mtnmarc's '99 WJ build thread - Page 42 - JeepForum.com
post #616 of 723 Old 06-10-2013, 04:40 PM Thread Starter
mtnmarc
Originally Posted by TJSWJ View Post
Looks like its different than the 97 TJ. That could be your problem right there, you need to know for sure what year sensor your using. 97 TJ uses pin#1 for signal output, 01 TJ uses pin#3
I ordered it off rockauto. Using the 01 tj as a reference. Soooo I may need to switch the orange and white/orange wires.
I'll try the drill thing first and see where that takes me.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #617 of 723 Old 06-10-2013, 09:32 PM
dillonjm
2013 WK
Hey brother, get yours sorted out yet?
I wired up mine tonight and got it to work. Mine was pin 3-5 on the abs plug and pin 3 output from the sensor, not that it matters since yours could be opposite.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #618 of 723 Old 06-11-2013, 11:49 AM Thread Starter
mtnmarc
****! No. I didn't get to work on it last night. Went to Greg's shop to pick up the old axles andbull**** with him for a little . I'm gunna mess with it tonight at work. It may be the fact that the sensor I have is opposite of everyone else's.
mtnmarc is offline
post #619 of 723 Old 06-11-2013, 12:25 PM Thread Starter
mtnmarc
I did find a pin out of my sensor off their site.
Airtex part number 5S4684
I'll see what my wiring is compared to the sensor after work. And basically redo all the wiring again if I need to.
mtnmarc is offline
post #620 of 723 Old 06-11-2013, 03:54 PM
dillonjm
2013 WK
That's showing pin 3 as the signal output. That's how mine is wired up.
dillonjm is offline
post #621 of 723 Old 06-11-2013, 10:31 PM Thread Starter
mtnmarc
Bam!
So I got it figured out. For some reason, the green wire at the abs harness wasn't supplying 12v to the sensor when it is the power wire for the old left rear abs sensor.
At first I double checked all the connections and traced the wires, making sure signal, ground and power wires had good connections. Then key on, didn't get power at the sensor. Jumped power to the green wire and spun the sensor, bam! Had a speedo!!!! So there is some reason why I'm not getting power through that wire. I spliced it in to the abs power wire and now I'm getting a speedo. Using the 41 tooth gear, its dead on. 37s and 5.38s.
mtnmarc is offline
post #622 of 723 Old 06-11-2013, 10:42 PM
AgitatedPancake
Winning! Well done bud, glad it was something simple, and everything was already on the right track except for that one little quirk.
Now chop part of the sheetmetal bumper out from under your headlight, and open up the wheel well openings on the rear plastic bumper . When I flexed it the tires were just able to grab the bumper. Not by a ton though
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #623 of 723 Old 06-11-2013, 10:49 PM Thread Starter
mtnmarc
Now just gotta fix the check engine light for the o2 sensors. Hahah.
I need to cut. Just been super busy lately. I'm off tomorrow, so I may get to choppin!!
The whole front end needs to come apart, again. So we will see what happens.
I'm just glad the speedo gremlin is gone.
mtnmarc is offline
post #624 of 723 Old 06-12-2013, 09:40 AM
wj4play
Good job , I would have sworn you would have needed a compensatior to correct your speed. Glad it's dead on
Sent from iPhone
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #625 of 723 Old 06-12-2013, 09:50 AM
TJSWJ
NICE! Glad to hear you got it straightened out!
TJSWJ is offline
post #626 of 723 Old 06-12-2013, 10:47 AM Thread Starter
mtnmarc
Before, the green wire was sending voltage to the sensor. So Idk what happened but I'm glad its figured out.
Trans shifts way better now. Before it had harsh 2-1 shifts, and in the parking lot, it would lock up both rear tires and chirp them.
And I think it fixed my very slight stalling issue. It had only stalled a handful of times, but it would be at horrible times like at a stop light or coming off the freeway. Idle stays constant while down shifting rather than dipping under 500 while on the brakes.
mtnmarc is offline
post #627 of 723 Old 06-12-2013, 02:20 PM
Bama_WJ
Good info for me. Thanks.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ, 2014 WK2
Bama_WJ is offline
post #628 of 723 Old 06-12-2013, 07:38 PM
skain8
skain8's Avatar
Glad you got it worked out. Its always the little **** that drives you bonkers with a swap like this.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #629 of 723 Old 06-15-2013, 02:32 PM
wj4play
You have the 4.0 right?
Edit: 4.7 I see
5:38 is not to steep for you on the highway and 37"s?
Sent from iPhone
wj4play is offline
post #630 of 723 Old 06-17-2013, 05:50 PM Thread Starter
mtnmarc
Edit: 4.7 I see
Sent from iPhone
Its not too bad. Its at 2200 rpm at 65 mph. I don't drive much freeway with it so I don't really care.
mtnmarc is offline
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
Help on how to do a build thread coolio365 ZJ Grand Cherokee Forum 11 12-09-2011 05:14 PM
Alexsious's WJ Build Thread alexsious Grand Cherokee General Discussion 4 01-19-2011 02:28 AM
WK build thread WSPJeep Grand Cherokee General Discussion 95 11-01-2010 09:17 AM
WJ_Renegade's Build Thread XJ_Renegade Grand Cherokee General Discussion 32 12-18-2009 03:52 AM
