mtnmarc's '99 WJ build thread - Page 40 - JeepForum.com
post #586 of 723 Old 06-05-2013, 09:25 PM Thread Starter
mtnmarc
I saw that they might be different colors.
Black is grounded to chassis. Disconnected the plug at the vss, turned the key on, used a dmm to measure voltage at the plug. Ground was good. And got 12v from orange/white and 5v from orange wire.
Used the wiring diagram to make sure the cab harness colors were the same. They are. Pin 3 and pin 5. Connected those. Test drove and got nothing.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #587 of 723 Old 06-05-2013, 09:41 PM
AgitatedPancake
Hey Marc are those black/brown wires on the length of sensor wiring you took home with ya? Where that connects to the chassis side, what are the colors? Still black/brown?
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #588 of 723 Old 06-05-2013, 10:05 PM Thread Starter
mtnmarc
I'll double check in a few hours.
mtnmarc is offline
post #589 of 723 Old 06-05-2013, 11:24 PM
TJSWJ
The wire with 5v is the signal wire. That needs to be the wire that gets attached to the signal wire for the instrument panel.
TJSWJ is offline
post #590 of 723 Old 06-05-2013, 11:56 PM Thread Starter
mtnmarc
So I may have solved the problem. Won't know tomorrow until I actually do it..
So here's the deal, it may seem confusing. But I'll try to take pictures tomorrow. Anyways....
Sensor wires
Orange-12v
White/orange-signal
Black-ground
Left rear abs harness has 2 wires
Black-12v
Brown signal
Connector for left rear abs wire
Black connects to green
Brown connects to green/blue
And so the signal wire is the green/blue.
Therefore at the cab harness I need to splice white/orange (in pin 3) to green/blue (in pin 6 I believe) and not to green (in pin 5).
I've been talking to Greg and we both think we just nailed it. Its too dark now and without my tools, I can't do much right now.
mtnmarc is offline
post #591 of 723 Old 06-05-2013, 11:58 PM
W2001J
You don't need a speedo!
93 ZJ Under Construction
W2001J is offline
post #592 of 723 Old 06-06-2013, 12:03 AM Thread Starter
mtnmarc
You're crazy fool. My tranny isn't happy already. Without the speedo, it has harder down shifts.
mtnmarc is offline
post #593 of 723 Old 06-06-2013, 12:05 AM
AgitatedPancake
Having a speedo is awesome, I'll be making mine work once we figure out Marc's . The automatic trans in these WJ's is sure more happy with one too haha.
ZJ's i'd be a little less worried, but there's no need to ever lose your speedo in a ZJ
Build Thread:
post #594 of 723 Old 06-06-2013, 12:13 AM Thread Starter
mtnmarc
Its obviously throwing a code too. P0500 no vehicle speed sensor reading.....hmmmmm I wonder why. Hahah.
So it needs to get fixed for smog, which I stupidly enough have to do this year. Perfect time to swap axles, not. But the little headache is worth it.
I want to just work on it now and get it figured out, but my snap on tools at work make life easier. Hah.
I'm glad I'm your test vehicle Greg!
mtnmarc is offline
post #595 of 723 Old 06-06-2013, 09:20 AM
TJSWJ
Here is what I have
Sensor Wires:
Orange- 5v (in your case we are going to send 12v to it)
white/orange- Signal wire (thats what we are going to send to the pcm)
Black (or yellow pending year)-Goes to a chassis ground.
Left rear wss sensor wires:
Green- 12 volts (connect this wire to the orange sensor wire)
Green/Dark Blue- Signal return ( connect this wire to the white/orange speed sensor wire, this is going to be your signal)
Abs connector:
Pin #6- Gren/Dark Blue (Cut this wire as that is going to be your signal from your new speed sensor)
Pin#3 - White/Orange (cut this wire and connect it to the Green/Dark Blue you cut from pin# 6)
If all my schematic reading is correct, this should give you a speed signal
Edit: after reading the above post it seems you have a black and a brown wire for you Left Rear sensor. In that case:
Black- 12 volts (connect this wire to the orange sensor wire)
Brown- Signal return (connect this wire to the white/orange speed sensor wire)
TJSWJ is offline
post #596 of 723 Old 06-06-2013, 09:26 AM Thread Starter
mtnmarc
That's exactly what I came up with last night. So the wiring on the mallcrawlin thread is wrong.
They say to connect pin 3 and 5. Not 3 and 6.
I didn't end up driving it to work today, but I plan on working on it when I get home tonight.
mtnmarc is offline
post #597 of 723 Old 06-06-2013, 09:30 AM
TJSWJ
Awesome, keep us posted.
TJSWJ is offline
post #598 of 723 Old 06-06-2013, 05:08 PM
dillonjm
2013 WK
Interested to see how you get it worked out. I may run my wiring this weekend and use a drill to see if I get it right before my tcase gets here next week.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #599 of 723 Old 06-06-2013, 07:27 PM
wj4play
Interested as well ... I have no actual experience except for my research and reading.
Was a red 99 wj from Illinois that also did the swap - he hooked up the wired like you to a tail shaft vss
Sent from iPhone
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #600 of 723 Old 06-09-2013, 08:27 AM
dillonjm
2013 WK
Get it sorted out?
dillonjm is offline
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
Help on how to do a build thread coolio365 ZJ Grand Cherokee Forum 11 12-09-2011 05:14 PM
Alexsious's WJ Build Thread alexsious Grand Cherokee General Discussion 4 01-19-2011 02:28 AM
WK build thread WSPJeep Grand Cherokee General Discussion 95 11-01-2010 09:17 AM
WJ_Renegade's Build Thread XJ_Renegade Grand Cherokee General Discussion 32 12-18-2009 03:52 AM
