Moparmatters Build Thread - Page 2 - JeepForum.com
post #16 of 28 Old 12-06-2009, 12:30 AM
cirame1
hmmmm not a fan of 3 inch spacers but wat eva u plan on trimming for those 32's? also u gettin track bars or sway bar links?
98' 5.9 slate on slate...
3.5" F>R swap, front and rear adj. track bars
17" rubicons w/ 285 70 17 inch hankook mtr's
full 3 inch exhaust w/flowmaster 40 series
242j tcase swap completed by jeeps unlimited providence,R.I.
cirame1 is offline
post #17 of 28 Old 12-06-2009, 01:51 AM Thread Starter
moparmatters
Nothing in terms of track bar or sway bar links yet. This is going to be mostly mall crawling with some mudding, but it's a daily driver. I'm not too keen on rock crawling at this point so articulation isn't a huge deal. I will be trimming once I get the tires on and see how much needs to be done. I'll get new coils for the front eventually, but spacers is all I could afford right now.
On to Jeep #2... Now the fun begins!
Jeep #2 is broken... transfer case and tranny :(
moparmatters is offline
post #18 of 28 Old 12-06-2009, 02:00 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
You need the track bar for a daily driver. That thing'll be dog legging all over the place if you don't recenter your front axle at least.
You should get discos for the front and extended links for the rear. 3" will tear the stock front links apart.
ratmonkey is offline
post #19 of 28 Old 12-06-2009, 06:59 AM
97DCZJ
you need at least a front adjustable track bar to center the front axle, and extended sway bar links. your stock ones won't reach if your doing 3" of lift. with no track bar both of your axles will pretty much look like this
_[]---[]
___|
___|
1997 Grand Cherokee Orvis: V8 5.2L, stock.
(Sold) 1998 Cherokee Sport: 4.0L I6, Stock.
(Sold) 1990 Cherokee: 4.0L I6, 4.5" Lift, 33" BFG's.
(Sold) 1997 Grand Cherokee Limited: V8 5.2L, 2" BB, 31" Dick Cepeks.
(Sold) 1999 Grand Cherokee Laredo:
; V8 4.7L, Stock.
(Sold) 1996 Grand Cherokee Laredo:
; V8 5.2L ,3.5" lift, 32" Tires
97DCZJ is offline
post #20 of 28 Old 12-06-2009, 07:48 AM
Yardman Harry
O
Yardman Harry's Avatar
I can send you my rancho coils once I take them off. I have some RE 4.5 coils sitting here that Im planning on installing, hopefully next weekend. If i dont get any ill side affects Ill send you my rancho coils for the front, shipping on you.
Check out IRO for some quality parts yet not too expensive. They sell a front trackbar that would be great for you. Id save up for that next.
Yard
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #21 of 28 Old 12-06-2009, 09:48 AM
spife7980
or check out the link in my signature. for a front track bar. hint hint
80 plus whatever shipping is.
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is online now
post #22 of 28 Old 12-06-2009, 02:02 PM Thread Starter
moparmatters
Put the tires on today and took it out to test and got it all nice and stuck. I've put almost 100 miles on it now since the lift and while it pulls to the right a little bit it actually works just fine. I'll make sure a track bar and swaybar end links are my next two purchases. The front links look just fine, but the back ones definitely need it.
Rear springs
Back end all finished
Riding high
Taking on the trail
Stuck!
post #23 of 28 Old 12-07-2009, 10:58 AM
Max-Bilt
that sure was a fun build
Legends are Bilt!
Max-Bilt is offline
post #24 of 28 Old 12-07-2009, 11:18 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
i can see how far out your axles are from those pics alone.
post #25 of 28 Old 12-07-2009, 05:33 PM
97DCZJ
x2 on that! holy crap you can definitely tell. i'd be careful with wearing those tires down. your alignment is probably completely wacked out and making turns are probably fun.
; V8 4.7L, Stock.
97DCZJ is offline
post #26 of 28 Old 12-07-2009, 05:49 PM
xjPWN
1994 ZJ
man, i have the same jeep! except I smashed it to hell.
xjPWN is offline
post #27 of 28 Old 12-08-2009, 02:22 PM Thread Starter
moparmatters
Thanks for the concern everyone, but she actually drives just fine (70mph smooth) and turns without issue. I think the axles just look off in that picture, because they really aren't that bad in real life. That being said, I know that I need to get it done, and the next $ I invest into it will be for those parts.
post #28 of 28 Old 12-08-2009, 10:53 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
I have a rear jks no one has claimed yet.
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 06:00 PM
