Modify ebay snorkel to fit wj! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Modify ebay snorkel to fit wj!
Free shipping on slip yoke eliminator kits New lower PriceNew! JK/U skid plate system.FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 11-18-2014, 05:48 PM   #1
AzLongArmWj
This is kinda my build thread to modify a 129.99 eBay snorkel that's made for a 94-? grand cherokee. Took the fender off to measure and cut into the fender for the hole. It actually fits the form of the fender pretty dam well. Next was the hard choice to drill the hole straight through the frame and pinch welds right to the inside of the engine bay or go around. I decided that it was to dangerous structurally to drill straight through so I notched out some of the frame and am going to go around and through where the washer bottle neck is. I have the fender on, frame cut, and the snorkel mounted so far but no piping ran yet. I hope I have time this weekend to finish it all up. So instead of buying a $600 $700 arb snorkel I got one for cheap and made my own. Here is a link to a exact one http://m.ebay.com/itm/like/371178675079?lpid=82
AzLongArmWj is offline   Reply With Quote Quick reply to this message
Unread 11-18-2014, 06:33 PM   #2
mycreativename
God that really makes that pedestrian hiding A pillar quite a larger menace, haha.
Regardless, well done, that looks quite good!
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline   Reply With Quote Quick reply to this message
Unread 11-18-2014, 06:47 PM   #3
SteelBlue_WJ
Where is the hose and how does it connect to the airbox?
[FONT="Century Gothic"]Bobby
[COLOR="RoyalBlue"]2001 Steel Blue WJ Laredo SA 4x4, 3.5" lift, Apperance Package with factory Laredo Steel Blue cladding/leather
Conferr Roof Basket with custom Randy Ellis Design light cage, WAAG grille guard and Hella lots of 500 lights[/COLOR]
[COLOR="Silver"]2004 Wrangler Sport, 2.5" and 31's, nothing special[/COLOR]
[FONT="Century Gothic"][COLOR="DarkGreen"]"For all sad words of tongue and pen, the saddest are these, 'It might have been.' "
[I]John Greenleaf Whittier[/I][/COLOR][/FONT][/FONT]
SteelBlue_WJ is offline   Reply With Quote Quick reply to this message
Unread 11-18-2014, 07:23 PM   #4
CHULOGORDO82
NOW IT GETS -.2 MPGS LOL... cool man i like it ...
AIRCRAFT DISPATCHER
http://www.jeepforum.com/forum/f197/chulogordos-build-tread-1520134/
CHULOGORDO82 is offline   Reply With Quote Quick reply to this message
Unread 11-19-2014, 05:45 AM   #5
offroading.net
offroading.net's Avatar
Thats a big chunck of box section to cut out
Steve Wright
1999 4litre WG Limited, 4"f-4.5"r IRO springs, IRO front long arms, IRO adjustable rear a-arm & LCAs, IRO adjustable RHD trackbar, XJ 242 transfer case, 3.91 Diesel Quadradrive axles, 235-85-16 Grabber AT2's Build thread
2003 2.8CRD KJ Limited
Previous Jeeps - 8 XJs, an MJ, a WJ, a TJ & a KJ
steve@offroading.net
www.offroading.net
www.rcmodelflying.com
www.oldchadscider.co.uk
offroading.net is offline   Reply With Quote Quick reply to this message
Unread 11-19-2014, 07:49 AM   #6
ChrisHager
ChrisHager's Avatar
I have the same questions/concerns...
1. Apart from the massive blind spot (comes with the territory I guess), I am also curious how you hooked the snorkel to the box. Remember, to make this useful, the path from the throttle body to the end of the snorkel needs to be water tight.
2. That is a massive chunk you cut out. I'd be concerned about the structural integrity of the front end.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 11-19-2014, 02:50 PM   #7
Jeeples
Jeeples's Avatar
Guys, he's not done yet. The first post says he plans on wrapping it up this weekend.
Barring that, I'm willing to bet you could find a local welder that would be willing to plate the section of railing you cut out for under $100. I think it would be well worth it.
His: '00 WJ 4.7 Limited- stock
Hers: '03 WJ 4.7 V8- IRO 3", 245/75/16 Duratracs
Jeeples is offline   Reply With Quote Quick reply to this message
Unread 11-19-2014, 03:49 PM   #8
AzLongArmWj
1. There is no "blind spot" I have no idea what your talking about? Do you know what a snorkel is and where it's mounted?
2. I knew about the structural integrity of the frame when I cut into it and plan on welding it all back up once I get my pipes in.
3. I'm not done yet, like I said if you read all the way.
4. If you want to pay $700 for an arb snorkel or safari then go right ahead. I don't know how they route there pipes but I'm not paying to find out.
5. Yes I know the purpose of the snorkel is to be air tight all the way to the TB, thanks for that.
Unread 11-19-2014, 04:46 PM   #9
ChrisHager
ChrisHager's Avatar
I do know what a snorkle is. Hints why I said that comes with the territory.
Excellent. That's a good plan.
I see that. Just offering constructive criticism.
I'd rather not. I have no use for a snorkel. Now, I think it's great you're being innovative and altering one to fit your needs. Many people ask about this. You may be paving the way for them.
Good deal. I'd hate to see a leak pop up and you suck in a bunch of water because of a bad seal.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 11-19-2014, 07:16 PM   #10
AzLongArmWj
I will smoke test the system once completed to make sure of a good seal and update pics and stuff along the way.
Unread 11-19-2014, 09:00 PM   #11
derekmac
derekmac's Avatar
I can't wait to see how it turns out! If all goes well, this could be something that I consider doing.
2002 WJ Olympics Commemorative Edition
32" BFG Mud Terrains | Custom Sliders
2" BB | Viair OBA
Build thread.
derekmac is offline   Reply With Quote Quick reply to this message
Unread 11-19-2014, 10:38 PM   #12
CHULOGORDO82
Cool idea ....
AIRCRAFT DISPATCHER
Unread 03-17-2015, 04:50 PM   #13
AzLongArmWj
Finally got around to finishing up the snorkel. It turned out amazing and I love it. Bring on the water!!
Unread 03-17-2015, 05:04 PM   #14
AzLongArmWj
The snorkel had a 4" opening so I used a 4" to 3" rubber reducer with a 3" 90 degree bend at the top to get it by the frame. Then 3" pipe all the way down to another 90 degree bend. Then a 2" spacer to connect another "extended" 90 degree that goes into my intake box. Seal the pipes with pvc cement, seal the air box with caulk and some flex seal and I'm good to go!
Unread 03-17-2015, 05:05 PM   #15
AzLongArmWj
Pipe
