Molly: WyoZJ's Build thread - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Molly: WyoZJ's Build thread
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 09-25-2009, 12:50 AM   #16
WyoZJ
1994 ZJ
it sure is
Five speed 35" Claws, locked, some extra steel
Front and rear Trailready bumpers, roof rack, IRO Rear long arms, and HD adjustable track bar for sale
WyoZJ is offline   Reply With Quote Quick reply to this message
Unread 11-06-2009, 05:25 PM   #17
WyoZJ
1994 ZJ
It's been slow goin on the long arms with being so busy and not being able to get into my buddies shop when i'm free but tommorrow I'll be driving to Greely to pic up some goodies
Pics to follow
Unread 08-08-2013, 10:47 PM   #18
WyoZJ
1994 ZJ
Wow. Haven't touched this thread in a hell of a long time. Since my last post I've moved 4-5 times, worked on the jeep some, beat on it a little, started Grad school and I'm now starting to make some changed to her.
I swapped in an AX15 (went smooth, if you're thinking about this swap it's EASY), got a little body damage (woooops), and did a lot of little fixes and mods. Now I'm Gonna take things up a notch.
Here's what's to come:
1. SIMPLE and light bumpers (Trailreadys are gonna go. Buy them!)
2. Ditch the roof rack (buy it!)
3. double my t-case, and maybe add a short slave shaft and do a complete flat belly. What I have planned wont work with the IRO cross member so the whole set up and track bar are also for sale!
4. Boatsides. WITH doors
5. Cage, probably hybrid
6. Hi-steer (might keep the turdy, at least for a while, or go to a D44)
And probably some other random stuff thrown in.
I'll try to throw up some current pics in the next day or two
Unread 08-19-2013, 12:58 PM   #19
WyoZJ
1994 ZJ
Current picture, not a very good one. Ordering steel today for boatsides and rear 4 link and x-member
Unread 08-22-2013, 12:50 PM   #20
WyoZJ
1994 ZJ
Got started on the boatsides last night. Figured I would start there on the list since it will be the most time consuming and cheapest material wise. Then I can knock out some of the other stuff once I sell off my bumpers, roof rack, long arms, and track bar.
Stripped the interior on the passenger side (dirty as heck I know, been sitting outside all summer with no doors on). Also started a rear seat mod that will come into play later. I'm excited about it
here is where the new rocker will sit
Put the doors back on and found the cut line. Think I'm going to keep the doors on while I cut to make the cut same on everything
A tube propped up about where it will sit off the rocker.
Where I'll be cutting does take off some of where the seat belt mounts. Either going to move it up, or install a set of harnesses. Haven't quite decided yet but leaning towards getting my B-pillar done at the same time and attaching harnesses to it
Unread 08-26-2013, 01:11 PM   #21
WyoZJ
1994 ZJ
Chopped the passenger side last night:
Pretty big hole
box tube mocked up with a trash can for reference. Will have over 31" of clearance at the rocker when it's all said and done
Hard to tell the scale completely but they are gonna be HIGH
Unread 08-26-2013, 03:31 PM   #22
CRJEeP_wj
I like it! This is gonna be awesome, please show all the details until finished.
02 grand cherokee, hp60 14b, 42s. Stazwork, triangulated 4-link, rear leafs, homemade bumpers and sliders. build thread [url]http://www.jeepforum.com/forum/f197/creep-wj-tons-build-1505917/[/url]
CRJEeP_wj is offline   Reply With Quote Quick reply to this message
Unread 08-26-2013, 04:31 PM   #23
Bama_WJ
Second that! Looks really good. Would like to see how you redo the door seal.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 08-26-2013, 05:15 PM   #24
WyoZJ
1994 ZJ
The door seal is the only thing i'm that worried about. I've got a couple Ideas, I might try them both and see which works better
Unread 08-26-2013, 07:55 PM   #25
Bama_WJ
Look forward to seeing those ideas. I was thinking about this very modification for mine.
Daniel
North Alabama Jeep
Unread 09-02-2013, 03:35 PM   #26
WyoZJ
1994 ZJ
Little more progress last week
Have about 6.5 beers of clearance at the rocker
with a piece of wood clamped on to get an idea of the slope when the UHMW gets on
Unread 09-05-2013, 03:11 AM   #27
FortCollinsZJ
Looking kick ***.
Flying under the radar.
FortCollinsZJ is offline   Reply With Quote Quick reply to this message
Unread 09-07-2013, 02:37 AM   #28
Bama_WJ
Looking good man. Can't wait to see some more updates.
Daniel
North Alabama Jeep
Unread 09-16-2013, 06:55 PM   #29
CRJEeP_wj
Any more updates on the boat sides? Do you plan to tie a cage into it?
Unread 09-20-2013, 12:40 PM   #30
WyoZJ
1994 ZJ
FINALLY got to do some work on the jeep for the first time in a couple weeks. Got the boatside about 95% done. Just need to cap the ends with some plate, make a few more welds on the floor, and add plastic. And yes, the cage will get tied into the b-pillar stanchion.
nuts welded to the plate
painted up
looks a bit like a Subaru outback from this angle
I didnt take pictures of it, but I did have to weld a small piece of angle and a nut to the b-pillar stanchion to keep use of the stock seatbelt, which will eventually get replaced by harnesses
