy looks badass, but with all the heavy parts you mentioned I'd think it would end up in the 3500lb range. Not that I think you're getting close to the limit on that axle though!
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 06-27-2012, 05:32 PM   #230
W2001J
So we spent 12 hours yesterday building and install long arms in the rear. It's a triangulated 4 link. Marc can add more pictures if he wants.
Old **** out.
Lower arms build and welded. Lower arms are ruff stuff 1/14" heims. Lower I think are the 3/4".
Upper mount tack welded. Bracket from Balistic Fab.
D44 link mounts with plate.
Just some welding.
Upper and lower mounts fully welded.
The final result.
93 ZJ Under Construction
Build Thread
W2001J is offline   Reply With Quote Quick reply to this message
Unread 06-27-2012, 05:55 PM   #231
mtnmarc
I don't have any final pictures, nor do I have any flexed yet. Maybe tonight.
Unread 06-27-2012, 05:58 PM   #232
mtnmarc
And they are 1 1/4 ruff stuff heims lowers with 2 inch. 250 wall dom and 3/4 inch uppers with 1 1/2 inch. 250 wall dom.
Unread 06-27-2012, 06:04 PM   #233
W2001J
It's not gonna flex much with your shocks!
Build Thread
Unread 06-27-2012, 06:07 PM   #234
mtnmarc
Just went out and snapped these pictures....
Unread 06-27-2012, 06:16 PM   #235
AgitatedPancake
I saw these pics last night . Lookin awesome man! One thing I highly recommend, do something to plate the frame rail and connect the two mounts to each other. It'll help keep the unibody strong for years to come haha. Feel the wrath of my paint skills!
Unread 06-27-2012, 06:18 PM   #236
W2001J
Greg cut us that plate and I'll weld her in! Marx your gonna have to make a template
Build Thread
Unread 06-28-2012, 12:08 AM   #237
mtnmarc
Ill make a template and get it to you asap. Heading to the Rubicon in like 2 weeks so strong is always better.
That's one thing I really wanted to do, is plate the unibody.
The road noise definitely increased with hard joints on all ends. I think im getting a little noise from the drive shaft, luckily the uppers make it easy to mess with the linking angle.
Unread 06-28-2012, 12:25 AM   #238
W2001J
Greg is saying to make a plate to attach the 2 brackets for strength. Get it and I'll weld it.
Build Thread
Unread 06-28-2012, 12:33 AM   #239
Shinobi
are u going in july 7th weekend or 14th ?
Shinobi is offline   Reply With Quote Quick reply to this message
Unread 06-28-2012, 12:56 AM   #240
mtnmarc
july 13-15th
