Mikes silver WJ - JeepForum.com
post #1 of 1 Old 02-11-2014, 09:06 PM Thread Starter
Mikes silver WJ
Bought my 1999 jeep grand cherokee v8 picked it up for 2,000 with 180000 miles on it
Heres the Build sheet on the jeep..
*DL Prem Leather Trimmed Bucket Seats
-AZ Agate
ADBP Protection Group
ADEP Cold Weather Group
AFFP Luxury Group
APAS Monotone Paint
ARPP Limited Decor Group
AWS Smoker's Group
A29P 4.7L Engine(EVA)/4Spd A/T 45RFE(DG4)
BAZS 136 Amp Alternator
BC6S 625 Amp Maintenance Free Battery
BRYS Anti-Lock 4-Wheel Disc Brakes
CACS Low Back Bucket Seats
CBWS Highline Door Trim Panel
CFNS Rear 60/40 Folding Seat
CGWS Next Generation Front Air Bags**
CKDS Floor Carpet
CKNS Cargo Compartment Carpet
CKRP Cargo Net
CKTS Cargo Tie Down Loops
CLEP Front & Rear Floor Mats
CLGP Covered Cargo Storage
CLPS Driver Foot Rest
CSCP Cargo Compartment Cover
CSRS Passenger Assist Handles
CUDP Mini Overhead Console
CUFS Full Length Floor Console
DGB All 4-Speed Automatic Transmissions
DG4S Multi-Speed Auto 45RFE Transmission
DHAS Lock-Up Torque Converter
DHFP Quadra-Trac II On Demand 4WD System
DJJS Dana 30/186MM Front Axle
DMEP 3.73 Rear Axle Ratio
DRKP Dana 44/226MM Rear Axle
EAAC All Engines
EVA 4.7L V8 Power Tech Engine
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGP Deep Tint Sunscreen Glass
GEPS Flipper Liftgate Glass
GFAS Rear Window Defroster
GNCP Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror
GT3P Power Heat Driver Auto Dim Mirrors
GWAP Power Sunroof
GXMS Remote Keyless Entry
GXXP Sentry Key Theft Deterrent System
HAFP Air Cond ATC w/Dual Zone Control
HGAS Hood Insulation
HGDS Deluxe Insulation Group
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHBS Rear Window Wiper/Washer
JJAP Cigar Lighter
JJBS Dual Note Electric Horns
JJJP 12V Rear Auxiliary Power Outlet
JKAS Glove Box
JKPS 12V Auxiliary Power Outlet
JKYS Power Accessory Delay
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JTFP Power 10-Way Heated Memory Seats
KEDP Lt. Quartz - Paint Stripe - Bodyside
LACS Illuminated Entry
LAGS Warning Chime
LAZP Vehicle Information Center
LBBS Courtesy Lamps
LBCS Glove Box Lamp
LBDS Ash Tray Lamp
LCBP Door Courtesy Lamps
LCES Rear Courtesy/Reading Lamps
LDAS Underhood Lamp
LDBS Cargo Compartment Lamp
LETP Traveler/Mini Trip Computer
LEWP Radio/Driver Seat/Mirror Memory
LMBS Halogen Headlamps
LMGP Automatic Headlamps
LNJP Fog Lamps
LSAP Security Alarm
MDAP Front License Plate Bracket
MFTP Body Color Grille
MHAS Black Windshield Moldings
MWGS Side Roof Rails
NAE California Emissions
NBVP Low Emission Vehicle (LEV)
NFPS 20.5 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMS Speed Control
PS4 Bright Platinum Metallic Clear Coat
QS4S Bright Platinum Clear Coat
RAAC All Radio Equipped Vehicles
RAZP AM/FM Cassette Compact Disc Radio
RCEP Infinity Speakers
RDDS Fixed Long Mast Antenna
RDZP Steering Wheel Mounted Audio Ctrls
SBAS Power Steering
SCLP Leather Wrapped Steering Wheel
SDAS Normal Duty Suspension
SUAS Tilt Steering Column
TBGS Compact Spare Tire
TBLS Inside Mounted Spare Tire
TTDP P245/70R16 BSW AS Perf Tires
TZAS Goodyear Brand Tires
WDRP 16X7.0 Lux Alum Silver Wheels
WFBS Compact Spare Wheel
WLZC All Aluminum Wheels
XGDP Universal Garage Door Opener
XPFS Protective Coating and Remover
YAAS Build To U.S. Mkt. Specifications
So far i have replaced a few things.
the first thing i replace was the worn out cv axle on passenger right side.
the second thing i replaced was a bad break boster that made it have a vaccums leak. I also replaced the sprak plugs and seefoamed it. i fixed a few check engine codes by doing that. painted the rack on top it was flacking off
the few problems that i have right now are
1 The ac is not working
2. the transfercase isnt making the front tires spin.. think its the chain
3 needs new tie rod ends also shocks and tires
Future mods after i fix the few problems are maybe lift kits and some cragar soft 8s
this is how it sits
michaeladeitz is offline
