Mountain Braking - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Mountain Braking
TeraFlex Now at Rockridge 4WD! BEST DEALS around!Why Buy Brakes From 1A Auto?ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 07-29-2014, 07:00 PM   #1
JeeperCreeper10
Mountain Braking
So my aunt has an 07 Grand Cherokee and claims there is no low gear to assist in mountain braking (just has drive, neutral, and reverse). What method would you all recommend she do to save her brakes? Is using 4-low an option? Thanks for the help
JeeperCreeper10 is offline   Reply With Quote Quick reply to this message
Unread 07-30-2014, 10:51 AM   #2
pkman
Junior Member
pkman's Avatar
There might be an "overdrive off" button
2002 Overland - OME 2.5 coils with Kolak special
pkman is offline   Reply With Quote Quick reply to this message
Unread 07-30-2014, 01:46 PM   #3
Timo_90xj
Timo_90xj's Avatar
I'm 100% sure there is a +/- gear change possibility on the WK gear selector when it's in "D". Just push the shift lever left or right for smaller or higher gear. It should stay in the selected lower gear until you hit close to redline, or if the RPMs fall too low it changes to a smaller gear.
..and no, 4lo is not an option at normal road speeds.
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
Timo_90xj is offline   Reply With Quote Quick reply to this message
