mtnmarc's '99 WJ build thread - Page 14 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > mtnmarc's '99 WJ build thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-10-2012, 04:11 PM   #196
mtnmarc
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 01-13-2012, 01:32 PM   #197
scarrskey
It was good to finally meet you and do a little bit of wheelin.
Looks like this is the problem with my jeep......hopefully
TSB 1803103 - 4.0L ROUGH ENGINE IDLE AFTER RESTART FOLLOWING A HOT SOAK
[URL="http://www.jeepforum.com/forum/f22/scarrskeys-99-wj-build-1184094/"][SIZE="4"][COLOR="DarkRed"]My Build[/COLOR][/SIZE][/URL][FONT="Impact"][/FONT]
scarrskey is offline   Reply With Quote Quick reply to this message
Unread 01-13-2012, 01:55 PM   #198
scarrskey
And here's the link to those axles also
http://sacramento.craigslist.org/pts/2786454231.html
Unread 01-18-2012, 12:38 PM   #199
mtnmarc
yeah man, it was a nice little run. you should have followed me up the left side of the tree when we were leaving. haha. here are some pictures..
and then me hitting my cross member. ha..
Unread 01-18-2012, 12:41 PM   #200
mtnmarc
then went wheeling sunday in colfax with a buddy. few flex shots..
and my favorite one..
Unread 01-18-2012, 01:21 PM   #201
PhantomWJ
2003 WJ
Originally Posted by MWyatt View Post
Here's that cut I was telling you about. Thanks again for all the help yesterday.
What bumper is that?
PhantomWJ is offline   Reply With Quote Quick reply to this message
Unread 01-18-2012, 02:04 PM   #202
mtnmarc
idk. mwyatt posted it. he found it somewhere.
that picture was just to show me the fender cut he was talking about.
Unread 01-18-2012, 02:20 PM   #203
MWyatt
I'm pretty sure its a custom bumper, unfortunately...
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
http://www.jeepforum.com/forum/f197/mwyatts-wj-build-1180994/
"If you can't fix it with a hammer, then you have an electrical problem."
MWyatt is offline   Reply With Quote Quick reply to this message
Unread 01-18-2012, 10:25 PM   #204
scarrskey
Your talking about when you made use of your sliders and I took the bypass on the right hand side right? With the weight of the axles in the back and not having rocker protection I don't think I would have been able to open my doors after lol. Sliders went on today and 6.5" coils will be going on saturday. Next time I'm out there I will definitely hit that line and maybe try the first rock face also. Now I just need to buy my gears and then start shopping for some tires.
Sounds like I might get a good deal on a JK rubi front 44 complete with chromos
Unread 03-27-2012, 01:58 PM   #205
mtnmarc
Damn. Went wheeling last night and bent my tie rod. So I'm in a pickle....
Fix the Dana 30 with a tie rod, ball joints, and rotors.
Or bend the tie rod back as much as possible and maybe sleeve it if needed, adjust the toe to get everything decent again, and put the money towards the Dana 44.
Unread 03-27-2012, 03:54 PM   #206
MWyatt
Check Pick and pull. I just got a tie for for like $30 there with TREs
Unread 03-28-2012, 03:23 PM   #207
mtnmarc
gunna have to check there. thanks man.
Unread 04-29-2012, 05:28 PM   #208
mtnmarc
havent been buying much for the jeep lately, life is getting in the way.
i did however change the diff fluids and another oil change. idk how long it has been since last diff service, but i felt like it was time to change the fluid. it still was relatively clean. also checked the gears and carrier, no chips or cracks. also found out i need bigger tires, front and rear center sections had scrapping on the bottom. and the front lower most bolt was smashed and had the hardest time getting it off.
im really debating getting an rc crawler to wheel while the jeep has balding tires and is my dd. like this
http://gmade.net/dealer/images/r1_1.jpg
anddddd ive also been debating since i have mostly everything to do the coilover install and long arms, i might just build it up with the stock axles and when i can afford to swap the 44 and 14 bolt in, everything will already be built.
Unread 04-30-2012, 12:22 AM   #209
scarrskey
Save your money and skip the RC crawler. I wanna see coilovers now!!
Then I wanna drive it and convince my bank account I need coilovers. Are they 2.0 12" FOA's front and rear? I think that's what I remember.
Unread 04-30-2012, 04:36 PM   #210
mtnmarc
14s for the front and 12s for the rear.
If I put the coilovers in now, I need to cut up the axles a little to clean them up. I might be able to just put some tabs on it to keep it still "bolt in" for when I sell it. The front im not too worried about because it will need some work to get decent enough to put in another jeep. Ball joints, rotors, tie rod. But I could sell the calipers and knuckles for a wj brake swap for tj guys.
And I need to see if the heims will fit in the stock lower control arm mounts at the axles. Then make or find some front and rear upper control arm mounts at the frame side. Not a whole lot, just stuff that will need my dd to be down for a while.
